Old Sep 04, 2012, 08:46 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
Proteus Motors!
Hey guys, just wanted to share some pics. Check these out, I think they are going to be a hit for sure. Let me know what you think!
Pseudonym is offline Find More Posts by Pseudonym
Old Sep 04, 2012, 11:09 PM
EJ1208 is offline
Find More Posts by EJ1208
Joined Sep 2011
Jesus that is awesome! Whats the can size on the bigger one?
EJ1208 is offline Find More Posts by EJ1208
Old Sep 04, 2012, 11:25 PM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Who makes them ,how much are they . Has any body used them . All I see is a picture of some motors and no information ? They are monsters , one is 750KV the other is 600KV . Probably need 10s amd 12s packs to run them . They do look good .
highflyerbill is offline Find More Posts by highflyerbill
Old Sep 04, 2012, 11:26 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Oh.................I thought you were gonna post the Purple Castle's
These look like some Pigs for sure! Sizes??
scorpion1 is offline Find More Posts by scorpion1
Old Sep 05, 2012, 07:48 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
http://www.skyrc.com/index.php?route...product_id=140
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Sep 05, 2012, 07:50 AM
Joined Dec 2000
The rpm limit is very low, bearings or unwraped rotor?
Old Sep 05, 2012, 09:47 AM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The low rpm limit would depend on how you look at it. 30,000 is all the Castle 2028 is rated for as well but it still makes some serious power. With enough prop it should still push a big hull pretty fast. You just have to think in comparison to the rpm's a gasser can provide.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Sep 05, 2012, 11:21 AM
rabosi is offline
Find More Posts by rabosi
United States, NY, Bethpage
These can be gotten here. http://www.keithbradleyboats.com/?page_id=4
rabosi is offline Find More Posts by rabosi
Old Sep 05, 2012, 12:56 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I like that you can change the wind type (and kv) by using different bullets at the motor, makes for less versions to carry!
Looks like a beefy motor too.
wparsons is offline Find More Posts by wparsons
Old Sep 05, 2012, 07:53 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Now Hobbyking has these Keith.................you knew they would be cheaper pricewise, BUT, then you pay shipping and pray nothing happens to it, cuz you'll never see a red cent of warranty money from HKing, with you it will be much different..............heck, you speak English to start with etc...........
You need to fix "the" to "they" in the last sentence of the 520 description btw
The Proteus line of motors is intended for large FE setups. The 520-3T is the smaller broth to the 524-3T, with a physical size of 56mm x 102mm. Single motor setups can power up to 60″ and twins up to 94″, but we recommend the large 524-3T if your project falls on the larger side of that spectrum. These motors are unique in that they feature 6 bullets connectors that can be used to configure the motor in a delta or y wind, changing the kv value and giving the motor greater overall versatility. The are also one of the best looking motors on the market.
Old Sep 05, 2012, 08:22 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Yeah baby!!
brushless55 is offline Find More Posts by brushless55
Old Sep 05, 2012, 08:52 PM
Pseudonym's Avatar
Joined Apr 2012
Thanks Scorp. It's yet to be seen hows the quality of the blue HK motors compare (I really expect the 524 to be the big seller anyway, not the 520). I know they sold some TP "copies" a while back at low prices and people said they were made with inferior parts. It wouldn't surprise me if these were the same. HK is selling them for significantly less than my cost.
I set introductory prices near cost, and I tried to keep shiping low. I only have a few, so we will see how they do. If people like them I'll be ordering more.
Old Sep 05, 2012, 09:33 PM
Pseudonym's Avatar
Joined Apr 2012
By the way...I think I missed someone's question about size. The larger motor is 56mm x 112mm
Old Sep 05, 2012, 11:46 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Specs:
RPM/v: 730kv @ "Y" config. / 1280kv @ "Δ" config.
Max voltage: 41V (11S)
Max Current: 128A @ "Y" 730kv / 229A @ "Δ" 1280kv
Max Watts: 5280wResistance: 0.0132ohm @ "Y" 730kv / 0.0046 @ "Δ" 1280kv
No Load Current: 3.2A @ "Y" 730kv / 4.2 @ "Δ" 1280kv
Can Diameter: 56mm (actual motor diameter)
Can Diameter inc. Water Jacket: 63mm
Length: 102mm
Shaft Size: 8mm
Weight: 971g
http://www.hobbyking.com/hobbycity/s...ess_Motor.html
Amp Abuser is online now Find More Posts by Amp Abuser
Old Sep 06, 2012, 11:35 AM
Pseudonym's Avatar
Joined Apr 2012
Check out the 524-3T I sell...6300Watts!
Discussion Rutan Proteus Plans Greg_E Scale Kit/Scratch Built 0 Aug 15, 2012 02:59 AM
Discussion Do you have simulated a four rotor flyer ? [Proteus] NikiPink.Com Multirotor Talk 2 Jun 29, 2012 11:33 PM
Sold Cheddar proteus boiler zorrow Boats (FS/W) 0 May 28, 2012 11:47 AM
Sold motors motors motors! chyorn Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 16, 2012 07:57 PM
Discussion ~100W 2s motor, what motors are efficient these days? saitrix Power Systems 0 Feb 27, 2012 01:13 AM
