Old Feb 01, 2013, 01:25 PM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Ok now I'm scratching my head a bit because I want to have my Ailerons come down a bit as flaps but keep my Flaps on my 3 way position switch.
I have the DX7 and a 6 channel RX
I tried the flaperons mode but like that I loose my 3 position switch for my flaps as they end up on my Gear switch.
I tried to do some mixing but no luck .
Maybe someone in here would have an idea or has done it .
Cant keep scratching my head because I dont have much hair already
Paul-RC is offline Find More Posts by Paul-RC
Old Feb 01, 2013, 03:34 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
http://www.rc-soar.com/spektrum/index.htm
This is for crow settings (flaps down and ailerons up), but you could switch ailerons so they go down instead of up.
warhead_71 is offline Find More Posts by warhead_71
Old Feb 01, 2013, 03:43 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Very nice thank you
Now I need a 7 channel Receiver but at least now I know its possible
Old Feb 01, 2013, 04:01 PM
Stregax is offline
Find More Posts by Stregax
Stregax's Avatar
Sweden, Stockholm County, Vaxholm
Joined Jan 2013
Maybe a silly beginners Q, but : why do you need to do this ?
/ Hans
Stregax is offline Find More Posts by Stregax
Old Feb 01, 2013, 04:05 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
/ Hans
To be scale as the full scale Beaver
Old Feb 01, 2013, 04:18 PM
Stregax is offline
Stregax's Avatar
Joined Jan 2013
Ok Thats what I suspected...
Old Feb 02, 2013, 08:05 AM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Going to maiden my Beaver today!
Anything I should know? Haven't flown anything this large in a while.
microflitedude is offline Find More Posts by microflitedude
Old Feb 02, 2013, 08:17 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Cool!
Anything you should know?
Yes ........expect to have fun
Wheels or on floats today?
either way it fly's great
Good luck
Might fly mine today too
Old Feb 02, 2013, 08:43 AM
RCG -Minus Member
Joined Oct 2009
Got wheels on it for now, not brave enough to fly it off the pond out back yet.
I should probably mess with the flaps at higher altitudes until I get a good feel of how they work.
Old Feb 02, 2013, 08:47 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Yes climb a bit higher and try them, it will most likely pitch up a bit .
I did program some down elevator trim on both flap position.
Old Feb 02, 2013, 08:49 AM
RCG -Minus Member
Joined Oct 2009
I've got them plugged into the gear switch on the RX. Is there a better way to do it?
Old Feb 02, 2013, 08:51 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
What Transmiter are you using?
I use the Spectrum DX7 and AR600 RX the flaps are plugged in the AUX1 and I use the 3 position mode switch and flaps system act and feed in the values for the take-off and landing and the elevator values for each position.
Old Feb 02, 2013, 09:04 AM
RCG -Minus Member
Joined Oct 2009
Dx6i and a 6 channel RX. It has a flap toggle switch, but I don't know how/if that can be programmed to activate the AUX channel. I haven't really programmed much other than the basic stuff.
Old Feb 02, 2013, 09:11 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
I dont know the modes on the DX6i but if you have no 3 position switch you will only have 1 flap position anyway.
Maybe there is some programing possibilities in that DX6i to give some elevator values up or down when flaps are selected.
If not just dont drop the flaps at a fast speed and you wont pitch up too fast and maybe you wont pitch up.
Maybe others know this radio here.
Ok I'm going to fly now , hope the weather holds but its cold . might not fly much.
Old Feb 02, 2013, 09:27 AM
RCG -Minus Member
Joined Oct 2009
There are no knobs on the 6i, just toggle switches and a button. So the flaps would be fully deployed instantly, causing it to pitch up like you said.
Happy landings!
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Kit/Scratch Built 16 Jun 09, 2016 07:24 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Fuel Planes 2 Jan 05, 2008 01:26 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Scale Airplanes 1 Dec 31, 2007 03:39 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Parkflyers 3 Dec 29, 2007 07:32 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Electric Planes 1 Dec 29, 2007 06:39 AM
