Old Feb 13, 2013, 10:28 AM
easy jets is offline
Find More Posts by easy jets
easy jets's Avatar
Germany, NRW, Gangelt
Joined Jan 2011
Good question!!
That is a very good question Arngeir.
The Ailerons only have one option... WING END
My gut feeling tels me root of the wing for the flaps but..
Your question is already in China.
Stay tuned,
Cliff
easy jets is offline Find More Posts by easy jets
Old Feb 13, 2013, 11:39 AM
Paul Swy is offline
Find More Posts by Paul Swy
Paul Swy's Avatar
United States, CA, Petaluma
Joined Apr 2007
Billy - Thanks for the tip on fan location. ESC if not mounted in motor fairing, should probably be mounted way back too ?
Paul Swy is offline Find More Posts by Paul Swy
Old Feb 13, 2013, 11:47 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I guess so, I will be using a YEP 180HV so I'm not sure if it will fit in my motor fairing, it is most likely too long. If it does not it will go on top of the duct just in front of the fan unit. I may add a couple of small NACA ducts on either side just behind the cockpit to feed it with fresh air if that is the location I end up with.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Feb 13, 2013, 12:37 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
I have to mount external to the motor fairing too, and was thinking about putting it in the same place. Let me know what you come up with for some additional cooling ducts. the NACA ducts sound like the way to go. I was also considering cutting a rectangle in the bottom of the belly just below the fan and letting the heatsink portion of the ESC protrude out the bottom - but I think there will be access and mounting issues putting it there.
Old Feb 13, 2013, 12:41 PM
Senior Member
Molde, Norway
Joined Jan 2001
Access to the belly under the duct is ok as long as you open up the wing root of the fuselage, I cut open mine and used a Dremel sanding drum to make the holes follow the plywood rib glued to the inside of the fuselage.
Old Feb 13, 2013, 12:46 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
mmm
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Feb 13, 2013, 12:52 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
Yes, I think I can see them in one of your pics - kind of an oval slot ? Sounds like you are saying that you didn't cut into the root rib, just removed the outer skin to match an existing slot in the root rib ?
Old Feb 13, 2013, 12:58 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
ive snapped em pretty fast on my spark. well over 100 but not 150. ive seen pablo do some freaky snap moving really fast with an electra.
Originally Posted by jfetter View Post
This is the fastest snap I've ever seen from a jet, check out the 2:00 minute mark, perhaps 125+ MPH give or take?
BVM Electra 3, Windows Media, High Definition, 171MB
Jack
nice vid!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Feb 13, 2013, 12:59 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
Any BLUE xXx sightings ?
Old Feb 13, 2013, 02:04 PM
Senior Member
Molde, Norway
Joined Jan 2001
Yep, that's what I did. Here is a pic for you as well.
Old Feb 14, 2013, 10:39 AM
Senior Member
Molde, Norway
Joined Jan 2001
I have also started installing retracts, I had a set of Electron ER-40's I wanted to use, unfortunately this meant I had to grind and sand a bit on the mounting rails and the door opening to get them to fit properly. But I got one done now, so the other one will be easier as I know what to do. The only thing I'm not 100% satisfied with is that I had to grind down the 2mm fiberglass reinforcement on the retracts mounts to be able to get the retract and leg to fit under the wheel doors, but it was either that or not getting the doors to fit properly.
I also want to avoid air systems in this plane, so I was thinking about using LADO E-Doors for the doors, these are a bit large but it looks like there's just enough room to fit one in front of the wheel so I will give them a try. I also plan to use Robart 7/16" struts, and I had to cut these down as much as I could to get them short enough to fit, but it looks like it will turn out ok. Wheels will be 66mm Intairco for the mains, and a 57mm nosewheel.
Old Feb 14, 2013, 11:37 AM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
That looks great. Fits nice. I like the fact that the wheel retracts into the wing rather than fuse. Will make it easier to assemble and disassemble at the field. Have you decided on a sequencer for the gear/doors ? Hobbyking sells a $14 unit that works great and is really easy to program. Can't remember the brand off hand though.
Old Feb 14, 2013, 12:57 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Here is the sequencer for the gear/doors That i use. It works great ...
http://www.usarcjets.com/cgi-bin/sho...20-%20Upgrades
Old Feb 14, 2013, 01:12 PM
Paul Swy is offline
Paul Swy's Avatar
Joined Apr 2007
That's the one - Assan. Been using it in my small JTM Viper and it's been flawless. Really like the way you can control the speed, delay and travel on each servo. I "y" the two main doors together as you can only control 3 outputs. Gear, Door1, Door2. This requires one reversed servo, or non-symetrical servo mounting for the main doors.
Old Feb 14, 2013, 01:23 PM
Senior Member
Molde, Norway
Joined Jan 2001
You don't need a sequencer with the Lado E-Doors, you program them with a Lado programmer, you can can set delays and if they are to close again or stay open after gear cycling with that so they just plug into the retract channel with a Y-connector. At least that is what their website says, so I hope it is that easy.
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1954 Feb 14, 2016 10:53 AM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
Discussion FoamEdge by Billy Haynes Billy Haynes Foamies (Scratchbuilt) 27 Apr 29, 2009 11:52 PM
D.O.G.S. Coverage from Billy Hell RC and RC Groups Jim T. Graham Fuel Power Events 33 Sep 13, 2005 07:31 PM
