Old Nov 13, 2001, 08:15 PM
Mark E is offline
Find More Posts by Mark E
Alameda, CA
Joined Oct 2001
Hitec HS-55 Servos in an LMH Corona?
I'm starting the assembly on my Corona. The radio I was going to use has HS 55 Servos. They're plenty small, but it occured to me that they have a lot less torque (13 oz/in) than the HS 81s (32 oz/in) that the manual shows in its "typical installation".
Any opinions on whether or not the HS 55s will be up to the task? Thanks!
Mark
Mark E is offline Find More Posts by Mark E
Old Nov 13, 2001, 09:00 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
They may have enough torque, but the gear train is not up to any rough stuff.
Go with the 81's, they work in the LMH fine and the bigger Corona will load them alittle more.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Nov 13, 2001, 11:06 PM
gstew is offline
Find More Posts by gstew
Columbus, MS, USA
Joined Oct 2000
I totally agree with Fred... HS-55's are too small for your LMH. I started with HS-80's in mine and later went to JR 241s. The 241s are about the smallest and lightest servo that I'd put in the LMH... while they are rated about the same as the HS-55, but have a sturdier gear train. That's the limitation of these servos... the HS-55's will probably move the cyclic 95% of the time, but a hard landing or minor blade strike or even a hard pullup can strip the gears... a bad thing to have happen, a really bad thing to have happen in the air.
The HS-81s are VERY good servos here!
Greg Stewart (Minneapolis, MN, USA)
gstew is offline Find More Posts by gstew
Old Nov 14, 2001, 12:30 AM
gpeden is offline
Find More Posts by gpeden
-Flight enthusiast_
gpeden's Avatar
Lake Louise, AB, Canada
Joined Feb 2000
I used JR241s in mine and they stood up to hard fast flying including loops. In the few crashes they endured I had to replace a couple of gear sets, no worse than the stock HS-80 servos originally used. I would not have used HS-55s though. If you are a beginner and might be crashing more than the odd time, then the HS-81s are probably a good idea
Cheers!
Glen
gpeden is offline Find More Posts by gpeden
Old Nov 14, 2001, 09:25 AM
wayne is offline
Find More Posts by wayne
Millarville,Alberta,Canada
Joined Jun 2000
Just a thought
The MX-50HP servos' have a weight of 9grams and 23in/oz torque, speed 0.078sec/60, and ball bearing on top. Not the same as HS-81 but not bad for a micro and weight. Would these be okay for the Corona.I have used them in electric planes and so far been really good. Is it true every gram you save is 1 more sec of flight time!
The JR241 have 17oz torque and .23sec/60, 9 grams
Wayne
wayne is offline Find More Posts by wayne
Old Nov 14, 2001, 11:37 AM
rcdude is offline
Find More Posts by rcdude
San Jose, CA
Joined Mar 2000
Dave sell the HES servos at really good price. I would go with either HES-588P or HES-688P upgraded to metal gear. I never had a stripped gear ever.
http://members.aol.com/davthacker/radicalservos.htm
rcdude is offline Find More Posts by rcdude
Old Nov 14, 2001, 08:00 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Tony, those are the same wieght as the HS-81 with the same power, but MUCH slower.
I would still go for the 81's, or 81 MG. They are strong and go for well under $20 almost everywhere.
I on the other hand am setting up a light LMH and got some CS 21's for it. A little less power than the 81's, but 1/2 the wieght.
Old Nov 15, 2001, 02:15 AM
rcdude is offline
San Jose, CA
Joined Mar 2000
Fred,
You are right on BOTH count.
Old Nov 15, 2001, 01:50 PM
HankF is offline
Find More Posts by HankF
Joined Apr 2000
I've been using HS55's on my eLMH all along and have had to replace 4 gearsets - thats a lot of flying. After I made it an ultralight I've had no more gear problems. The 55's are fragile though but the torque is fine for the eLMH.
HankF is offline Find More Posts by HankF
Old Nov 19, 2001, 07:12 PM
Mark E is offline
Alameda, CA
Joined Oct 2001
Thanks to everyone for the advice. New HS-81s are on the way!
Wanted Looking for 2 Hitec HS-55 servos and an AR6000 receiver BD Flyer Aircraft - General - Radio Equipment (FS/W) 0 Jan 01, 2007 02:50 PM
Sold 10 Hitec Hs-55 servos new in box stealthy Aircraft - General - Radio Equipment (FS/W) 2 Dec 12, 2006 10:38 PM
Wanted 1 or 2 Hitec HS-55 servos NEW OR IN GOOD CONDITION!! usbcmember Aircraft - General - Radio Equipment (FS/W) 9 Oct 30, 2005 11:56 AM
hs-55 servos in corona rchawks Electric Heli Talk 0 Jun 24, 2005 10:04 PM
Hitec HS-55 Servos, 2 New In Box nspark Aircraft - Electric - Airplanes (FS/W) 2 Dec 19, 2003 05:19 PM
