Naples FL USA
Joined Mar 2009
Here is a thread that might help with some of your questions....
http://www.rcgroups.com/forums/showthread.php?t=1625684 |
http://www.wikihow.com/Convert-a-Com...b-Power-Supply |
Not a solution for Richie, but may be useful to others:
(Richie, see the edit in my next post for answers to your questions) I have a cheaper suggestion than your proposed power supply, that uses pre-built components, and you can re-use them for other purposes, too. Get a 12 volt battery charger -- that preferably can supply 6 or more amps continuously. It MUST be a transformer type old fashioned battery charger NOT a "computerized" or regulated modern type. You want the type that had a built in meter, not LED lights. Then get a Harbor Freight Router Speed controller. These are regularly on sale for about 20 bucks or less. That's it besides a bow, and you don't have to wire anything. Just plug the charger into the router speed controller. Now you can adjust the charger's output with the router speed controller. The other advantage of this system is that the HF speed controller comes built in with a fuse, cord socket three way switch for full power, variable power and off. These features are often missing from homemade setups, and with the box usually cost more as components than the HF unit does complete. You can also use these things individually to charge a battery, or add variable speed to a router, as originally intended! ps that setup would work well with stainless steel wire leader material of about .023" diameter and a 36 inch bow. If you want a different material, diameter, and or bow length, you can use my hot wire calculator to figure out what will work. If you can't use the calculator, I'll be glad to help figure out what you need on that thread. As mentioned earlier by CayminLast it's at: http://www.rcgroups.com/forums/showthread.php?t=1625684 |
Wow, lots of questions! Hard to know where to begin. In fact this is all very simple, and I think your concerns will evaporate as soon as you begin cutting wings. People do it every day. But it is always good to understand how things work -- and that can be part of the fun itself. So I will try to answer your questions as best I can.
First of all, the calculator I came up with was based on data supplied by forum readers measuring their actual cutting specs, not theory. So I asked people in that thread to measure their amperage, and voltage while cutting, and send in their wire type and diameter and length. From that data, the calculator was constructed. Therefore it is very practical. It relates directly to cutting foam for wings and other modeling activity, using widely available materials and power supplies. I've seen another calculator online that was constructed from theory, and it is very limited, and yet complicated by comparison. Because my calculator depends on people sending in data, it doesn't cover everything so far. Nichrome wire is one area where no one has sent in any cutting data, so we have estimate that. Once you make your bow, please let me know how it works, and provide some data, and we'll update the calculator with that, okay? I'm going to break this up into several shorter posts rather than one long one. So that's the first point. |
In General: you enter figures in the white blanks, and read calculated results in the yellow blanks. Click anywhere in the spreadsheet to recalculate results after changing something. 1.) Always put in the actual heated cutting length of your wire, not the overall bow length. You want to put in 1 meter (40 inches) if that is your heated length, not 1200 mm. Unless that is what the actual heated length is. The heated length is the distance between electrical contacts. 2.) Put in the rated maximum nominal voltage of your power supply unless you have some specific reason not to. It's okay that you put in 12 V but it will be better to put in 15 V. (note: voltages over 35 are dangerous never use any power supply with higher voltage outputs for wire cutting.) 3.) Put in the maximum rated current available from your power supply. In this case it is 15 amps. The calculator won't force you to use all 15 amps, it will simply check to make sure that the wire you choose won't exceed the rated output of your power supply. That's the only reason it asks for this figure. 4.) I usually cut at .4 to .6 watts per inch, but personal preferences vary. People have reported cutting at 1.5 watts per inch and running the wire at red heat. Personally I can't imagine this. I don't like the idea of running that hot, and their wire probably doesn't last too long! But to give yourself some adjustment range, you might choose say 0.6. 5.) You didn't mention the adjustment figure called "Setting" on the spreadsheet. What this means is that for the cutting heat you have chosen, where on your power supply's settings should this "normal" cutting heat be? In the middle, or closer to the maximum setting? In other words, if you have a knob to adjust your supply, at what position of the knob do you want your "normal" cutting heat (chosen in the last step) to be? If you are concerned about safety -- put this fairly high, like say 80% or more. By setting this high, you can't dial in much more heat by accident than the usual cutting heat. Fixed power supplies can't adjust so they should set this at 100% unless there is a specific reason not to. 5.) Resistivity is something you fill in. There is no suggested single figure for this. It merely means how much resistance a material has for its thickness in wire form. In other words an insulator, like plastic, has more resistivity than a metal like copper. And stainless steel has more resistivity than regular steel. There is a short table of resistivity included on the spreadsheet for reference purposes (the grayed area). If you are using stainless steel wire you enter 700. But that is just for stainless. All of these figures were derrived from actual user input, So they are practical figures. Unfortunately we don't have a value for nichrome in the table yet. But we can approximate that from your specs. Things like "guitar string" are difficult to pin down, because strings may be made from different materials. I think we got one data point for guitar string, and that one appeared to rank somewhere around steel's resistivity (low) , rather than stainless steel (higher). Anyway, I'll give you an estimate for nichrome shortly, from your data of the wire you bought and you can try that in the calculator. phew, enough for one post........ Below is a picture of the spreadsheet as an example. It does not have your figures in it. It's just an example of what it looks like for people who are trying to follow along here. ]
Setting for power supply....
Regarding the Setting question you asked...
| Thread Tools | |
| Data Hot Wire Foam Cutter Calculator (UPDATED 7-31-2012) | vtdiy | The Builders Workshop | 90 | Apr 13, 2013 12:34 PM |
| Sold Hot-wire cutter variable power supply | jim breese | Aircraft - Sailplanes (FS/W) | 1 | Apr 13, 2012 12:48 AM |
| Question Drivers and Steppers for CNC Hot wire foam cutter | sscherin | CAD/CAM | 1 | Feb 27, 2012 03:08 PM |
| Question Hot Wire Foam Cutter Power Supply? | Slope Lift | Slope | 18 | Jan 15, 2006 07:29 PM |
| Hot wire foam cutter power supply - Electrician needed!!! | CactusJackSlade | Foamies (Kits) | 3 | Jan 19, 2003 01:53 PM |
