This thread is privately moderated by skydvejam, who may elect to delete unwanted replies.
Old Sep 03, 2012, 04:37 AM
skydvejam is offline
Find More Posts by skydvejam
Once you taste flight...
skydvejam's Avatar
United States, ME, Garland
Joined Dec 2011
Build Log
Cherokee Babe Project
I will be posting pics soon, but with my latest project about to go in the air, time to work on the next one, might do a SPAD during this, even more so if I find some servo's and a motor cheep, even better if it is a busted motor that I get to fix, just the way I am with the hobby.
This will be a little closer, and a possible lead up to my first full kit build that will lead to a scratch build.
Anyways I was given an older Cherokee Babe by one of the local fliers here, just happens to be the same one I bought my last project from.
Still debating servo's for her, as well as a covering scheme, been looking at pictures of the full scales for some ideas.
Going E-powered since it is about a .20 size plane so I will have a balsa park flier E-Flite 450 motor on the burner for her, going to have to test some ESC's 20 AMP is what is called for, I most likely will use a 30 AMP because I like a little overhead. 3S 1800 most likely will be the order of the day, figuring out the best way to mount is going to be a little challenge, but that is part of the fun.
First order of work is to remove what is left of the old glittery covering. It has some work to be done in the tail section, some of the sheeting needs repairing, and some new sheeting added. Then will be covering, and adding some scale details as well as motor, ESC, battery and servo placements, and how to connect the control surfaces.
Hinges look good, going to work on removing the pins, if I can do that then it will assist in removing the old covering and placing the new covering on easier, if not then I will re-hinge with real hinges not CA's, sorry easy is not better....
Anyways if nothing else I should get around to taking pictures on my days off coming up, as well as some starting on removing what covering is left not looking forward to working with that gooey stuff.
skydvejam is offline Find More Posts by skydvejam
Old Oct 05, 2012, 06:13 PM
fyrc22 is offline
Find More Posts by fyrc22
fyrc22's Avatar
United States, VA, Fredericksburg
Joined Sep 2008
Any progress on the Cherokee?
fyrc22 is offline Find More Posts by fyrc22
Old Oct 06, 2012, 02:43 PM
skydvejam's Avatar
Joined Dec 2011
Just some slow sanding and pealing, finding out it is a little less messy to do it slowly by hand, also drawing up plans for the rear...
I do have the sheets for the wings, might go ahead and start patching the breaks in there.
Old Nov 29, 2012, 07:39 PM
fyrc22 is offline
fyrc22's Avatar
Joined Sep 2008
any more progress? Has this become a winter project I have a few my self The OLY II, the Ultimate, the Sky Hawk.....need I say more
Old Oct 02, 2013, 08:33 PM
skydvejam's Avatar
Joined Dec 2011
Wow I have the power system, and I have been learning how to approach it properly. I almost have the glassing that I want to do figured out, just getting that tail right was harder than it first looked.
I have learned a lot and hope to complete her soon. Been doing a few scratch builds, and getting out of fuel planes, so I will have more time to dedicate to her, and she will have a nice power set up . Thinking I might want to lightly glass the wings though with the power I anticipate and make her not so much of a scale flier as a ballistic sleeper.
Cherokee Babe Project LPU fyrc22 Non R/C Items (FS/W) 17 Aug 19, 2012 09:42 PM
FREE Cox 049 Babe Bee Texaco ECT Widow Needle Valve Spring engine049 Non R/C Items (FS/W) 5 Mar 25, 2012 01:11 AM
Help! Moding Kyosho Piper Cheroke Minium omer921 Electric Plane Talk 2 Dec 22, 2010 04:25 PM
Discussion Herr Piper Cheroke set up tips fasteststang 1/2A Planes 2 Apr 27, 2009 07:49 PM
Discussion kyosho cheroke/4ch post your mods b36roxs Scratchbuilt Indoor and Micro Models 6 Dec 24, 2008 10:07 PM
