Old Sep 04, 2012, 10:49 PM
KingBubbaTruck is offline
Find More Posts by KingBubbaTruck
Reno, NV
Joined May 2007
Finally convinced to get rid of puffed lipos.
Realized it wasn't worth the risk in charging or flying with them, so hooked them up to a 50 ohm 10 watt resistor and let each one discharge overnight till the resistor was cold again. At least I was sure they weren't discharging at too high a rate.
Warning, the resistor gets hot during discharge, I used an infrared thermometer to check the temp.
While these batteries were not that overly used, they were a couple years old. I think my main problem was charging them too fast. When I first got my charger, what I read had said to charge at 2C, but everything I see now says 1C. So, I'll be changing my charging procedure.
My charger has a temp probe I can use, so I will be using that from now on, and I do use a metal can to contain the batteries during charging. I always charge them attended with a fire extinguisher close by.
Just went and ordered new batteries. Should be worth a little peace of mind.
Description:
KingBubbaTruck is offline Find More Posts by KingBubbaTruck
Old Sep 04, 2012, 10:57 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
2C vs. 1C charge rate will have zero difference on usable life. Storing in fully charged state, storing in a warm environment, and overdischarging by relying on low voltage cutoff are far more damaging to lipolys.
Store in a cool area in a discharged or partially charged state and only charge prior to use and your lipolys will reward you with a long life.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 05, 2012, 08:50 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Glad to see you got rid of all of your damaged LiPo batteries. While I understand it's a free country, I don't understand why people insist on using damaged LiPos when batteries are so cheap. The risk just isn't worth it. I may be a bit overcautious but any LiPo that's damaged even the slightest gets discharged and disposed.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Discussion Techniques for getting rid of GoPro jello TheNiceGuy Multirotor Talk 16 Sep 26, 2012 07:41 AM
Mini-HowTo get rid of the chatter in your servos!! bushpilotx1 Scratchbuilt Indoor and Micro Models 7 Jun 23, 2012 06:42 PM
Rave Finally received a Puffed Turnegy From HK everydayflyer Batteries and Chargers 26 Mar 13, 2012 02:24 PM
Discussion Finally getting rid of my heli :( Sad day. Stamp Coaxial Helicopters 1 Mar 27, 2009 02:15 AM
