Old Dec 21, 2012, 01:41 AM
ForeverFlying is offline
Find More Posts by ForeverFlying
ForeverFlying's Avatar
Christiansburg, VA
Joined Sep 2002
Is the spreadsheet posted somewhere? It would sure make my life easier!
Thanks guys, good thread!
ForeverFlying is offline Find More Posts by ForeverFlying
Old Jan 11, 2013, 02:48 PM
f14tom is offline
Find More Posts by f14tom
f14tom's Avatar
United States, OH, Miamisburg
Joined Jul 2012
If you go back to Thread #9 you should see a post by vtdiy. He posted a link to the spreadsheet he made. I am reposting his link below:
http://www.rcgroups.com/forums/showthread.php?t=1625684
However, please do read his posts to understand the spreadsheet. vtdiy is very helpful; so, if you have any questions, please don't hesitate to ask him. I finally got my electronic components figured out. I am ready to build a complete cutter. I will post my results soon.
f14tom is offline Find More Posts by f14tom
Old Sep 27, 2013, 07:33 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Hi electronics gurus , I realize this is an old thread but need advice on power supply. I just bought a 5 amp 12 volt power supply to controlled with a 1000 watt dimmer . I was hoping to use mig welder wire . Not sure of the diameter but it does look thinner than say .020 . I'm not at all an electrically minded person and was hoping to get some advice on whether this will be enough power . I'm thinking of making a 3 foot bow . Will the 5 amp be enough ? I think it's Acdc current . The guy at the electronic supply said the dimmer should go on the output side on the power supply on the positive wire . Does this sound right ?
pencon is offline Find More Posts by pencon
Old Sep 27, 2013, 09:20 PM
Christiansburg, VA
Joined Sep 2002
Hot Wire Cutter
Hi Pencon!
You definately need to put the dimmer on the AC side (input) of your power supply. If your power supply does not have a transformer, then you need to get one for safety purposes (to provide isolation, to prevent shock). Here is an Instructable that is pretty good:
http://www.instructables.com/id/Hot-...tter/?ALLSTEPS
If you have trouble with the mig wire, consider this:
http://www.skykingrcproducts.com/acc.../renewire.html
If you want to simplify all of this, and make life easy and safe, consider this:
http://www.circuitspecialists.com/csi3005sm.html
I didn't have much luck with a bow cutter. This one for tapered wings, however worked pretty good for me:
Hotwire demonstration (3 min 30 sec)
Best of luck!
Old Sep 28, 2013, 12:51 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Can you provide details of exactly what "5 amp 12 volt power supply" and "1000 watt dimmer" you have ?
If it's a regulated supply putting the dimmer on the input side won't do anything.
If it's a DC supply then most dimmers will not work on the output side.
And 12V is not enough for most 3ft long bows but it does depend critically on EXACTLY what wire you're using (I've got wire of 5 different sizes and materials for my MIG welder).
Steve
slipstick is online now Find More Posts by slipstick
Old Sep 28, 2013, 05:00 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The Mig welding wire I use is .023 thou. I also use a variac
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Sep 28, 2013, 09:36 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Gord.
I started out using .023" welding wire and was happy with the results until I tried Rene wire. No comparison. Faster, cleaner cuts and a much nicer finish on the cut piece.
Granted is online now Find More Posts by Granted
Old Dec 01, 2013, 04:42 AM
wassimj is offline
Find More Posts by wassimj
Joined Jun 2012
Battery Charger + Dimmer?
Hello all,
I am looking to build a hot wire foam cutter. I am wondering if I can use the following battery charger and add a Lutron rotary dimmer to it for variable output:
Maypole 716 12A Metal Battery Charger 12/24V
Voltage: 12/24V
Current: 9/4 Amp
My wire cutter spec is as follows (used an online calculator to get the spec):
Temperature: 300 C
Length: 1200 mm (47 inches)
SGW: 22 (0.635 mm)
Volts: 15 volts
Amps: 3.62 amp
Watts: 54 Watts
Resistance per foot (OHMS): 1.055
Total Resistance: 4.176
Your help and advice is much appreciated.
wassimj is offline Find More Posts by wassimj
Old Dec 01, 2013, 05:40 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Update : guys , our sliding plank hot wire cutter didn’t work , so we got out the old HW Bow ... Stainless fishing leader wire.. Worked fine... Used the Variac (it’s what I had ) with Safety considerations... No problem ....
Here’s the finished project ... The Rolling Hanger ... Styrofoam , covered with canvas ...
Ps. the hole in the side is for the AC ...
gpw is offline Find More Posts by gpw
Old Dec 01, 2013, 05:51 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Here’s a shot inside ... Comfortable for camping (like at a Fun-Fly) , plenty room for planes ... ...the wife is , or course, texting ...
Old Dec 01, 2013, 06:12 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Beautiful job. What/how are the mainframe bows made from.
Gord.
Old Dec 01, 2013, 06:33 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
CNC cut 3/4” plywood ... Much like an old time fuselage former eh ...
Old Dec 01, 2013, 02:42 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Beautiful job. Would take a while to do on my old beater bandsaw.
Gord.
Old Dec 01, 2013, 03:50 PM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Hi Gord.
Here's a good cutter plan, complete with safety features................ http://www.utahflyers.org/index.php?...ask=view&id=37
goldguy is online now Find More Posts by goldguy
Old Dec 01, 2013, 04:01 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Just remember that though a Variac uses transformer principles it is not an isolating transformer. In other words, don't touch the wire, it could be hot, electrically as well as temperature wise. Otherwise it is a good tool for the job.
Mac50L is offline Find More Posts by Mac50L
Data Hot Wire Foam Cutter Calculator (UPDATED 7-31-2012) vtdiy The Builders Workshop 118 Jan 04, 2016 01:42 PM
Sold Hot-wire cutter variable power supply jim breese Aircraft - Sailplanes (FS/W) 1 Apr 13, 2012 12:48 AM
Question Drivers and Steppers for CNC Hot wire foam cutter sscherin CAD/CAM 1 Feb 27, 2012 03:08 PM
Question Hot Wire Foam Cutter Power Supply? Slope Lift Slope 18 Jan 15, 2006 07:29 PM
Hot wire foam cutter power supply - Electrician needed!!! CactusJackSlade Foamies (Kits) 3 Jan 19, 2003 01:53 PM
