Três Corações - MG - Brasil
Joined Oct 2008
GPS Position Hold dont work
Hello everyone and pm1.
I use the board CRIUS SE V1.0 with GPS-NAV and GPS uBlox. I soldered pins. I uploaded the new firmware for the card NAV. I configured correctly the file gps.ino (for pids) and the parameters related to the config.h gps even hit the magnetic declination (and others) in config.h. I did the calibration mag. The led in the NAV blinks 3x indicating positioning 3D and the software MultiWiiConf show location and from about 10 satellites. But anyway, I tried with several PIDs and does not hold position. Tried with pids standards and was increasing and then decreasing, gps hold woks inverse, on acc only is better. Tried with mag mag on and then off and the result are the same. The baro is disable. It simply does not work. See the video
In this video I try 3 times, when I say "GPS on" I move the switch for GPS Hold and wait, when it goes away I disable "GPS OFF". Please someone help me. Thank you very much (sorry by English) |
United States, MI, Fort Gratiot Township
Joined Apr 2011
Great thread. I'm sure with this instruction in this thread I will have it working in no time. I am a little stuck however.
I have had the Crius multiwii running 2.0. I just got my ftdi programer and had no problems doing the multiwii upgrade with the fc to 2.1. Problem: I added pins to the Crius I2c board and plugged it in and it seems to communicate appropriately, however when I upload the sketch it just stalls during the upload. Arduino program never errors, just shows uploading, and the fdti and i2c board blink. Like its flashing ok, but never finishes. Byte wise it seems to be about half of what multiwii 2.1 is so I don't think it should take all that long. Any guidance? I have worked thru other flashing issues in the past, but this is new to me. I have tried changing boards in the Arduino prog too. Thanks |
Joined Apr 2011
Walking away and coming back later apprently helped. I had the ftdi plugged in backwards. I thought I checked it a few times before. I have since been able to flash the Ic2 board.
One of the reasons I have no posts is because I can usually find what I need by searching around. I'm usually just a lurker. Anyways, Great group! Thanks! Scott |
Joined Dec 2010
I receive I2C errors
I got a lot of I2C errors.... i updated the 2 a version
![]() If i disable #define I2C_GPS in config.h the errors are gone... I didn't soldering the 14 + 15 pins. If i do that wil the i2c errors maybe gone? The GPS it self is working i got afix within 40 seconds.... |
Germany, BY, Gestratz
Joined Oct 2008
This problem has nothing to do with the gps module! - how does the i2c board blink? - which fc you are using? |
| Thread Tools | |
| Discussion CRIUS GPS with I2C | little nellie | Multirotor Electronics | 53 | May 16, 2013 12:44 AM |
| Discussion FC I2C-GPS NAV Module | jy0933 | Multirotor Electronics | 5 | Oct 07, 2012 04:58 AM |
| Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit | godwisper | Multirotor Electronics | 5 | Aug 25, 2012 04:03 AM |
| Discussion RC Timer GPS and I2C-NAV module for MWC | Foam boy | Multirotor Electronics | 3 | Jul 16, 2012 08:41 PM |
| Sold ArduPilotMega autopilot board, APM IMU Sensor Shield, I2C Magnetometer and GPS | pilot006 | Aircraft - Electric - Multirotor (FS/W) | 3 | Mar 13, 2012 05:07 PM |
