Wing templates
I have noticed your templates are inside templates, I have cut the wing profile ribs each end, and cut on the outside of them, is there an advantage to using negative templates? |
Bow Length
I am going to do what you suggested, and fix the bow to the desk, and move the foam around it, fingers crossed the power supply will turn up tomorrow.... Cheers for all the help all....much appreciated :-) |
Guys ,I have a little foam to slice ... was planning on a slicing table/jig , with a wire stretched across the guides , and tightened by a small spring (not heated) .. Was planning on using my old Variac , but it may not have enough amps ... Only 24” wide ... Shorter wire so I might need less amps , right ???
It will work fine GPW. Just start at zero and gradually increase until you have cutting heat. You won't draw more current at cutting heat on a shorter bow if you are using a variable supply and you adjust up to the same temp. Your voltage setting will be lower than the longer bow, and the current will be about the same. All this assumes you are using the same wire on both. If not you should re-calculate.
BTW I don't like Variacs for bows for two reasons: because their output isn't isolated from the power line, and can be set at lethal voltage by mistake. Unlesss there is something limiting your adjustment knob. If you put an isolation transformer somewhere in your circuit, it would isolate it, and if you make up a physical limit to the knob it will prevent a bad setting. You don't need anything more than 24 volts on a bow. And to achieve both things at the same time, you could use a 24 volt transformer as an isolation transformer before the Variac. This will isolate it and limit its voltage to 24 V. Just make sure the 24 V transformer has an amperage rating above what you draw with your setup. |
Funny!! I had a couple of dock billots to cut and made a Rube Goldburg system to cut them. I put the foam on a piece of plywood with the same setup that you have. I tilted it up on about a 45 degree angle and looped a piece of clothsline around the back of the billot, looped it over a chair with a pair of vicegrips for weight and turned on the Variac.
By the way I do have an isolation trans. with the variac. Think I had to add a wrench to the vicegrips to get the feed speed right. I used #10 on the variac for the right heat. Sat back with a beer and watched it cut.![]() Gord. |
Naples FL USA
Joined Mar 2009
I did have an issue with the T-pins at first, just make sure that they are angled away from the core so the wire can't snag them. |
http://www.rcgroups.com/forums/showthread.php?t=243271 http://www.rcgroups.com/forums/showthread.php?t=1221543 |
| Thread Tools | |
| Data Hot Wire Foam Cutter Calculator (UPDATED 7-31-2012) | vtdiy | The Builders Workshop | 90 | Apr 13, 2013 12:34 PM |
| Sold Hot-wire cutter variable power supply | jim breese | Aircraft - Sailplanes (FS/W) | 1 | Apr 13, 2012 12:48 AM |
| Question Drivers and Steppers for CNC Hot wire foam cutter | sscherin | CAD/CAM | 1 | Feb 27, 2012 03:08 PM |
| Question Hot Wire Foam Cutter Power Supply? | Slope Lift | Slope | 18 | Jan 15, 2006 07:29 PM |
| Hot wire foam cutter power supply - Electrician needed!!! | CactusJackSlade | Foamies (Kits) | 3 | Jan 19, 2003 01:53 PM |
