Old Sep 04, 2012, 06:40 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Gear position and ground-loops on a tail-dragger
Fokker D-VII set up with a tail-wheel, vicious ground loop tendency, one problem is the tail wheel gear is too flexible, fixing that, but also see the main gear is a bit farther forwards than spec.
I suspect the further forward the gear the greater the moment arm, and so the greater the ground-loop tendency.
Anyone have any idea just *how* great the sensitivity is?
CNY_Dave is offline Find More Posts by CNY_Dave
Old Sep 04, 2012, 07:49 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Depends on the model, its size and weight and lots of factors, but having the gear too far forward does exactly what you mention......gives a greater moment arm between the CG and the wheels.
With a scale model you are sort of limited to the scale gear location unless you as going sport scale and then you can tweak it as desired.
One old rule of thumb that usually gets it close is to look straight down on the model from above. The axles of the landing gear need to be pretty much directly below the leading edge of the wing, or perhaps a touch further back...but not further forward. Models that have a very large deck angle do cause exceptions to this rule......
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Sep 05, 2012, 05:28 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
All the above is great advice, but if you can't do anything about the gear position there are a few things you can do with radio setup and flying style that might help...
  • Be pedantic about taking off exactly into wind - any slight crosswind will exascerbate your problems keeping it straight.
  • Reduce your ruddder rates for takeoff, and increase rudder expo;
  • Throttle up slow and smooth, and don't use full power until your wheels are off - with a model like that I'd have thought nice scale takeoffs were possible with 1/2 - 2/3 throttle.
Best of luck!
MattyB is offline Find More Posts by MattyB
Old Sep 05, 2012, 07:29 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yep, gear too far forward is generally sighted as being a bad thing for ground looping so I'd say dont put it any further forward than the scale location. Narrow set gear is another red flag, as is long landing gear... the DVII probably has all of these things.
You might try toe'ing the wheels out. This is a sensative subject with some swearing by toe-in and some by toe-out. In truth i dont think there is one solution that fits all but for narrow track taildragers I think toe-out works best, maybe worth a try if you can do it easily?
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Sep 05, 2012, 09:32 AM
CNY_Dave is offline
Joined Sep 2010
Thanks.
The gear is actually forwards of the proper install location, I realized this when I saw the front-most screws poking through the floor just in front of the wood block for the screws. Just another thing on this that wasn't done *quite* right.
So between the better tail wheel and moving the gear back a bit I have hopes the ground handling will be a little improved, anyway.
Old Sep 05, 2012, 10:19 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
I believe that you'd want to toe the wheels IN to reduce sensitivity. It's why production cars all have front wheel toe IN...When I was auto crossing my Miata I had a tad of toe OUT in the setup and talk about quick responsive handling. Think turn and it was half way through the turn before you could blink...Terrible for trying to drive straight down the freeway, so I had it removed to 0...
rtbates is offline Find More Posts by rtbates
Old Sep 05, 2012, 10:28 AM
Leadchucker is online now
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Matty B has some of the answer I had a Stearman that was all wobbly on take off and adding 30% expo cured the problem.Once the plane started going astray, counteracting with too much rudder authority only made it worse The it would go too far the other way and counteracting that with too much rudder just made things even worse. I wouldn't reduce the rudder throw though as it affects ground handing turn circle diameter which could get quite large.
If your TX is capable you could add in some throttel/rudder mix to calm her down. The aboce tip on wheel alignment is good too with just a touch of toe in, toe out will make for a mean handling plane on take off generally.
Other than that,not much you can do with scale gear placement as mentioned above, if you want the look you have to go another route.
Leadchucker is online now Find More Posts by Leadchucker
Old Sep 05, 2012, 10:49 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Increase the height of the tail skid/wheel to lower the nose . Wheel axles lined up with wing leading edge . Moderate toe in. Up elevator to keep tail skid on ground during start of take off run. Release elevator when rolling faster to let tail rise and steer with GENTLE nudges of rudder anticipating tail swing and torquing to the left. Take off at 3/4 throttle or less and gain altitude slowly before turning using coordinated ailerons and rudder. I use aileron/rudder mix most of the time. Real WWI bipes had guys running along holdiing onto wing tips to help prevent ground looping. Model will have less ground looping when taking off from grass if grass is short and smooth.
E-Challenged is online now Find More Posts by E-Challenged
Old Sep 05, 2012, 12:59 PM
CNY_Dave is offline
Joined Sep 2010
Takeoff is actually not much of a problem. It gets the tail up and starts flying fast enough that ground looping isn't an issue, although if I get the tail up too quickly the gyroscopic precession will turn it 90 degrees pretty quickly.
If I can get it to not ground loop during landing rollout I'll be a happy camper.
I went with a bit of toe-in already, but the too-wimpy tail gear is just flopping about, have a better unit in hand and ready to go on.
Old Sep 05, 2012, 01:27 PM
Aberdeen
Joined Mar 2006
As i said toe-in and out is a controversial subject but suffice to say there is some good science that says that toe out should work with a narrow track taildragger (the physics is different from a car!).. All I'm saying is it may be worth a try, you have tried toe in and it's not helped so.. might be worth considering?
Old Sep 05, 2012, 01:42 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Most of the full scale pilots I know think a little toe out is the way to go.
Discussion of why toe out is a defendable and desireable setup on a taildragger:
http://www.homebuiltairplanes.com/fo...technique.html
Old Sep 05, 2012, 06:25 PM
CNY_Dave is offline
Joined Sep 2010
Toe-in and toe-out may be an impossible conversation to have rationally without also discussing camber.
Also, on a full-scale there may be very important considerations relating to geometry changes as weight is applied, suspension movement during weight shift, and lateral and fore-aft movement of the contact patch (that last could drastically affect the effective caster).
I could see depending on the plane, and on a model, where one or the other could be the better, depending on which effect was greater or more important. It could well be what makes for better handling with no cross-wind works opposite what makes better handling with a cross-wind.
One could analyze the situation as a car being set up with negative caster, and if a car with positive caster is more stable with toe-in, maybe a car with negative caster might be more stable with toe-out.
I'm a nut about getting a good landing, so if I don't get good results with toe-in I will certainly try neutral and toe-out.
It seems this could be a downwind-faster-than-the-wind / will-the-plane-takeoff-from-a-treadmill scale discussion!
Dave
Old Sep 05, 2012, 07:42 PM
mrittinger is online now
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Try flying from grass, and slowly advancing the power.
My Top Dawg is crazy on the pavement, but a pussycat from grass.
I think the toe-in toe-out thing depends on the model. My Super Sportwin likes a degree of toe in, others like a little toe-out. Time to experiment
Mark
mrittinger is online now Find More Posts by mrittinger
Old Sep 05, 2012, 07:51 PM
eagle1960 is offline
Find More Posts by eagle1960
United States, TN, Johnson City
Joined Jul 2011
Mark
My experience, exactly. It depends on the plane. Experiment to see what works best, if you can.
eagle1960 is offline Find More Posts by eagle1960
Old Sep 05, 2012, 07:57 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Camber is a variable on models with flexible landing gear...Spring steel, bungees like a Cub, etc. It is one thing when lightly loaded at touchdown with the wing still flying somewhat., different at rest and different again if you make a hard arrival and load the gear with more than one G..
Discussion Seeking Larger Docile Flyer ARF/RTF Foam Tail Dragger - Ideas? itsme2 Electric Plane Talk 4 Aug 15, 2012 10:21 PM
Discussion Landing a tail dragger? electricrc68 Electric Plane Talk 17 Jul 18, 2012 12:02 AM
Discussion Tail Dragger or Tricycle Gear????? RC Trainer plane Electric Plane Talk 23 Apr 27, 2012 11:36 AM
Question Best Angle for a Tail Dragger to Sit on the Ground ? Chophop Electric Plane Talk 21 Nov 16, 2010 06:48 PM
Discussion Tail-Dragger Ground-Handling NChronister Electric Warbirds 8 May 04, 2009 07:27 PM
