Old Nov 26, 2012, 10:22 PM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
Canopy
Not feeling like reinventing the wheel I set about installing the canopy in my usual way. First I built a simple frame, used kitchen wrap to keep the glue from sticking to the fuselage...
Sheeting is glued to the frame...
Second layer of sheeting, the lamination should help maintain the curved shape...
Sanded flush...
A clearer view of the sub-frame...
A coat of gray paint & on goes the soda-bottle canopy...
She's looking kinda sexy...
Time once again to let the glue dry.
Nodd is offline Find More Posts by Nodd
Old Nov 27, 2012, 09:42 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
I got a few odds & ends done today... Trimmed the excess plastic from the canopy. Scared myself silly drilling a hole up through the pod to the wing-saddle for the wing's servo wires, turned out okay. Performed a balance test to see how much weight I have to play with for the tail.
Y-Tail
After some thought I think I'm going to stick with a V-tail for this bird but I'll be adding a small sub-fin effectively making this a Y-tail, fun fun...
Once again I used the sailplane V-tail calculator from tailwindgliders.com to figure out the tail sizing & geometry. And before anyone starts worrying about the V-tail angle, that'll be set at the usual 110°.
I thought about adding a small rudder to the sub-fin but that'd take another servo & require an extra channel which my DX7s doesn't have. Would have been cool & an interesting mix with the V-tail's ruddervators but there's really no need for a rudder. I'll get to designing the tail's structure tomorrow.
Old Dec 01, 2012, 01:47 AM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
After some more CAD work I printed up a set of ribs for the tail...
I plan to use dowel for the tail's leading edge hence the curvy bits...
Rough cutting using the scroll-saw...
Pile-o-riblets...
Sanded to shape using the belt-sander...
Printed up a set of plans...
I'm using a thin strip of carbon-fiber to stiffen up the tail's main-spar...
Glued the carbon-fiber to the spars...
Time to start putting this together...
Everything was going great until I looked up at the clock. Doh' it's 1am, time to call it a day...
I expect I'll get these finished up tomorrow, I'm off to bed Zzzzzz...
Old Dec 01, 2012, 11:33 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Picking right up were we left off yesterday, setting up the dowel leading edge...
More progress...
Here's some pieces that'll makeup the root area. Going to layer balsa - light ply - balsa...
Root area built up & reinforced...
When I did my balance test the other day it took 4 oz on the tail-boom to make her sit level. It looks like we're well within limits so far...
Added some fancy tips...
Seeing what she looks like...
This tail feels sooo much stronger than the original, loving those diagonal ribs.
Old Dec 02, 2012, 02:58 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
could yah repost the last pic Cause it isnt coming up But Im Drolling over this...
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 02, 2012, 06:03 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
I think the problem is on your end 3D.
If you're using a PC to view this try holding down shift while clicking on the browser's reload button. That should force your browser to purge its cashe & reload all the photos. If that doesn't work, the last photo can be found here...
http://www.scipie.com/rc/vee-gull/20121202_0076.jpg
Old Dec 02, 2012, 08:56 PM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Very nice. Looking forward to final weigh-in and maiden flight.
It's been several years since I did a built-up plane....several. Feel the urge pulling me out of the foam shavings.
sawman is offline Find More Posts by sawman
Old Dec 03, 2012, 12:34 AM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Yeah go for it sawman. I like messing around with foam too but there's something special about a wood build.
More overly engineered fun...
I've been thinking about how much abuse my sub-fin is likely to take during landing, especially if I catch a wing-tip & the tail hits sideways...
I've decided to build in a little insurance, a sub-fin that'll bend instead of brake...
As you can see its made from two pieces of ply. Holding them together will be some coat-hanger wire. It's soft enough to bend if she hits hard, hopefully absorbing the impact instead of just snapping off...
I layered carbon-fiber either side then drilled holes...
Some Kevlar thread & plenty of epoxy holds the wire in place...
Added light balsa on the sides to hide the uglies...
That takes care of that, next is the lower fin part...
More carbon-fiber, mostly to keep the wire in place but also for ding protection...
Sanded the other piece to a nice smooth shape...
More progress on the sub-fin...
Test fit. Note I added a slight bevel where the two pieces join. Like a rudder's hinge, this should allow the fin to bend if need be...
Well that was fun...
Old Dec 04, 2012, 10:38 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
wow,yeh thats all i can say
FASTBEN is offline Find More Posts by FASTBEN
Old Dec 06, 2012, 09:01 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Time for another balance test
All this stuff needs to fit in there...
Yes! It fits...
Slung the tail over the boom & stuck her up on the balance stand. It looks like we're a tad nose heavy...
I'm okay with nose heavy at this point. The tail still needs to be glued on there & covered, push-rods & other hardware added, that'll all add weight to the tail.
110°
Happy with the balance I set up a jig & started gluing the V-tail in place...
Lots of measuring, eye-balling & more measuring...
Added a strip of heavy glass cloth...
I'll let this setup over-night, should be able to get the sub-fin on there tomorrow & finish up the glass reinforcements...
Old Dec 06, 2012, 09:51 PM
ScottSails is online now
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Work of art sir!
Well done.
Scott
ScottSails is online now Find More Posts by ScottSails
Old Dec 08, 2012, 01:22 AM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Thank you Scott. Hopefully she'll fly pretty too.
Time to turn this V-tail into a Y-tail...
Added some feather-light 3/4oz glass...
Yeap that's one odd looking tail alright...
I need to mount up the ruddervators still but we have a tail... yay!
Old Dec 08, 2012, 03:28 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Airframe complete!
Time to stand back & take a look...
There's still plenty to do so back to the workshop...
Old Dec 09, 2012, 01:22 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
Nodd very nice can't wait to see a vid.
man you are good.
Ben
Old Dec 12, 2012, 08:48 AM
PlayinInTheParK is offline
Find More Posts by PlayinInTheParK
less sleep more planes
PlayinInTheParK's Avatar
Australia, QLD, Brisbane
Joined Sep 2006
The land of Nod is a weird and wonderful place ,congrats great work.
PlayinInTheParK is offline Find More Posts by PlayinInTheParK
Build Log Scratch Designed/Built Sailplane Nodd Electric Sailplanes 198 Oct 08, 2012 10:30 PM
Build Log Designing for scratch-built FPV wing... PiperCub49 Flying Wings 15 Mar 09, 2012 10:15 PM
Slightly OT but i need help for a scratch built heli fuselage meatbomber Foamies (Kits) 4 Nov 04, 2004 11:53 AM
Spirit scratch built fuselage NW Boiler Thermal 3 May 26, 2004 08:56 PM
Scratch built fuselage erik1938 The Builders Workshop 3 May 17, 2004 10:52 PM
