Old Oct 14, 2012, 05:23 AM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Ok so maybe there is no stringing between deposits.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Oct 15, 2012, 07:24 PM
Joined Jan 2010
Man, I am sooo close to just jumping in and pledging/buying an Eventorbot off kickstarter, but trying to control the urge, and wait for a couple reviews, and that Make article in november.
I found one other interesting one thats quite similar with a solid metal frame design. The PandaBot. Runs about $800 shipped (and I believe fully assembled). And it does have an interesting feature...
Automatic print head self calibration.
Having never used a 3d printer, I don't know, is this a truly awesome feature, or nothing major. Is the calibration procedure with normal 3d printers normally a time consuming pain, or no big deal?
carl1864 is offline Find More Posts by carl1864
Old Oct 15, 2012, 07:43 PM
Merry Christmas... :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
Calibration is not too bad on most. Usually the plate is adjustable and you go to each corner and adjust so you have a specific clearance between head tip and plate. (.1 or .2mm).
Mark
KCV6 is offline Find More Posts by KCV6
Old Oct 16, 2012, 11:09 PM
Joined Jan 2010
Well the pandabot (the one that self calibrates), just released a couple new sample pictures. Don't quite know what to think about these. I mean, I don't like to knock work in progress and innovation, but these samples of the "faceless man" just seem pretty bad, especially to be showing as samples, and the yoda head didn't even print fully.
http://www.kickstarter.com/projects/...-printer/posts
Old Oct 17, 2012, 05:12 AM
Joined Oct 2012
Another good one:
http://mendelmax.com/
http://www.flickr.com/photos/techsho...7629484425149/
ElectroDie is offline Find More Posts by ElectroDie
Old Oct 17, 2012, 06:54 AM
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
I have to agree the hoodie one is crap but the other two seem alright
scrub monkey is offline Find More Posts by scrub monkey
Old Oct 23, 2012, 01:05 AM
Newcastle, NSW Australia
Joined Oct 2009
Post by the creator regarding the hoody guy....
Creator Panda Robotics 6 days ago
Sorry for the confusion regarding the person in the hoodie.
This was an earlier test print we did. There are definitely a few
problem points related to draft angle and stringing but overall it's a
fairly good print. In particular, surface finish on the torso is a
good indicator of the type of surface finish you could expect around
0.2mm slices. We're happy to share in-progress images of work as we
go, and it's really worth bearing in mind that hoodie was printed on
our first prototype, which doesn't always perform 100%. We're well
along on our up-grade path and will be posting more images soon
thren is offline Find More Posts by thren
Old Oct 23, 2012, 01:11 AM
Joined Oct 2009
(double post sorry)
41 hour to go on the eventorbot kickstarter campaign and he has reachesd funding of $115K
not bad considering he was only after $25k
Old Oct 23, 2012, 09:08 PM
Joined Jan 2010
Well, I went ahead and took the plunge, and pledged for a full Eventorbot kit.
Its not like me to throw this much money towards a product that I haven't even seen a review of, but I'm just too eager to wait. Plus the inventor really seems like a great and trustworthy guy, who is going out of his way to make this product as good as it can be. Also its open source, and upgradable so I'm sure that if any problems do arise, they will be solveable.
Old Oct 23, 2012, 11:10 PM
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
What 3D software are you using for the printer?
ZIPPER is offline Find More Posts by ZIPPER
Old Oct 23, 2012, 11:19 PM
KCV6's Avatar
Joined Aug 2009
For the printer or to make the STL files?
I use Creo Elements (ProE)
Still deciding but we may get a Makerbot.
Mark
Old Oct 25, 2012, 05:46 AM
The Mantis is on its way
windoze killa's Avatar
Australia, VIC, Rowville
Joined Jan 2012
Whats the external finish like on some of these cheaper printers? Would there be much need to sand and/or buff it for painting or plating?
windoze killa is offline Find More Posts by windoze killa
Old Oct 25, 2012, 09:12 PM
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
I think the guy I know has a makerbot, the first thing he made was a manifold for the fume extractor he attached to the makerbot.
From what he says, you need to accurately measure the plastic you buy as the feed and heating rates are dependent on the diameter.
Robbie d is offline Find More Posts by Robbie d
Old Oct 26, 2012, 06:26 AM
2.5kg C-17 foamy, No prob!!
pezzer2003's Avatar
Australia, NSW, Wattle Grove
Joined Mar 2005
I have completed and am running a Prusa Air 2 http://reprap.org/wiki/Prusa_Air_2
I have achieved my goal of keeping under $1000 (so far).
All was looking good then the Wade extruder I had built failed me..
So I have invested in a MBE EXTRUDER V9 http://www.qu-bd.com/
The accuracy of the Prusa Air is really good but I want to do better. So my plan is to use the existing parts and build a better one. I'm looking at the Lulzbot TK-0, http://devel.lulzbot.com/TK-0/ my plan is to get the Prusa Air to print the parts and source the t-rail locally.
As for the finish, you have to sand PLA, but if you print it ABS then dip the part in acetone for 30sec (results may vary and you should do a test part first) the result is amazing. Check out this guys results http://www.thingiverse.com/thing:17404
Cheers,
Matt
pezzer2003 is offline Find More Posts by pezzer2003
Old Oct 26, 2012, 05:57 PM
Australia
Joined Oct 2000
this is the future..
http://m.smh.com.au/technology/techn...026-289ki.html
MartinL is offline Find More Posts by MartinL
Discussion Home 3D printing Artsloper Inland Slope Rebels 4 Sep 18, 2012 06:33 PM
Discussion 3D printed FPV but DLG type elliptical wings.. Laurence Carroll Hand Launch 3 Aug 17, 2012 02:15 PM
Discussion 3D Printed 1/48 scale RAmparts 3000 Tug remondo Scale Boats 6 Aug 06, 2012 04:05 PM
Help! 3D printed 1/12 scale pan racer Jolijar On-road Cars 7 Mar 25, 2012 03:55 PM
