You might check out Oct 2003 and Jan 2004 articles here: http://www.spadtothebone.org/rcreportarticles.html
Keep in mind the site is still a work in progress at updating the old www.spadtothebone.net. |
Joined Sep 2012
A) Yes, My boyfriend is a competent flier and I just learned.
B) No, buy my boyfriend built an LT-40 and a Bee Gee from kits 9 years ago. C) We're using plans for a balsa Tiger Moth (for the dimensions): http://www.outerzone.co.uk/planfiles...gerMoth_50.pdf |
Joined Sep 2012
Good reads. |
Joined Sep 2012
Aspeed, I'm hoping to get a beefy electric motor, from Hobby King, I'm seeing some that might work: http://www.hobbyking.com/hobbyking/s...0KV_2400W.html for $45 with 5+kg of thrust, combined with a battery and speed control might put me a bit over-budget, but I think I'd like to keep it electric so It doesn't shake apart. |
If it's any help, most coro fuses that I have seen don't use longerons. They usually just use a few formers. See this 1/4 scale Fokker D-VII Build at spadworld.net. The fuse stuff starts on page 2.
frosty |
Joined Sep 2012
Today we got the fuse box re-cut out ( the first cut was too small), all four wings are mostly built. The weight should be at around 6lbs but may be slightly less when the fuse is cut. Hopefully we can make more progress this week and determine what the weight will really be so we can order the appropriate motor (I want ~2lbs more thrust than the weight of the plane). Thanks for all the advice thus-far, we definitely need all we can get with our first dive into SPAD. We threw together the airplane to see about how big it will be; my boyfriend is pretty happy about it!
| Thread Tools | |
| Video Build - GWS Pico Tiger Moth NPS Version (white) spray paint | TheLeabres | Electric Plane Talk | 7 | May 25, 2012 03:15 AM |
| Discussion looking for the build manual (instructions) of tiger moth 400 | jaas75 | GWS (Grand Wing Servo) | 7 | Mar 05, 2012 12:54 PM |
| Discussion Help, im building a GWS tiger moth 400 and lost the manual | jaas75 | Parkflyers | 4 | Feb 28, 2012 06:19 AM |
| Discussion Help me build GWS pico tiger moth or bigger 400 tiger moth | wrangler | Beginner Training Area (Aircraft-Electric) | 2 | Dec 06, 2006 11:28 PM |
| 88" Pilot Tiger Moth Kit, NIB | gavoss | Aircraft - Electric - Airplanes (FS/W) | 0 | Mar 23, 2002 10:36 AM |
