Old Sep 04, 2012, 11:58 AM
memnuts is offline
Find More Posts by memnuts
United States, NJ, Rockaway
Joined Feb 2011
Techone Mini Neptune
I was on the techone webpage and found they have something called a mini neptune. I was hopping it was a small 30mm or so edf wing but it resembles something along the lines of a Striker 180Q typ shape is has a 588mm (23+in) wing span so it is slightly larger. I searched and found nothing so far. Has anyone seen this before or is this actually new?
http://www.techonehobby.com/proinfo....=1&pid=67&st=1
memnuts is offline Find More Posts by memnuts
Old Sep 07, 2012, 03:06 AM
8thelephant is offline
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
It's actually new and some of us who are flying it's EDF big brother are awaiting to see it in the flesh.
I've been flying a Stryker 180 for a while now and am anxious to see how this compares in the air.
Servos mounted on top is a good idea and I like the fact that the wing follows the fuselage all the way up to the nose as this is a weak point for the S180. S180 is only a 17.0 in (432mm) wingspan so this would hopefully be more of a floater with 23.2 in.
Techone's site doesn't specify if it's EPO or something else....
8thelephant is offline Find More Posts by 8thelephant
Old Feb 11, 2013, 12:16 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
I just sent an email to Tech One. Has anybody heard anything about this yet? I'm not a wing owner yet and wonder if there is a comparable wing like this out there already? Being that I don't have one and am just seriously considering one, is there a recommendation on a ARF that is reasonably priced, indestructible and has a good following? I'm sure the mod bug will bite later, but want to do it in steps. Thanks.
kodak_jack is offline Find More Posts by kodak_jack
Old Mar 03, 2013, 12:39 AM
sonnydc is offline
Find More Posts by sonnydc
sonnydc's Avatar
Joined Dec 2011
check out the Wing-wing kit :
http://www.hobbyking.com/hobbyking/s...dproduct=25663
sonnydc is offline Find More Posts by sonnydc
Old Mar 03, 2013, 06:22 AM
kodak_jack's Avatar
Joined Mar 2008
The wing wing is a smaller Neptune as far as teh wing is concerned, but uses a prop and not an EDF.
Old Mar 03, 2013, 12:47 PM
sonnydc is offline
sonnydc's Avatar
Joined Dec 2011
Check out this mod thread. It uses a 50mm alloy EDF.
http://www.rcgroups.com/forums/showthread.php?t=1710798
Old Mar 03, 2013, 01:47 PM
kodak_jack's Avatar
Joined Mar 2008
Thanks. GREAT stuff!!! I thought the mini Neptune was supposed to be an EDF like its big brother?
Any problems with the ESC getting hot? As usual, the stuff comes from the International warehouse. I don't know how much I'd save on the crazy S&H if I split it up and bought the kit from the US warehouse? Did you buy the kit or the PNF version? No sense buying the PNF if you're going to toss most of it.
Old Mar 03, 2013, 11:33 PM
sonnydc is offline
sonnydc's Avatar
Joined Dec 2011
The esc stays cool even at WOT. Get the kit version. Plus the hardware as mentioned in Junglegym's blog.
For better sound and faster performance, you can upgrade to the Dr. Mad 10 blade 50mm alloy EDF (it consumes 27a max) and a 40a Plush or Blue Series ESC using the same Zippy Compact 2200mah 4s 25c battery. I also added a 3-axis gyro in my set-up.
Maybe you have seen this already? It flew at full throttle.
http://www.rcgroups.com/forums/showp...6&postcount=19
Old Mar 04, 2013, 06:06 AM
kodak_jack's Avatar
Joined Mar 2008
Great video. Is it intuitively obvious how to cut the motor housing for the EDF? How in the world do you balance the fan on one of these?
What do you use to keep the canopy on? I've read posts about guys constantly losing them.
The EDF says it's a 4S version. It'll run OK on 3S, won't it?
Old Mar 04, 2013, 12:53 PM
sonnydc is offline
sonnydc's Avatar
Joined Dec 2011
The fan is already balanced when you buy the edf unit. For mounting, you just need to cut some foam on the sides and use epoxy to glue it in place. Check out the pictures posted at Junglegym's blog as a guide. For the canopy, I just use velcro on the front and there is a snap-on clip at the back side. If still unsure you can always tape the canopy before every flight. And for the battery, you would really need the compact 4s 2200mah 25c for power and also for proper cg.
Old Mar 04, 2013, 05:51 PM
kodak_jack's Avatar
Joined Mar 2008
Everybody like the Turnigy Plush ESC's, but for some reason, they don't stock them in the US warehouse. This one is available, but I don't know how good it is:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Maybe it isn't that big a deal since the EDF would have to come from the International warehouse anyway.
Old Mar 04, 2013, 06:09 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Hobbywing Pentium ESCs are the same as the Plush. I bought my last on from eBay... http://www.ebay.com/itm/HobbyWing-Pe...item1e778a0af8
Murman is offline Find More Posts by Murman
Old Mar 04, 2013, 10:58 PM
sonnydc is offline
sonnydc's Avatar
Joined Dec 2011
You would need a separate BEC for the SS 40a. That would be fine if you have a separate BEC. The Hobbyking (Mystery) Blueseries ESC's are my favourite, are also very good and at par with the Plush.
http://www.hobbyking.com/hobbyking/s...ontroller.html
Old Mar 05, 2013, 06:18 AM
kodak_jack's Avatar
Joined Mar 2008
Thanks guys.
Old Apr 19, 2013, 02:16 PM
Soaring Fanatic!
Joined Dec 2008
Nitro has them now: http://www.nitroplanes.com/02a-705-m...arf-black.html
Still on the fence about this one; though I'm sure it performs will if it it's anything like it's big brother
Discussion Techone Neptune EDF NorCal Foamy EDFs 593 Apr 03, 2016 04:50 PM
Sold (2) TechOne Mini Eagles and Micro Flight Paks sgomes Aircraft - Electric - Power Systems (FS/W) 0 Mar 22, 2012 08:54 AM
For Sale (2) TechOne Mini Eagles and Micro Flight Paks sgomes Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 18, 2012 12:20 PM
Discussion Techone Mini Tempo 3D ve Techone Extra 300 bluemeane 3D Foamies 2 Feb 24, 2012 02:48 PM
