Old Feb 22, 2013, 07:06 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
excellent mod! the 60-120's work great!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Feb 22, 2013, 09:23 AM
Paul Swy is offline
Find More Posts by Paul Swy
Paul Swy's Avatar
United States, CA, Petaluma
Joined Apr 2007
Blue xXx
Thanks Billy,
Arrived in perfect condition. My 4th JTM and the quality is superb ! Everything fits soooo.... tight and looks true. Also thanks for all your engineering on the new Tam Trunions for the 60-120's - much appreciated by all I'm sure.
The mystery of the odd sized inlet duct has been solved - see pic - fits "Like A Glove" - dry fit right out of the box. No grinding or sanding. This is also so tight fitting that I could literally get a flight out of it with a few drops of CA in the right places. Just need to drill a few holes, add some blind nuts, and glue the rails in - done ! Again - just wanted to say how impressed I am with the quality of the workmanship coming from JTM - Thank You Andy.
Paul
Paul Swy is offline Find More Posts by Paul Swy
Old Feb 22, 2013, 10:03 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I like the blue the best... very sharp!
Ron101 is offline Find More Posts by Ron101
Old Feb 22, 2013, 10:28 AM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
I actually would have preferred the Red - but too many red/white jets already, and I wanted an off color so I won't get it confused in the air with my buddies red/white Electra. He got his Electra 3 weeks ago - so were about even with build progress - Ha, Ha,
Old Feb 22, 2013, 10:33 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
+1
Samjet is offline Find More Posts by Samjet
Old Feb 22, 2013, 12:11 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Paul nice combo. The blue looks very nice.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Feb 22, 2013, 01:57 PM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Anyone else think it looks "Sparkish"
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Feb 22, 2013, 02:18 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
I can see some Spark in it, Nose reminds me of the Bu 32 - What do you guys think about putting some anhedral in the horizontal stab ? First thing I noticed when I fit it up is that the wings and stab are almost in line, maybe a half of an inch stagger. It would mean some body work and could compromise the integritiy of the mounting. Probably a mod best left to later on down the road when we see how she flies.
Old Feb 22, 2013, 02:41 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Steve.
I think I see a little Bandit in the pedigree
MCSGUY is offline Find More Posts by MCSGUY
Old Feb 22, 2013, 02:54 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
Bandit in the mix for sure - but still very much it's own design - not a copy. Well thought out design when you look at the interior.
Old Feb 22, 2013, 03:50 PM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
New progress report, I have got the fan adapter finished and fan is now sitting in the plane with the inlet duct all wrapped up, it needed just a little bit of sanding for a perfect fit. Another job that is done is the battery mount, it took me a while to figure out how to do this, as I wanted it to be quick and easy to get the packs in and out of the jet. My two main packs will be strapped to the plywood plate, and I just have to remove the two bolts to get the whole assembly out, the plate has a tongue at the rear that slots into the plywood former that's glued in at the back between the ducts.
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Old Feb 22, 2013, 03:59 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Your welcome.... That Schübeler fits nice in there!! I also like the blue one.. I'm building the 1.7 Viper in the same color blue right now
On the Trunions for the 60-120's they will be UsaRcJets. Tam will be making the strut's,wheels and brakes.
Originally Posted by Paul Swy View Post
Thanks Billy,
Paul
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Feb 22, 2013, 04:21 PM
Senior Member
Molde, Norway
Joined Jan 2001
Last two pics is for Billy, this is how I plan to run 14S in the xXx, with a 2S pack on top of the ducts right on CG.
Old Feb 22, 2013, 05:00 PM
jetmodeler is offline
Find More Posts by jetmodeler
Flying for Fun
United States, OH, Warren
Joined Aug 2007
With all the xXx's out now I guess I won't have the fastest xXx, wow 14 cell setup, that can have potential to really kick. Saw Paul's comment on anhedral in the stabs, man don't do it, pain in the but everytime you set the fuselage down. I haven't seen any difference between my xXx and any other similar jet that does have anhedral, pitch response is very good and precise, even with the flaps down so I don't think it will have any improvements in handling.
jetmodeler is offline Find More Posts by jetmodeler
Old Feb 22, 2013, 05:08 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
Thanks for that - sure don't want to do it if it's not necessary.
Arngeir - nice fiberglass work on your duct. looks like you'll be flying soon.
Billy sorry for the way I made that sound - I meant Trunions that will allow fit up of Tam Struts. I'm assuming that's the reason for the mod. I've always had to grind a portion of the strut to get them to fit on standard E-Flights.
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1958 May 14, 2016 07:45 PM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
Discussion FoamEdge by Billy Haynes Billy Haynes Foamies (Scratchbuilt) 27 Apr 29, 2009 11:52 PM
D.O.G.S. Coverage from Billy Hell RC and RC Groups Jim T. Graham Fuel Power Events 33 Sep 13, 2005 07:31 PM
