Old Sep 03, 2012, 09:26 AM
Hossinarizona is online now
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Question
Nose Gear Door Hinges
I need to close up a nose gear door and need some hinges. I saw some spring loaded ones a while back but can't seem to find them? Or maybe now there is a better method, any help would be greatly appreciated.
Hossinarizona is online now Find More Posts by Hossinarizona
Old Sep 03, 2012, 10:29 AM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Sonictronic has a spring loaded offset hinge
http://www.sonictronics.com/xcart/pr...9&cat=0&page=1
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Sep 04, 2012, 03:35 AM
jofro is online now
Find More Posts by jofro
Joined Jan 2010
I just fitted 30mm long bullet plastic hinges to my Hawk, 2 on each side but could anyone suggest what would be the best outlet selling very soft springs some 30mm by4mm OD. to keep the pull-pull wires away from the nose gear retract mech, Joe.
jofro is online now Find More Posts by jofro
Old Sep 04, 2012, 08:37 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
What some have done is to use what we call a zip-tie or cable ties. comes in various lengths, and widths, for securing just about anything. It's bent in a U shape and shrink tubed over each steering cable. It always wants to spring apart, so on retraction, cables sping apart, down and locked, not enough compression to worry about.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 05, 2012, 03:07 AM
jofro is online now
Joined Jan 2010
Thanks for suggestions, I used all sorts of alternatives but there is nothing to beat the soft reliable spring as ill. bottom pic, any idea where to get them? I tried today 10 places I could think off, no luck! Joe.
Old Sep 05, 2012, 09:20 AM
Narragansett, RI
Joined Oct 2000
Local True value hardware store
Old Sep 05, 2012, 02:34 PM
moparren is offline
Find More Posts by moparren
I am what I teach
Tucson AZ
Joined Mar 2007
Or Ace depending on what is in your neck of the woods.
moparren is offline Find More Posts by moparren
Old Sep 05, 2012, 02:46 PM
Joined Dec 2008
I believe that Jofro's neck of the woods, is "downunder" . Not sure there are too many ACE, or TrueValue's there.
Old Sep 05, 2012, 05:13 PM
jofro is online now
Joined Jan 2010
Above spring is too delicate for any h/ware store, tried them all. Even our spring specialist shop don't have it. I wonder where chineese get it for their h/ware kit packs, Joe.
Old Sep 06, 2012, 05:57 AM
CaseySP is offline
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Biro spring with the end coils bent out perpendicular?
CaseySP is offline Find More Posts by CaseySP
Old Sep 06, 2012, 01:08 PM
EricD2 is offline
Find More Posts by EricD2
Oshawa Ont. Canada
Joined Jul 2011
Briggs & Stratton lawnmower engine governor springs are perfect. They are on the older engines with dual springs.
EricD2 is offline Find More Posts by EricD2
Old Sep 06, 2012, 01:28 PM
Bob Reynolds is offline
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
Ball point pen springs with a little rebending.
Bob Reynolds is offline Find More Posts by Bob Reynolds
Discussion retractable gear door hinging ?? pinolefm1 Scale Sailplanes 3 Jun 27, 2007 04:16 PM
Discussion hinging gear doors Big Nuts 181 International Scale Soaring Association (ISSA) 5 Feb 04, 2007 07:03 AM
Help! Retract Gear Door Hinges? RocketRob Scale Kit/Scratch Built 7 Nov 20, 2006 07:11 AM
Offset Hinges For Gear Doors diver don Scale Kit/Scratch Built 4 Aug 10, 2005 02:59 AM
