This thread is privately moderated by pm1, who may elect to delete unwanted replies.
Old Oct 01, 2012, 07:59 PM
Ébeo is offline
Find More Posts by Ébeo
Três Corações - MG - Brasil
Joined Oct 2008
Mag swap roll and yaw in 5883L
Originally Posted by pm1 View Post
Check, if mag orientation is ok. check, if the copter in the gui follows exactly the direction of the copter!
Yes, it folow in left side of multiwii (compass) but on the right side (values of mag) the yaw and roll are swaped.
See video for better explanation
FC Crius SE Mag Error swaped yaw and roll (4 min 18 sec)
If I change the MAG_ORIENTATION in config.h nothing happens, continue the same.
If I change the MAG_ORIENTATION inside def.h the values are ok, but the right side on the gui show wrong compass.
My board is Crius SE 1.0 with 5883L mag.
I use #define Crius_SE in config.h
Search in web i found this http://www.diydrones.com/profiles/bl...o-diagnose-apm
Thanks for helping.
Ébeo is offline Find More Posts by Ébeo
Old Oct 06, 2012, 11:50 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Will this work with any GPS - I have a few 1590R (locosys) laying around.
Does anyone has the PINOUT for the I2C Nav Board on the FTDI solder pads?
The only descriptions are GRN on the left side and BLK on the right side which doesn't really help.
flyandi is offline Find More Posts by flyandi
Old Oct 06, 2012, 11:53 PM
flyandi is offline
Joined Aug 2009
Uhhh .. I think I am using the wrong board?! I got the I2C-GPS NAV Module ...
http://www.rctimer.com/index.php?gOo...2&productname=
Old Oct 07, 2012, 05:28 AM
pm1 is offline
pm1
Find More Posts by pm1
pm1
Germany, BY, Gestratz
Joined Oct 2008
It should work with any gps with serial connection with 5v level. But for nice operation the gps should be capable to make more than 1 measurement/s.
pinout:
It is exactly the same as for most other multiwii boards:
DTR,RX,TX,5V,CTS,GND
pm1 is offline Find More Posts by pm1
Old Oct 07, 2012, 05:38 AM
pm1 is offline
pm1
pm1
Joined Oct 2008
For Multiwii orientation look here:
http://www.multiwii.com/faq#How_shou...xis_directions
Your board is a "new" SE. I don't know the intended orientation, but with the faq you can modify here in def.h until it works as intended:
#if defined(CRIUS_SE)
#define ITG3200
#define BMA180
#define HMC5883
#define BMP085
#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = -X; accADC[PITCH] = -Y; accADC[YAW] = Z;}
#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = Y; gyroADC[PITCH] = -X; gyroADC[YAW] = -Z;}
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = X; magADC[PITCH] = Y; magADC[YAW] = -Z;}
#endif
Old Oct 07, 2012, 12:54 PM
flyandi is offline
Joined Aug 2009
So I uploaded the firmware posted in post #1 to the I2C Nav Board .. activated GPS I2C and also made the patches to the code as described in post #1.
Check the screenshot for results. It seems that the MW Board is receiving erroneous values.. it's all over the place.
If I disconnect the GPS, everything is back to normal.
Here is what I did:
- in config.h of i2c-gps firmware I changed the format to NMEA and 115200 bauds - GPS works on that.
Anyone know would could be wrong? Also I uploaded the firmware using the ISP header - is there a difference between ISP and FTDI upload? I am using a USBasp programmer.
Is there a way I can see the communication between the GPS and the I2C Board to the MW Board?
Btw, I am using the Quadrino as the FC.
Sorry I just got started in this world but learning fast :-)
Old Oct 08, 2012, 03:49 PM
pm1 is offline
pm1
pm1
Joined Oct 2008
Here is what I did:
1. Calibrate ACC
2. Firmware updates for Multiwii and nav board are done by FTDI, USBasp is only needed to flash a new boot loader.
3. How did you update the nav board?
4. At which connector on the FC did you connect the nav board?
Old Oct 08, 2012, 04:40 PM
flyandi is offline
Joined Aug 2009
1) ACC is calibrated. If I remove the GPS, I get perfect values.
2) I update the FC using the internal FTDI bridge of the Quadrino
3) I used the USBasp for uploading the firmware .. seems to work fine since I can put other code as well on it (e.g. blink example) :-) - I do not have a FTDI programmer here. I am using the same for my Nano boards.
4) Using the Quadrino I2C 3V Connector ...
Old Oct 09, 2012, 03:32 AM
flyandi is offline
Joined Aug 2009
Ok here is a sample frame from the GPS:
$GPGGA,072852.500,3306.0849,N,11711.4698,W,1,4,2.2 1,238.0,M,-35.0,M,,*61
$GPGLL,3306.0849,N,11711.4698,W,072852.500,A,A*43
$GPGSA,A,3,32,01,11,23,,,,,,,,,2.42,2.21,0.99*06
$GPGSV,4,1,13,32,79,005,29,31,51,043,,20,50,316,,5 1,50,162,35*7F
$GPGSV,4,2,13,01,43,238,34,30,36,129,21,23,33,287, 25,11,25,221,32*76
$GPGSV,4,3,13,16,18,155,19,14,08,072,,25,05,038,,1 3,05,268,*71
$GPGSV,4,4,13,22,04,129,*45
$GPRMC,072852.500,A,3306.0849,N,11711.4698,W,0.31, 123.73,091012,,,A*79
$GPVTG,123.73,T,,M,0.31,N,0.57,K,A*39
$PLSV,13,-8,0,35,30,4*0F
I sniffed the TTL traffic on the FTDI connector on the i2c-nav board and I got a connection to the GPS. Everything worked - even the LED recognized valid GPS signal, however the FC is still getting tons of i2c erros.
Old Oct 09, 2012, 03:36 AM
flyandi is offline
Joined Aug 2009
Ah damit - those chinese .. sorry ... they mixed up the board and reversed the SLC/SLA lines on the i2c interface of the board. I just switched the lines and bum it works!
Thanks everyone :-)
Old Oct 09, 2012, 03:47 AM
flyandi is offline
Joined Aug 2009
One thing .. firmware related: The LED brightness is really dim on the board. If I upload the Blink Example I get full brightness - so is that something that was set in the firmware? If yes, where do I find this?
Andy
Old Oct 09, 2012, 03:38 PM
pm1 is offline
pm1
pm1
Joined Oct 2008
Andy
Seems to be your board..., the LED on my board is not dim. The software does only switch it on for 150 ms, and then off again. No idea...
Old Oct 09, 2012, 03:43 PM
flyandi is offline
Joined Aug 2009
I wonder if there is not enough power for it. I am running the board on 3.3V - probably need to use the 5V I2C header.. but heck it works now - I got GPS hold - pretty awesome!
Old Oct 13, 2012, 04:58 AM
Mulder_ is offline
Find More Posts by Mulder_
FPV Pilot
Mulder_'s Avatar
Germany, NRW, K
Joined Jun 2010
i have the crius se, the crius i2c-serial bridge and the crius neo-06 all from rctimer. I followed the instructions in post 1 of this thread. I have the red LED blinking 100ms on, 1 second off so coms seem to work OK. only probem is that it stays like that, it will not get a 3d lock. i am testing this outside, should be no issues finding sats. any hints?
Mulder_ is offline Find More Posts by Mulder_
Old Oct 13, 2012, 04:38 PM
pm1 is offline
pm1
pm1
Joined Oct 2008
The blinking means, you get valid frames from the GPS. If you get no fix, try your GPS without i2c. Test it with your FTDI board with the ucenter software from the ublox web site. There you can see the reception quality...
Discussion FC I2C-GPS NAV Module jy0933 Multirotor Electronics 26 Apr 25, 2015 08:45 PM
Discussion CRIUS GPS with I2C little nellie Multirotor Electronics 74 Sep 18, 2014 12:31 AM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 05:03 AM
Discussion RC Timer GPS and I2C-NAV module for MWC Foam boy Multirotor Electronics 3 Jul 16, 2012 09:41 PM
Sold ArduPilotMega autopilot board, APM IMU Sensor Shield, I2C Magnetometer and GPS pilot006 Aircraft - Electric - Multirotor (FS/W) 3 Mar 13, 2012 06:07 PM
