Old Oct 03, 2012, 04:03 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by txg8gxp View Post
I picked up some linkage stuff and 2 s3114 servos today for the flap mod. I have had great luck flying with different chamber setting on this plane so I can't wait to add flaps. Once they are installed I will reprogram my radio for fully adjustable reflex/chamber, flaps and crow.
One of the big reasons I'm considering the Calypso is because of its flap system. I recently acquired a JR X9303 Native 2.4 (no modules) Sailplane Version and am dying to get some of its tricks into play & experiment with. It's almost funny how, ever since getting the JR, every plane I've been considering can't fully exploit its capabilities.
Aside @Pete & txg8gxp:
I was in a Michael's Arts & Crafts store a couple weekends ago & they were laying in some new airbrush paints. I picked up a bottle each of blaze orange & chartreuse so bright that, I swear with all the lights out in the house you can HEAR 'em! I hope they will hold up under the sun's UV, which is usu. the downside of that category of hues.
Oh, one more thing @ txg8gxp: I have an old buddy who swears by 'hot pink'. He makes underwing circles with 'Duck' brand tape, says it pops out like nothing he's ever seen. But me & pink? *heh heh* Can't make myself do it.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 03, 2012, 10:30 AM
txg8gxp is offline
Find More Posts by txg8gxp
Joined Aug 2012
For me, neon greens and neon pinks really stand out. When i finally order my blaster 3 DLG it will be in one of those colors, I'm leaning towards neon pink. The main reason I have been going over board on setup options with flap/chamber/reflex/crow on my calypso is just like you said, to really learn my radio. I have a 8FG super that seems like it can do anything and everything. I totally love the futaba. From what I understand you should be able to do whatever you want with the 9303 aswell.
txg8gxp is offline Find More Posts by txg8gxp
Old Feb 14, 2013, 11:58 PM
Guardian7 is offline
Find More Posts by Guardian7
Guardian7's Avatar
United States, CA, Lancaster
Joined Sep 2012
Having a Radian Pro my Calypso did not seem to float as well so I've been working to reduce her weight. Swapping the motor for a Hacker 20-22 helped reduce weight quite a bit, due to weight I decided not to add in the flaps because I want a floaty bird.
Guardian7 is offline Find More Posts by Guardian7
Old Feb 15, 2013, 08:06 AM
Westranm is online now
Find More Posts by Westranm
Westranm's Avatar
United States, AZ, Chandler
Joined Jan 2011
In my experience with the Calypso and experimenting with the weight, I believe you will have better luck installing the flaps and setting up your radio to increase lift through adjusting the camber of the wing. The Radian has more built-in camber than the Calypso.
-Randy
Westranm is online now Find More Posts by Westranm
Old Feb 25, 2013, 03:45 PM
feldmarshal1 is online now
Find More Posts by feldmarshal1
feldmarshal1's Avatar
United States, AL, Smiths Station
Joined Oct 2011
A little bit of flap works great to keep her in the air, alot and she stops. I've got mine dialed in to where my landing are so slow I hav a 6 ft role out. Flpas down, aelerons up and she lands anywhwere I want.
I'm getting about 30minutes on one 1500mah battery with aout 4 climbs to altitude. Only trim I have is for full throttle ther is down elevator mixed in, other than that everything is straight.
Good flyer, does everything you ask and stays in the air.
Feldmarshal1
feldmarshal1 is online now Find More Posts by feldmarshal1
Old Feb 25, 2013, 04:55 PM
Earthbound Skyhound
Joined Jun 2011
But remember when you lighten that motor you have (usually) to make CG concessions. Have you tried 'er (balancing) with the Hacker & what'd you have to do?
Old Feb 25, 2013, 11:08 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
Hi, SH.
We haven't connected in a while so I'm risking an OT post.
I've been playing with motors. I still like the SK3 2836 but have become a real fan of the Turnigy 2834 1250 kv. I have yet to find a motor that can match it's power to weight, 66 grams, ratio at any price so the SK3 has become my "back up motor". I've been flying my Yak 54 with the HK motor and, with a 11X4.7 prop, it hovers at around 1/3rd throttle and gives me 9 minutes of hard 3D flying with a 2200mah 25C battery. Now I just need to find the perfect glider for my second 2834. I'm torn between a Esprit Model's Pegasus and a Fly Fly DG-1000. I'm guessing that any glider under 1500 grams should climb as high as I want it in under 10 seconds!
BTW. Even with the stock motor I have found it hard to get the CG back far enough on the Calypso. I think a lighter motor with a bigger prop is the way to go.
Cheers!
peterlngh is online now Find More Posts by peterlngh
Old Feb 26, 2013, 05:08 AM
Earthbound Skyhound
Joined Jun 2011
Cheers!
That being the case, sounds like the lighter motor would fit right in with your scheme of things. Good move.
(Slight tack: What's best source for Hacker pricing & availability -- or are they pretty much 'price controlled' too?)
Funny too -- a couple of lines from a couple of my recent HK orders:
109773 4ea OK HK2834-1250 - HobbyKing 2834 Brushless Outrunner 1250K..
...2037 4ea Turnigy Aerodrive SK3 - 2836-1040kv Brushless Outrunner Motor (USA warehouse)
Looks like we've been sniffing up the same trees!
Gonna be sending some samples to Dr. Kiwi to test, rate, & of course add to his database, so stay tuned ....
By the by - if you start to go for the FlyFly 1000 let me know & maybe we can team up for a double buy/shipment? Been sniffin' round that way for awhile, too.
Old Mar 04, 2013, 03:09 PM
HARD DRYVE is offline
Find More Posts by HARD DRYVE
Puerto Rico, Mayagüez
Joined Jan 2011
Hi guys!, I have my Calypso setup with my Spektrum DX7. What I did was plug the flaps with a "Y" to the Gear channel and left the flaperons active. As the DX7 has 3 flap positions I can have "up" flaperons (spoilers), "normal" or "down", while the flaps are on a separate channel so that I can have crow/butterfly, etc. Everyone at our club loved this glider!!! Right now its very windy here in PR and while most of them are grounded I'm actually having a blast!!
HARD DRYVE is offline Find More Posts by HARD DRYVE
Old Mar 27, 2013, 06:07 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Originally Posted by kingsflyer View Post
Nice upgrade Dave.
I was wondering if the flaps could now be reflexed "UP" for spoilers? On a lot of high-dollar gliders, the flaps are reflexed up slightly to increase straight line speed when traveling between thermals and then deflected upward a lot to kill lift and come down quickly.
With your 9C and many other TXs, you can link the individual flap servos to ailerons and have flapperons and spoilerons. Of course you will need a different receiver with more channels so each flap servo could be plugged into a different channel.
McD
generally if you reflex up the faps alone you will increase the speed but also create a NASTY tip stall (due to the upward flaps creating a wash-in effect) so usually people put the flaps and ailerons upwards, with the ailerons even with or slightly higher than the flaps.
baconflyer is offline Find More Posts by baconflyer
Old Jan 16, 2015, 07:08 PM
gadgeter is offline
Find More Posts by gadgeter
gadgeter's Avatar
Joined Aug 2014
Not a necessity but....
The Calypso wants to stay airborne w/o flaps but they do allow for a little slower approach
If you like the Calypso try the Lanyu (Voltanex) Phoenix and Phoenix Evolution 2.6
Actually better built but similar in some ways
gadgeter is offline Find More Posts by gadgeter
Old Jan 17, 2015, 06:49 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
http://www.rcgroups.com/forums/showthread.php?t=2325555
Martyn McKinney is offline Find More Posts by Martyn McKinney
Article Flyzone 73" Calypso EP Glider Review 78dave Electric Sailplanes 2142 Today 11:21 AM
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 93 Jan 13, 2016 03:15 AM
Discussion Ordered a Flyzone Calypso Glider. Kimber Foamies (Kits) 12 Oct 05, 2012 05:20 PM
Sold Parkzone Stinson Reliant SR-10 w/ Optional Flaps jktravis Aircraft - Electric - Airplanes (FS/W) 4 Jun 28, 2012 09:02 AM
