Old Jan 17, 2013, 08:54 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Sorry Arngeir it took me so long..Thanks Billy D
Originally Posted by Arngeir Blakseth View Post
I found a pair of Futaba 3150's with mounts in a drawer in my workshop so I will use those either on elevators or ailerons. I also found a Hitec 5245 which can be used for nosegear steering.
So Billy, can you confirm that there is room for a 5" fan, I am starting to really like the idea of using my Ramtec since I already have a set of Hyperion packs to use with it, plus I can add a 2S as a booster pack to run 14S when I feel the need for speed
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Jan 17, 2013, 09:11 PM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
120mm adaptor will work perfect with the BVM EVF.
swps is offline Find More Posts by swps
Old Jan 17, 2013, 11:00 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
I believe the Ramtec and the Dynamax are the same body size? If so the Dynamax Pro fits into the fuse and plywood cradle well. However the largest adapter will need to be spread about 1/4" to go around the fan or some method otherwise found to accomodate what is essentially a butt joint fit
MCSGUY is offline Find More Posts by MCSGUY
Old Jan 17, 2013, 11:44 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
JTM xXx Rc Sport Jet by: USArcJets.com (3 min 15 sec)
Old Jan 17, 2013, 11:57 PM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Nice video, time to start saving the pennies
cquian is online now Find More Posts by cquian
Old Jan 18, 2013, 12:36 AM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Excellent! I need to find some 6800mah batteries. Now that XPS isn't selling them I'm not sure where to go for that particular capacity. Any suggestions?
Old Jan 18, 2013, 02:29 AM
Parakos is offline
Find More Posts by Parakos
Addicted
Parakos's Avatar
Stockholm, Sweden
Joined May 2010
Thanks for the vid BillyD! Would really appreciate if you could do a simular video of the new 1.8m Viperjet also.
Parakos is offline Find More Posts by Parakos
Old Jan 18, 2013, 04:44 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Thanks Billy, video was nice as well.
ID on the Dynamax and Ramtec is the same, but the Ramtec is slightly larger in OD, I have both so I tried to fit my Ramtec into the inlet duct I made for my Dynamax powered MiG-15 once, it did not fit. Both fans however are setup the same way, the inlet duct should have the same ID as the fan and slip inside the front of the shroud, on the Ramtec there is a step in the shroud for the duct to sit in, the Dynamax has a taper that will serve the same purpose.
I'll have to get my kit first, but I do have a plan for how I want to do the inlet/fan fit, I will snap some pics and post up once we get there.
Hyperion have 35C 6500mAh's, Thunderpower have 6600mAh's and those two are roughly the same weight as the XPS 6800's. Neu have some 8300mAh's, they are only 100grams more for a 6S pack so the energy density is higher on those cells than the others, you would end up 200grams (7oz.) heavier on a 12S setup but the flight time will be much longer.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 18, 2013, 07:03 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
really a good looking jet! love the ARF finish!!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Jan 18, 2013, 08:11 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Coming Soon.. Please say tuned
Old Jan 18, 2013, 08:39 AM
swps is offline
swps's Avatar
Joined Jun 2010
Where are the batteries for CoG? Doesn't look like there there is room for saddle packs.
Old Jan 18, 2013, 11:01 AM
Senior Member
Molde, Norway
Joined Jan 2001
No need for saddle packs, batteries go in front between the inlets, lots of room there.
Old Jan 18, 2013, 11:12 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
How would 100mm stumax do in this? Would there be to much drag from intakes?
Doug Bateman is offline Find More Posts by Doug Bateman
Old Jan 18, 2013, 11:29 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I would say a 100mm would fly it but not to good.
Old Jan 18, 2013, 12:40 PM
Paul Swy is offline
Find More Posts by Paul Swy
Paul Swy's Avatar
United States, CA, Petaluma
Joined Apr 2007
Cool Video - Thanks Billy - Can't wait for it to show up on my doorstep. I ordered Blue - any ETA on those ?
Paul Swy is offline Find More Posts by Paul Swy
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1958 May 14, 2016 07:45 PM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
Discussion FoamEdge by Billy Haynes Billy Haynes Foamies (Scratchbuilt) 27 Apr 29, 2009 11:52 PM
D.O.G.S. Coverage from Billy Hell RC and RC Groups Jim T. Graham Fuel Power Events 33 Sep 13, 2005 07:31 PM
