http://www.wowhobbies.com/cb180zparts.aspx is where I get my parts but it does seem that these are black in their inventory. http://www.bananahobby.com/wk-ak-26-80395-prd1.html Here it is... in red with the bearings for $3.45. At least parts for this heli are cheap! |
A bent flybar will cause a bit of shake. I normally bend it back in shape many times before I replace it. If you want it to be perfectly smooth, change the flybar, put a brand new main gear in, if it has any damage at all. Smooth and balanced make these things way easier to fly! |
Trick for Changing Tail gears
If you aren't going to do the belt upgrade and you are going to keep changing these gears, here is a trick we learned from Levi the Kiwi CB180Z mechanic...
When you are trying to remove either the front or the rear gear that is pressed onto the drive shaft, instead of pulling, cut it off carefully with side cutters. If you just pull, you are sure to pull it at least partially out of the other gear and you are at great risk of moving the center shaft bearing which is a real drag to reposition! I know this too well. ![]() Just cut off the damaged one and when pushing the new one back on, hold the other end with some sort of small, flat tool. Finger tips are a bit too soft sometimes and its a tight little area for fingers unless you have the tail off and in pieces. ![]() There is your CB180 tip of the day! |
I think its $14 or so...... Nope... I looked it up... you can get this gear for $4.99. Great price and another good cheap upgrade for the CB180Z!
Joined Jan 2012
May I offer an alternative. Since don't have the V460D01 skid this is what I did based on a suggestion. Get the Walera Lama 3 skid as it is a drop in replacement. Another little trick is to make a loop of music wire and attach it to the tail fin at the bottom with a pair of 2/56 screws/locknut. It can add additional clearance at the tail.
If you are learning have all 3 gyro setting on the RX set at about 60%. Just try hovering and figure out which way you are drifting, stop, adjust the swash or the rudder linkage a bit... all with the goals of keeping the trims on the TX in the middle. If they are really slight drift issues, do the adjustments in the TX subtrims. You get good at hovering and the bird gets perfectly set up. Do you have any shakes or ticks or is it all running smooth? If you have the extended servo horns and you find it too radical, you can either move the ball to the next closer hole in the horn to create less travel, or you can adjust the travel some on the RX. With too much travel, if you aren't ready for it, it can be a crazy, out of control flight. Its lots crazier than a stock CB180Z which flights hard to fly forward. |
Trick for Changing Flybars
If you have flown a CB180Z enough, you have crashed, broken blades and bent the flybar. Even the slightest bent will give you a vibration. If its a bad bend, it won't even spool up properly. If its not kinked, you can try straightening it out on the bird, if its worse, just replace it. When you first get into this, it looks like a tough change over... but if you do it this way... no sweat!
Although its tempting to try changing it without taking it apart, I suggest taking off the blades and the blade holders so that you get good access to the flybar bearings. It takes 2 minutes and makes the process so much easier. After you take the 2 screws out, the flybar will still be locked in place with the 2 bearings. Use a small flat screwdriver to softly nudge them out from the inside. If you pry a little on each side, they do pop out. Putting it back together is the same in reverse. Remember that the visable little bearings go to the inside of the flybar housing! Watch you don't over tighten the screws. Its just plastic and it will strip. Too tight and it will restrict flybar movement. There you go. I think the whole thing takes 10 minutes if you do it this way. I have mucked around for 30 minutes trying to get those bearings out without taking the blades and holders off! There is your repair trick of the day! I'm sure others have found even quicker ways, but this is what I'm doing now. |
Well, I'm actually using the stock tail servo right now on my CB180Z, but its a plastic geared toy! Until I needed it on another heli, I was using the one from my V450D01 which is much better. However, its heavy and expensive. I'd be interested in finding better servos for all of them in this machine. I have killed a few in crashes and I don't have anything left here that will fit the EV and AL servo positions. Has anyone changed these over to something better? |
| Thread Tools | |
| Discussion Walkera CB180Z parts V200D01 | Shazlee60 | Electric Heli Talk | 6 | Aug 24, 2012 06:59 PM |
| Wanted Looking for Align TREX 500 Tail Boom & Tail Boom Case Belt drive | Killer007 | Aircraft - Electric - Helis (FS/W) | 0 | Jul 12, 2012 02:48 AM |
| Found Looking for a Walkera V200D01 or CB180Z | turnberry | Aircraft - Electric - Helis (FS/W) | 3 | Jul 04, 2012 08:50 PM |
| Sold 2 Walkera CB180z's | og1974 | Aircraft - Electric - Helis (FS/W) | 0 | Jun 25, 2012 04:41 PM |
| Discussion help setup walkera cb180z tail | lightningzeus | 3D Electric Heli Flying | 1 | Jul 21, 2011 12:22 PM |
