Old Dec 30, 2012, 11:35 AM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
I am so jealous of you guys all flying off snow, but then again it will be 70* with no wind down here today....
greedyg76 is offline Find More Posts by greedyg76
Old Dec 30, 2012, 11:39 AM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Rub it in
Find a hockey indoor arena , usually they dump snow outside in the parking lot
Or better yet fly in the hockey arena on the ice with skis
Paul-RC is offline Find More Posts by Paul-RC
Old Dec 30, 2012, 11:49 AM
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Or better yet, just fly !
It's a little breezy up here in Ft. Irwin this morning....no flying
It was raining like cats and dogs yesterday as I drove by the Bass Pro Shop on the way back up the Cajon pass...the snow covered peaks look simply stunning
Justwingit is offline Find More Posts by Justwingit
Old Dec 30, 2012, 11:55 AM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
I live about 3 minutes away from Bass Pro. I might go up the canyon and try to get in some snowy mountain FPV today
Old Dec 30, 2012, 12:08 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Originally Posted by jpgilbert View Post
Finally got a chance to fly from snow with skis. Had hoped for powder but it was wind-sweep. Mainly touch & gos. Got in four flights and four with my E-flite J-3 25. Temps started at 12 degs and went up to 20. NO wind and that makes all the difference.
Cannot say enough about this plane. It just flies so good!
I usually do a lot of editing on the videos since I am using a non-zoom camera like Paul. I mount my GoPro on my head. No sense in showing a speck in the sky!
We got 8" of nice snow last night but quite windy today.
Joe
Nice video too. I can't tell from the video, how much if any flap did you have on for most of that? Looks nice and smooth at those slow speeds.
Aviefly is offline Find More Posts by Aviefly
Old Dec 30, 2012, 12:13 PM
Justwingit's Avatar
Joined Apr 2012
Now you're talkin' !
That would be awsome as long as the wind ain't whipping up those slopes...
Old Dec 30, 2012, 12:26 PM
FTA_FTW is offline
Find More Posts by FTA_FTW
FTA_FTW's Avatar
Joined Apr 2011
Great video Paul and jpgilbert! Awesome landings both of you.
I'm having trouble keeping the hook-loop tape stuck to the plane in this cold weather. How do you guys keep it stuck?
FTA_FTW is offline Find More Posts by FTA_FTW
Old Dec 30, 2012, 12:29 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Do you mean to hold the camera or for the Batt ?
Old Dec 30, 2012, 12:39 PM
jpgilbert is offline
Find More Posts by jpgilbert
MaineFlyer
jpgilbert's Avatar
Augusta, Me
Joined Feb 2005
Actually, I used the flaps very little on those flights. A few times on takeoffs and landings. I would be hard pressed to say which ones. The plane is a great flyer even without them. And I never did change the servo arm on the flap servo so they are pretty much just as received from the factory. I did notice that taking off on the water is better with a bit of flaps.
At the moment, my flap control is on the flap switch and I plan to modify it so it uses a slider on my radio also. The transmitter mitt I have is pretty tight when I use it on the DX-18. Be easier for me then. I have that setup on my Fun Cub. Now that plane has some flaps!!
Joe
jpgilbert is offline Find More Posts by jpgilbert
Old Dec 30, 2012, 01:02 PM
Stikflyer is offline
Find More Posts by Stikflyer
Nova Scotia, Canada
Joined Apr 2006
Originally Posted by King Pin View Post
I use the aurora 9 with the flaps on the left slider. I mixed in down elevator by using Flap Control (page 2) 100% flap to +28% elevator. This is actually down elevator. I also used a longer arm on the servo for more throw, hope this helps.
I did manage to get the flaps working on a 3 position switch "E" In Flap con menu I only get the option for switches A to H, no slider option.
Stikflyer is offline Find More Posts by Stikflyer
Old Dec 30, 2012, 01:07 PM
FTA_FTW is offline
FTA_FTW's Avatar
Joined Apr 2011
For the camera. It won't stick on the floats or the fuselage. It sticks the first time I apply it, then when I try to remove the camera, it comes off.
Nova Scotia, Canada
Joined Apr 2006
On mine I injected and then coverded with black silicone caulking , its very strong
Be careful if you decide to put some epoxy in this area. It would be a good idea to tape over the area after adding the epoxy and then place the plane in a upright position or the epoxy will just run out inside the fuse where your RX is located. DAMHIKT
Old Dec 30, 2012, 01:11 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
I guess the sticky side of the velcro is not of a too good quality.
My velcro is very hard to remove, I took one out and had to use heat to do it.
Old Dec 30, 2012, 01:12 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Thats sad, the caulking doesn't run so it was good to apply and its very strong.
Old Dec 30, 2012, 01:36 PM
MaineFlyer
jpgilbert's Avatar
Augusta, Me
Joined Feb 2005
My DX-18 is similar but I added a mix so the left slider will activate the flaps. I use a switch to activate/deactivate the mix. Sliders can tend to be easier to have in the wrong position and I want to activate the mix when I want to use it.
So I mix AUX4 (controlled by left slider by default) to FLP and the mix is activated by switch A. Requires you to adjust the mix offset and rate.
Hope this helps and doesn't confuse you.
Joe
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Kit/Scratch Built 16 Jun 09, 2016 07:24 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Fuel Planes 2 Jan 05, 2008 01:26 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Scale Airplanes 1 Dec 31, 2007 03:39 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Parkflyers 3 Dec 29, 2007 07:32 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Electric Planes 1 Dec 29, 2007 06:39 AM
