Old Sep 04, 2012, 06:36 PM
rdold is offline
Find More Posts by rdold
Joined Sep 2012
Turnigy Typhoon 500H Settings
Hi All
I'm interested to hear from you what settings you are running in your ESC with the Typhoon 500H
I have a TAROT 500 with an 80A YEP ESC (YGE Clone) with an 11T pinion and a 2200 6S.
The performance is hardly dazzling, this has made me suspect that maybe my settings are out.
I'm currently set up like this:
Timing - 18 degrees
Governor - Off
Startup Speed - Heli Middle
PWM - 8 kHz
Startup Power - Auto 1-32%
Any thoughts will be appreciated
rdold is offline Find More Posts by rdold
Old Sep 04, 2012, 06:44 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
That motor is a powerhouse for a 500 heli. Listed at 1800kv...Its more like 1900kv. ....Set your normal throttle curves to 0-30-50-75-100. Your battery is small at 2200mah your looking at 3.5 min flight time..this heli takes 2600-3000mah, Most run a 6s 3000mah 30c-40c that will get you 5.5- 6 min flight time. Set your esc to soft start. Stay with your 11 tooth pinion with that motor.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Sep 04, 2012, 07:00 PM
rdold is offline
Joined Sep 2012
Thanks Stixx44
Yes, my next battery purchase will be 3000mah.
I was talking more around the power, it seems to be quite tame. And with all the talk about how awesome and powerful these motors are I was wondering if my timing or PWM is out?
Sold Turnigy Typhoon 500H RobDog Aircraft - Electric - Helis (FS/W) 2 Jul 27, 2012 08:18 AM
Sold Turnigy Typhoon 500H 1800kv (NIP) snoshoe62 Aircraft - Electric - Helis (FS/W) 2 Apr 11, 2010 08:54 PM
For Sale Turnigy Typhoon 500H Heli Motor 1800kv (500 Class) snoshoe62 Aircraft - Electric - Helis (FS/W) 0 Mar 14, 2010 10:39 PM
Sold Turnigy Typhoon 500H Heli Motor 1800kv (500 Class) snoshoe62 Aircraft - Electric - Power Systems (FS/W) 3 Mar 14, 2010 09:16 AM
For Sale Turnigy Typhoon 500H Heli Motor 1800KV for 500 heli compuatic Aircraft - Electric - Helis (FS/W) 3 Jan 12, 2010 04:06 PM
