Old Sep 04, 2012, 10:45 AM
XstarWake is offline
Find More Posts by XstarWake
XstarWake's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Help!
DIY PC power supply shutting off after 5 minutes...
Hi,
I did the DIY power supply of a PC power supply.
It does work super great.
Issue : The power supply just shut off after 5 minutes of use... I use it with my Accucell8 , that push 7amp to a 4S....
The fans works great on the power supply, the power supply does not overHeat i beleive, as the power supply is not hot. (external case)
Any idea of the problem?
Thanks for all the help!!
Max
XstarWake is offline Find More Posts by XstarWake
Old Sep 04, 2012, 12:10 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Did you put a load on the 5V line? Also what power supply are you using? Are you sure that it's rated to sustain the number of watts you are trying to pull? Often times cheap power supplies will list "peak" amps instead of sustained amps. Also did you tie all the 12V lines together if it has more then one +12V rail?
grimbeaver is offline Find More Posts by grimbeaver
Old Sep 04, 2012, 01:11 PM
XstarWake's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Wow, thats a lot of questions that im not sure...
Ill try to answer my best.
5V line are the RED wires if im correct. and the answer is NO, i only tied the Yellow together (total of 3) for the 12v. I did cut the Red wire pretty short close to the board.... about 2 inch long remaining...
What power supply? it is a 350W or a 400W power supply. I will read on the side of it to have more informations. What is the informations you need ?
Are you sure that its rated to sustain the number of watts you trying to pull?
Answer : Yes, because they say that he can pull 18Amp on the 12V.
I dont understand the difference of the Peak amps, instead of the sustained amps... maybe a language barrier, as im french....
All Yellow wire together for sure. and, i beleive they are all on the same rail... again, not sure. how do i verify that?
Thanks a lot for that informations!!
Max
Old Sep 04, 2012, 01:21 PM
United States, MN
Joined Feb 2011
Every time I have seen a desktop power supply modified you have to put a resistor load on the 5V lines or you will not be able to max out the 12V lines. I'm betting this is your problem. See this thread:
http://www.rcgroups.com/forums/showthread.php?t=1714389
and this:
http://www.rcgroups.com/forums/showthread.php?t=1670090
Peak means it can only supply that much for a short period. Sustained meaning it can provide that much forever.
Just an example this cheap power supply is listed as 480W which is actually a "peak" rating because when you look at the label in the photo it's only 330W.
http://www.newegg.com/Product/Produc...82E16817170024
If it had multiple rails they would be listed separately on the label with individual ratings, +12V1, +12V2, etc.
Old Sep 04, 2012, 02:04 PM
XstarWake's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Hi sir,
Wow, thanks a lot for that info.
I read both post regarding the load on the 5V line.
Here is what a dude did : I used four 4.7 Ohm, 10 Watt resistors on mine. That's 4 point 7 Ohms each -- wired in parallel.
Q- Were can i find a 4.7ohm, 10 watt resistor? or, can i go 20 ohm, 50 watt resistor? its kinda the same... right?
Thanks for the clarification about the peaks and sustained current.
About the rails, what does it do if there on different rails?
Great help sir,
Thanks a lot again,
Max
Old Sep 04, 2012, 02:13 PM
United States, MN
Joined Feb 2011
You would have to get the resistor from an electronics supplier such as DigiKey, Mouser, etc. Not sure on Canada sources. The other option as mentioned in one of the threads is just use a few automotive tail light bulbs or flash light bulbs. You just need some kind of load on it.
Think of rails as independent supplies, if it has multiple rails you tie them together to form parallel supplies so you get the power of all of them put together. No good or bad to it, just have to make sure you use all the wires to get all the power.
Old Sep 04, 2012, 08:41 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Four 4.7 ohm resistors in parallel = a 1.175 ohm resistor.
Four 10 watt resistors in parallel = a 40 watt resistor.
Resistors in parallel divide ohms. The wattage does add.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Sep 05, 2012, 04:20 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
As the voltage on the battery being charged increases, the charger must draw more current from the power supply. For example, charging a 4S Lipo to 16.8V at 7A requires about 130W of charge power (assuming 90% charger efficiency) which is nearly 11A at 12V. If this increased current causes the input voltage to drop then the charger will try to draw even more current (eg. 12A at 11V) until the power supply senses under-voltage and cuts out.
Most pc power supplies have a single transformer with multiple output voltages, but only the 5V line is regulated. Putting a load on the 5V line causes the power supply to increase transformer power to compensate for the lower voltage (on the 5V line), which then raises the voltage on the other outputs.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 05, 2012, 11:32 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
This is incorrect.
A pc PSU is a SMPS (it rectifies the AC to DC then uses a DC-DC converter to get lower voltage). ALL the outputs are regulated (they have to be as ATX spec is only 5% variance on the 12V line).
Older PSUs (and the really cheap crappy designs) need some load on the 5V line or they think something is wrong (which is correct if it is a PC) and shut down. New ones wont care as pretty much all the power on a modern PC is supplied via the 12V lines.
Be aware that none of the cheap no-name PC PSUs are likely to be able to manage more than 200-250W without shutting down (or burning up). The specs are total lies and a 500W and 300W unit is likely to be electrically identical (only difference is the sticker). They dont really make a good choice for a supply, server units from eBay are much better (and just as cheap).
desertstalker is offline Find More Posts by desertstalker
Old Sep 06, 2012, 07:02 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
YMMV.
Haven't used a load on my recent PC PSUs either -- last 5 years or so; yes prior to that.
Tested the newer supplies w/ & w/o load no difference on 12V performance.
Can you monitor the output of the PSU/input to Charger via a Whattmeter?
The load on the PSU ramps up -- could take 5minutes w/some chargers -- at this point the PSU might be overloaded..
jrb is offline Find More Posts by jrb
Old Sep 06, 2012, 07:46 AM
XstarWake's Avatar
Canada, ON, Ottawa
Joined Oct 2010
JRB,
Are you saying that loading the 5V line is not the issue?
I dont have a wattmeter, but can borrow one from my friend.
thanks all for the info... its greatly appreciated. I am learning a lot as i go.
Max
Old Sep 06, 2012, 07:50 AM
United States, MN
Joined Feb 2011
Instructions from TJinTech say to load it and he's pretty knowledgeable so pretty sure you need it. He says a 1A load:
https://sites.google.com/site/tjingu.../convert-pc-ps
The thing I don't get is he says:
I ended up using 2x 1.5ohm 10W in series to create a 3ohm resistor that would draw 5/3A.
Since V = IR wouldn't that be 12v/3ohm which is 4A not 5/3A? But I suppose since it can only dissipate 10W each the math is different and he's doing 20W/12V = 5/3A?
Old Sep 06, 2012, 08:44 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
As I said YMMV; but, when I tested my latest PSU conversions the 12V performance was the same whether 5V was loaded or not.
I always put my Whattmeter inline between the PSU and charger during the 1st couple of "high power" uses.
Old Sep 06, 2012, 10:20 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
I have converted many of those older computer supplies for our use. All, yes ALL, have required a load on the 5 volt bus to get 12 volts at any decent current out of the 12 volt line. How much load, some required only about 5 ohms but some required as much as 2.7 ohms to get the full voltage out of the 12 volt bus. If you look at the schematics, most of these power supplies depend only on the load on the 5 volt bus to establish proper regulation. Admittedly, all these power supplies have been 5 or more years old. It is easy to find out if that will help if you are converting a power supply, just load down the 12 volt bus to draw the max current you will need from it and then experiment with different values of loads on the 5 volt bus while checking the voltage on the 12 volt bus.
Rodney is offline Find More Posts by Rodney
Old Sep 06, 2012, 10:44 AM
XstarWake's Avatar
Canada, ON, Ottawa
Joined Oct 2010
omg, you guys are smart!
Im reading and learing a lot, but still a lot of info i dont really understand.
Peace,
Max
Discussion Power Supply shutting down 5regal Batteries and Chargers 8 Aug 20, 2012 07:45 AM
Discussion Electric boat setup: dead after 5 minutes? bmwbob Power Systems 1 Feb 24, 2012 09:58 PM
Help! Engine shuts off after 5 min HELP!!! mr.Q Off-road Cars 6 Nov 07, 2007 07:40 PM
3.5 minutes and power shuts off JJoseph Power Systems 2 Feb 01, 2005 01:00 PM
PC power supply shuts off? Lammergier Batteries and Chargers 8 Jun 12, 2003 02:22 PM
