Old Sep 03, 2012, 01:30 PM
Photo Elevate is offline
Find More Posts by Photo Elevate
Gravity always wins !!!
Photo Elevate's Avatar
UK, Essex, Tiptree
Joined Jan 2010
Question
Coaxial motor setup
Has anyone considered using different kv size motors ie. 710kv top and 770kv bottom.
Keeping the same size props all round, the bottom motors would spin faster to overcome the propwash.
I dont know if the HF board would throw a wobbly with this setup,
Would flight times or stability suffer?
Any thoughts?
Photo Elevate is offline Find More Posts by Photo Elevate
Old Sep 03, 2012, 02:00 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
I usually stick with the same motors and go with an inch bigger and one or two inches faster pitch on the bottom motor, the bottom motor will then go at a similar speed but move more air with the same effort (as the prop above is already haulin a$$)
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Sep 03, 2012, 03:10 PM
Webheadfred is offline
Find More Posts by Webheadfred
Air Traffic Controller
United States, TN, Knoxville
Joined Aug 2011
I use 1" bigger on the bottom and more pitch as well.
Webheadfred is offline Find More Posts by Webheadfred
Old Sep 03, 2012, 03:13 PM
Joined Jun 2007
Alot of echo in these hoverfly forums. :P.
CJ
Old Sep 03, 2012, 06:15 PM
JZSlenker is offline
Find More Posts by JZSlenker
JZSlenker's Avatar
United States, PA, Harrisburg
Joined Aug 2011
Ditto 1" bigger slightly more bite on the bottoms of our X-8
JZSlenker is offline Find More Posts by JZSlenker
Old Sep 04, 2012, 11:02 AM
webgeek is offline
Find More Posts by webgeek
Joined Sep 2004
In my current Y6, I have 1" larger props with more bite on the bottom and those motors are getting hotter than the top motors. I'm actually going to make them same props all around to see what happens.
-Mike
webgeek is offline Find More Posts by webgeek
Old Sep 04, 2012, 11:33 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
-Mike
Bottom motors tend to run a little hotter because of airflow there is nothing wrong with your setup. The important thing is to have the same load on all motors during a stable hover, If the power in unbalanced you loose efficiency and the board has to use compensate to keep it stable.
RC Man is offline Find More Posts by RC Man
Old Sep 05, 2012, 12:47 AM
tahoelight is offline
Find More Posts by tahoelight
tahoelight's Avatar
North Lake Tahoe
Joined Nov 2009
Who has a prop suggestion for my X8. I have been running 14x4.7 SF top and bottom. I have never had good luck with the APC e props. How are you guys getting 1" larger props with higher pitch on the bottom? I just don't see any options for these larger props out there.
tahoelight is offline Find More Posts by tahoelight
Old Sep 05, 2012, 01:46 AM
Joined Jun 2007
Try master airscrew, they have a good prop selection. They're pretty tough, they come quite well balanced (though I'd always balance them myself when they show up) and they do some good sizes too. They're a bit chunky but this helps with yaw speed.
CJ
Old Sep 05, 2012, 08:33 PM
Joined Aug 2011
On my X8 I used 11x47 on top and 13x6 on bottom. I also have 14's also but I find I get a smoother flight with 12's. I'm flying 12x38 on top and 13x47 on bottom. I have flown 11x47 both top and bottom. It's actually a little easier to control with the 11's but less flight time.
I'm using BC 3536-11 750k with 4s. MTM distance is 38".
Discussion Syma S033G Convert from coaxial to non coaxial Kenwhite23 Beginner Training Area (Heli-Electric) 13 Apr 17, 2014 03:01 PM
Discussion Motor mounts approaches for coaxial setups alvarezpja Multirotor Talk 7 Jul 06, 2011 03:24 AM
Discussion Need Help: Gyro setup for a brushless coaxial heli rcastab Coaxial Helicopters 1 Jun 13, 2010 02:36 AM
Discussion Coaxial rotor setup without the flybar? edi Coaxial Helicopters 1 Feb 14, 2008 04:54 PM
Build Log Coaxial AP setup help needed! trashmanf Coaxial Helicopters 6 Mar 14, 2006 01:13 PM
