Old Nov 13, 2001, 09:41 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
how to bypass LVC or use rx batt with esc
Wondering if theres a way to do either of these things easily.
Would love to bypass completely or reset voltage cutout to a lower voltage number on my kontronic 4001, or if thats not possible, to use a seperate rx batt. I'm not sure how to do that. All my planes always just plugged the esc connector into channel 3.
Any ideas anybody?
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Nov 13, 2001, 10:52 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Hi Dean,
I don't like BEC's and only use them in small stuff where there is no choice. I've read a number of posts where planes are lost because the BEC burned up. Separate battery removes that fear completely.
To use a separate battery for the reciever and servos, simply remove the red (pos) lead from the plug from the esc to the throttle channel and tape it back. This leaves the signal and ground connections required to work the esc.
The rc system now needs a separate pack / switch just like a glo powered model.
As far as the cutoff voltage, I'm clueless.
But, on mine without the BEC or cutoff, when the battery dumps its all over. There is no more warning than when the esc kicks off. One second you are flying and 4 sec later its dead stick.
FYI
Dave
DaveW is offline Find More Posts by DaveW
Old Mar 20, 2002, 08:46 AM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
I'm reviving this thread...
I also want to use a seperate Rx battery pack with a kontronik "sun 4001" esc. I sent an e-mail to kontronik asking how to do it, their service is always excellent and here is the response I got :
"Put a seperate battery pack into the receiver and don't disconnect anything".
that's what I intend to do (I won't be cutting any wires...).
Dean, what did you end up doing ?
oded mazor is offline Find More Posts by oded mazor
Discussion BEC or seperate Rx Batt pack GNieuwoudt High Performance 8 Dec 11, 2006 07:09 AM
Can I use ESC+ 2S1P lipos as RX batt....? C-MIC Radios 3 Nov 04, 2004 01:04 PM
FS- New Hitec Neon Tx with Rx crystal for GWS pico or Naro Rx- also some new ESC's FS Etonic Aircraft - Electric - Airplanes (FS/W) 0 Sep 14, 2003 11:31 AM
FS: Parkhawk Ornithopter (with servos, esc, Rx, batt)) sgil2001 Aircraft - Electric - Airplanes (FS/W) 1 Sep 08, 2002 01:49 PM
How many servos can I use with a Pixie 20 ESC? try2fly Foamies (Kits) 3 Feb 15, 2002 03:43 PM
