Old Jan 25, 2013, 06:55 PM
I need more power Scotty!!!
MCSGUY's Avatar
Joined Feb 2010
16.5 to be exact
MCSGUY is offline Find More Posts by MCSGUY
Old Jan 25, 2013, 07:19 PM
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
Originally Posted by MCSGUY View Post
16.5 to be exact
Awesome thanks!! Can you give me a measurement on the nose gear steering?
swps is offline Find More Posts by swps
Old Jan 25, 2013, 07:26 PM
MCSGUY's Avatar
Joined Feb 2010
If I would have started my opening 1/8" closer to the trailing edge I would have missed the dowell block completely. If you keep below 73.75 from the TE you will miss it. Stay above 26.5 and you will miss the lower spar.
MCSGUY's Avatar
Joined Feb 2010
When I get there (unless you can be more specific)
Old Jan 26, 2013, 06:00 AM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
How much skin strength do you think is compromised by cutting that chunk out of the surface, looks to be rohacell? A laminate servo cover frame would ad strength back. I usually tape off the surface then layout the opening , score it with a blade a few times until it slices through, it looks like a mouse got a hold of them edges man!
ApexAero is offline Find More Posts by ApexAero
Old Jan 26, 2013, 06:36 AM
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I'd rather make a cutout in the root rib and mount the servo through it, then you'd only need a small slot for the servo arm to poke through the surface.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 26, 2013, 07:19 AM
ApexAero's Avatar
Joined Aug 2008
You know you're right, that or possibly better, the same thing but directly through the fuse root contact, looks like there is enough room down under and next to the efflux pipe area within the elevator fairing, then your surface slots just slip over the exposed horn during installation.
Old Jan 26, 2013, 09:08 AM
Mile High EDF
United States, CO, Denver
Joined Jul 2011
If my 84 RX7 sells today I'm in
420flyboy is offline Find More Posts by 420flyboy
Old Jan 26, 2013, 01:09 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
ok ordered, get ready for killer fuzz 2
hoser is offline Find More Posts by hoser
Old Jan 26, 2013, 01:12 PM
Team Futaba
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Good for you dude! Now bring it to the Bluegrass EDF jet jam in september now that it is closer to you
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jan 26, 2013, 01:30 PM
MCSGUY's Avatar
Joined Feb 2010
Yeah it does, a real tiny mouse . Thanks for the tip, I wasn't sure about the properties of the material when I started cutting, I figured I'd do a little refinishing, I like your way much better. For strength I plan to bond a thin square piece of CF under the servo mounting posts and frame the opening so the doctored piece I removed will be screwed back in place. The strength will be more then adequate.
Old Jan 26, 2013, 01:37 PM
MCSGUY's Avatar
Joined Feb 2010
That would be the ideal solution IMO. Pretty tight working conditions, not sure if I would attempt it unless I saw an example first.
Old Jan 26, 2013, 01:53 PM
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I see one of these in my future. However distant that may be since I'm still building my Sniper XL.......(Wish I weren't)
Michael Paxton is online now Find More Posts by Michael Paxton
Old Jan 26, 2013, 02:43 PM
MCSGUY's Avatar
Joined Feb 2010
Is that new name for the one we'll be attending in Kentucky? "Bluegrass EDF jet jam", I like it
Old Jan 26, 2013, 03:10 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I like the name TOO So Bob, I take it you will be getting a Bluegrass band to play at the pilot's Dinner??
BILLYDSRC is online now Find More Posts by BILLYDSRC
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1071 Yesterday 11:26 AM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
Discussion FoamEdge by Billy Haynes Billy Haynes Foamies (Scratchbuilt) 27 Apr 29, 2009 11:52 PM
D.O.G.S. Coverage from Billy Hell RC and RC Groups Jim T. Graham Fuel Power Events 33 Sep 13, 2005 07:31 PM
