Old Feb 17, 2013, 12:22 AM
Its a Condition not Addiction
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
Originally Posted by Michael Paxton View Post
I would love to see how you guys do that!
Here are some pics i took during the install of the flaps
Jamez
lashmett75 is offline Find More Posts by lashmett75
Old Feb 17, 2013, 02:41 PM
I need more power Scotty!!!
MCSGUY's Avatar
Joined Feb 2010
Now I'm glad I got pulled off my build while moving, gives me a chance to come back and see how it's supposed to be done. I think your servo mounting technique is brilliant Arngeir, elegant and solid. You don't see the need for the balsa reinforcement on the elevator horn Andy referred to?
Nice treatment on the flaps Jamez, thanks for the pics.
Joe
MCSGUY is offline Find More Posts by MCSGUY
Old Feb 17, 2013, 03:02 PM
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
There is a balsablock already inside the control surfaces, so as long as you install the horns in the correct place (where JTM has put the balsa) you will have no problems, I have done ailerons and the rudder so far and on all three I found balsa inside when drilling the slot for the fiberglass horn. On the elevator this block covers the inner 35mm according to the info given earlier in the thread by Andy at JTM, and the linkage will end something like 20mm from the inside edge so that should land it almost in the middle of the balsablock.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Feb 17, 2013, 03:38 PM
MCSGUY's Avatar
Joined Feb 2010
Thanks! That tells me I can extend the reinforcement out to where I placed the control horn and get by with that location. I misunderstood Andy in that I thought he meant we had to add something he omitted. If I had it to do over again I would copy your approach entirely.
Old Feb 17, 2013, 04:05 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
Jamez thanks for sharing, I though it seemed simple but why would you not do at the location of the flap servo?
hoser is offline Find More Posts by hoser
Old Feb 17, 2013, 04:15 PM
Senior Member
Molde, Norway
Joined Jan 2001
I am more wondering about if he has room for landing gear, I could not mount a servo in that position as it would hit the actuator on my gear.
Old Feb 17, 2013, 05:13 PM
shut up & fly
hoser's Avatar
Joined May 2001
my concern also
Old Feb 17, 2013, 09:03 PM
lashmett75's Avatar
Joined Jul 2008
Originally Posted by hoser View Post
my concern also
It would be....but Tam and I reversed the gear operation and the motor for the eflite electric gear goes into the wing and not the gear pocket. I will get some pics for you guys tomorrow. reason why I didnt use the factory hole for internal linked flaps was because the hole needed would cause an integrity issue with the spar. So moving the flap servo to our new location allows the hole to be made in the spare with "meat" on top and bottom.
James
Old Feb 18, 2013, 12:00 AM
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Jamez
Thank you. That looks Sweet!!
Michael Paxton is online now Find More Posts by Michael Paxton
Old Feb 18, 2013, 09:17 AM
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
James
That's what I was thinking when I was looking at the flaps.....there wasn't enough meat on the spar to make an internal linkage at the stock flap location.
swps is offline Find More Posts by swps
Old Feb 18, 2013, 04:59 PM
Senior Member
Molde, Norway
Joined Jan 2001
Got the plug for my inlet adapter made up yesterday, and finished off with 3 layers of wax last night, then it was ready for a coat of PVA first thing today. Layup is two layers of 163g/m2, should be strong enough I think. Front end will go outside the inlet ducts, while the back end is inserted into the front of the Ramtec shroud which has a step for the duct to sit in.
Old Feb 18, 2013, 07:05 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
nice work arngeir
stoneenforcer is offline Find More Posts by stoneenforcer
Old Feb 18, 2013, 07:23 PM
Senior Member
Molde, Norway
Joined Jan 2001
Thanks, I hope it fits well, my plan is to apply a thin bead of silicone on either end when doing final assembly to seal it up and to help with resonance, the Ramtec fan has rubber isolated mounts so it makes sense to add some silicone to the duct as well, that's what was normal practise back in the GDF days at least.
Old Feb 18, 2013, 08:58 PM
High Dynamic Thrust
Joined Feb 2007
a band or two of carbon on the adaptor to prevent static implosion ?
Old Feb 18, 2013, 09:02 PM
Senior Member
Molde, Norway
Joined Jan 2001
I thought about that and will see how strong it is when I pop it off the plug tomorrow, if it feels a bit flexible a wrap or two with carbon tow is quick and easy to add the the rear end.
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1076 Today 09:21 PM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
Discussion FoamEdge by Billy Haynes Billy Haynes Foamies (Scratchbuilt) 27 Apr 29, 2009 11:52 PM
D.O.G.S. Coverage from Billy Hell RC and RC Groups Jim T. Graham Fuel Power Events 33 Sep 13, 2005 07:31 PM
