Old Sep 30, 2012, 12:11 PM
United States, TN
Joined Mar 2011
What kind of rattle can paint might work best on the floats, I'm thinking I want to paint them silver?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Sep 30, 2012, 01:04 PM
Closed Account
Joined Apr 2008
If its epo foam most any brand.....testors, krylon etc. Just test a small area inside the battery bay or somewhere to make sure it doesn't react to the foam. Also apply very light coats especially of the first couple coats.
BrentP is offline Find More Posts by BrentP
T-28 Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Originally Posted by BrentP View Post
yikes, starting to get a little nervous about this bird. Not digging that bell motor for one.......
I want it and it's waiting at the LHS for me but I think wanting to replace the rx and now possibly the motor is putting me on the fence now about getting it.
Don't be nervous, its a 10 dollar motor. You should get it, fly it and and replace the motor for something else if it goes out. Its not going to go out for most people. You won't find a better flying plane for land and water.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 30, 2012, 01:05 PM
T-28 Fanatic
Joined Jul 2008
Yes, I can confirm its EPO.
Old Sep 30, 2012, 01:09 PM
Closed Account
Joined Apr 2008
Wow hasrh dude.......I knew the plane was epo well before your vid. Just letting the guy know if a plane is epo most paint works.
Unsubbed
Old Sep 30, 2012, 01:14 PM
T-28 Fanatic
Joined Jul 2008
My apologies Brent.
Old Sep 30, 2012, 01:16 PM
T-28 Fanatic
Joined Jul 2008
Thank you!
Tamiya makes great water based acrylic paints that you can airbrush. Once dry, you will not be able to remove it with water.
The silver is a great idea.
Old Sep 30, 2012, 02:08 PM
"special"
{}{steve}{}'s Avatar
United States, MA
Joined Sep 2011
I had a similar motor issue with my E-Flite Taylorcraft. If I eased the throttle all the way up it was fine. But, if I dropped the throttle and punched it, then it would bind. The problem turned out to be the ESC and its been perfect since I swapped it out.
{}{steve}{} is offline Find More Posts by {}{steve}{}
Old Sep 30, 2012, 02:14 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Originally Posted by SkylineFlyer View Post
No sweat dude, If your feelings get hurt that easy, maybe you need to find a new hobby.
That is uncalled for...
Old Sep 30, 2012, 04:25 PM
T-28 Fanatic
Joined Jul 2008
Alright, so it might not be the motor then. I've got extra ESC'S. I can put one in and let you know it it helps. Thanks for the help in troubleshooting.
Old Sep 30, 2012, 05:00 PM
Canada, ON, Toronto
Joined Jun 2010
Can anyone post a picture of the motor mount and mount point please?
GP73 is offline Find More Posts by GP73
Old Sep 30, 2012, 06:07 PM
T-28 Fanatic
Joined Jul 2008
Yep, I can get a photo for you.
Old Sep 30, 2012, 07:07 PM
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Skyline, could you post that motor/mount picture for all to see. Just curious to see how it's mounted. My Beaver should be here on Tuesday.
Tom Smith is offline Find More Posts by Tom Smith
Old Sep 30, 2012, 07:17 PM
T-28 Fanatic
Joined Jul 2008
Sure, I'll go get it now.
Old Sep 30, 2012, 07:48 PM
T-28 Fanatic
Joined Jul 2008
Alright, here are the photos. I also got a photo of the stock shaft showing the groove from the factory. This groove is right between the front bearing and the prop adapter. Its almost like they did this so that it would fail. There is no reason why a groove like this would exist.
As for the motor mount. Mine has down right thrust. Can someone confirm this with their model when they get it.
If anything, the way I crashed should have caused the motor mount to bend up and to the right. So when I took the mount off, I didn't keep track of the orientation on the mount. I could have accidentally put it on upside down, but then the thrust would have been down and left, correct?
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Electric Planes 14 Oct 16, 2009 02:03 AM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Fuel Planes 2 Jan 05, 2008 01:26 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Scale Airplanes 1 Dec 31, 2007 03:39 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Parkflyers 3 Dec 29, 2007 07:32 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Electric Planes 1 Dec 29, 2007 06:39 AM
