Old Sep 03, 2012, 05:35 PM
Bill Diedrich is offline
Find More Posts by Bill Diedrich
Bill Diedrich's Avatar
Ventress, Louisiana
Joined Oct 2007
Adhesives for ABS Plastic
Found a Tug kit that has an ABS platic hull in a freind's
model stash, and would like to build it, but not familiar with
adhesives used for wood to ABS joining. Said he would make
me a heck of a deal if I wanted the kit. It is the Artesiania Latina
Amsterdam. What would a fair price for this kit be, he has assembled
the keel parts only, kit is complete.
Bill Diedrich is offline Find More Posts by Bill Diedrich
Old Sep 03, 2012, 07:19 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Bill,
You can use epoxy, thick CA, or Gorilla Glue for wood to styrene based on what you have around as well as your preference. If he’s a food friend and you’re interested in that particular kit, I’d say it’s worth a BBQ and some beer at your place, or what ever he’d like to get out of it, or what you are ok with paying. Started kits don't typically do very well unless they are extremely rare or have complicated fitting kits.
Kcal is offline Find More Posts by Kcal
Old Sep 03, 2012, 07:47 PM
Ventress, Louisiana
Joined Oct 2007
Originally Posted by Kcal View Post
Bill,
You can use epoxy, thick CA, or Gorilla Glue for wood to styrene based on what you have around as well as your preference. If hes a food friend and youre interested in that particular kit, Id say its worth a BBQ and some beer at your place, or what ever hed like to get out of it, or what you are ok with paying. Started kits don't typically do very well unless they are extremely rare or have complicated fitting kits.
We BBQ together quite often, as for the beer, neither one of us drinks, but I did offer him $75 for the kit, said he'll sleep on it.
Never had much luck with epoxy on ABS before in my aircraft assembling, guess it's time to finally try the Gorila Glue.
Old Sep 03, 2012, 07:56 PM
Kcal is offline
Joined Jul 2008
There has to be a build thread here, I would start there and see how they went about it. You will also get an idea of what you face in the build and solutions to and issues that may arise. I just used lock tight 5 minute epoxy last night for wood to styrene but it was for a large flat surface to reinforce a transom, I was the clamp and it worked quite well.
Old Sep 03, 2012, 08:06 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
That kit is worth about $400.
Kmot is online now Find More Posts by Kmot
Old Sep 03, 2012, 08:13 PM
Band1 is offline
Find More Posts by Band1
Band1's Avatar
United States, NY, Queens County
Joined Oct 2011
Hi, make sure you prep the hull first or the glue will not stick.
Band1 is offline Find More Posts by Band1
Old Sep 03, 2012, 08:43 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
Anyone ever tried G/flex epoxy on ABS?
http://westsystem.com/ss/search-resu...%C2%A0Go%C2%A0
Apismelifera is offline Find More Posts by Apismelifera
Old Sep 03, 2012, 09:14 PM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
My Happy Hunter is made of ABS plastic and when I built her, I used Stablit Epoxy to start off with. Later as I progressed through the model and for repairs I use(d) gap filling CA. I don't have any issues with the CA sticking, but as most of us find with our models, most of the stuff that comes off or breaks is because of my own carelessness or accidents in moving her around, not the CA not working
Scott
laser110 is offline Find More Posts by laser110
Old Sep 03, 2012, 09:52 PM
Ventress, Louisiana
Joined Oct 2007
Did a little research into the G/Flex Epoxy, looks very promissing, just need to get some on order if my friend accepts my offered or we come to an acceptable agreement on price for the kit.
Old Sep 04, 2012, 12:28 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
ABS to Wood
My choice would be GORRILLA CA, not, the regular Gorrilla Glue. Rough it up with about 180 grt. sandpaper, and it should stay great. That is also what I would use for all the wood joints. Even started, that kit is probably worth $200, or more. CB
CaptCB is offline Find More Posts by CaptCB
Old Sep 04, 2012, 03:48 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Comes up at regular intervals. Graupner recommend "Uhu Hart" which is basically Balsa Cement for wood to ABS.
If you're gluing ABS to ABS or to Polystyrene (NOT foam) sheet, MEK (Ketone) is a solvent and will weld the bits together, just be careful not to have it running all over.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Sep 04, 2012, 01:40 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
I have used it on wood to ABS, wood to fiberglass, ABS to fiberglass, and more works great! Preping the surface is key though!!!
keith S is offline Find More Posts by keith S
Old Sep 04, 2012, 01:53 PM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
What about Milliput?
Old Sep 04, 2012, 09:42 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
I used G-Flex to join a wood deck to an ABS hull on this old tug. Worked great.
woodybob is offline Find More Posts by woodybob
Old Sep 04, 2012, 09:51 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
How about ABS pipe cement? Might be messy though.
Underthetire is offline Find More Posts by Underthetire
Help! Glue for ABS Plastic? Butch777 Electric Plane Talk 10 Jun 10, 2012 05:26 PM
Discussion Remedy for Uv Yellowed ABS PLastic-It Works! cdog46 Dock Talk 3 Jul 25, 2010 10:37 PM
Question What resin is suitable for ABS plastic? badbunny_uk Scale Boats 5 Feb 07, 2007 03:57 PM
Best Filling Material For ABS Plastic? andyg The Builders Workshop 6 Jan 10, 2005 06:10 AM
