Old Sep 02, 2012, 06:42 PM
fvasileios is offline
Find More Posts by fvasileios
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Build Log
graupner multi jet boat
Hi there guys,
finally i bought that kit and kind of started building it...
i'll try to keep you updated with phootos....
fvasileios is offline Find More Posts by fvasileios
Old Sep 02, 2012, 06:52 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
any help/ideas appreciated...
any links of other build logs also appreciated
i also bought with the kit 2 600 graupner race motors and mos power 60
speed controller...
i started gluing some parts and i can say that they fit perfect...
Old Sep 03, 2012, 10:05 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
I WANT THAT BOAT....
Got enough of new kit's waiting for me to start building them, but last year when i saw Graupner intended to make this kit, i told myself i want it..... But it is a plastic boat = no fun to build...
I STILL WANT IT
Sharky1dk is offline Find More Posts by Sharky1dk
Old Sep 03, 2012, 02:07 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
I STILL WANT IT
I agree,no fun building a plastic kit but I believe that
This model is quite lot of fun running it...:-)
Old Sep 03, 2012, 02:42 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Yes and that's exactly why i want it...
Old Sep 04, 2012, 01:45 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
I hope for a test in my tube in the next few days
As I made some mixing configurations
On my transmitter today for the flaps....
Hopefully i'll come up with a video...
It's all I'm too busy from work and I can't
Move as fast as i would like...
Bill...
Old Sep 06, 2012, 01:33 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Hi there
I did some linkages today with my jets
I'll come with pics tomorrow...
I have one question
I connected my motors continuesly
with a 2s lipo.do they get battery's whole
voltage or the voltage is splitting?
Thanks a lot
Bill...
Old Sep 10, 2012, 03:23 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
hi there,
today i fitted servos for reversing flaps...
Bill.....
Old Sep 10, 2012, 05:01 PM
Guard-Officer is offline
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Looks like it will be a sweet running boat when finished. If you plan on running both engines on one speed control and you want speed, you will have to wire the motors parallel so that they both get 7.4 V from the 2cell LiPo. If you want to conserve your battery and can settle for slower, wiring in series will split the voltage in half between the two. Hope that helps
we don't see too many of these kits in Canada!
Cheers
GO
Guard-Officer is offline Find More Posts by Guard-Officer
Old Sep 11, 2012, 02:46 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Cheers
GO
Hi there GO
In parallel connection I use separate
cables from esc to each motor?if yes
then I'm in series.do I have to change
connection or I can add one more 4000
2s lipo to double my voltage?my esc can
handle up to 36 volts.
I hope it will run nice when finished.
I did some holes on the mast today for
the lights.i'll keep you updated...
We'll see together how it'll run in the
end......
Bill
Old Sep 11, 2012, 02:54 PM
Gimpdiggity is offline
Find More Posts by Gimpdiggity
Valiant Poultry
Gimpdiggity's Avatar
United States, MI, Jackson
Joined Apr 2012
Parallel would be each motor's positive and negative wires are connected directly to the ESC's positive and negative.
Series would be the ESC positive is connected to the positive of one motor, then that motor's negative is connected to the positive of the other motor, and the negative of that motor is connected to the ESC.
That's a cool looking boat, by the way.
Gimpdiggity is offline Find More Posts by Gimpdiggity
Old Sep 11, 2012, 05:15 PM
Joined Feb 2009
fvasileios;
Here is a quick example of how you would wire two motors for the same direction of rotation and to get the same voltage from the ESC. Each wire out from the ESC would be made into a "Y" and connected to the motor's. (If you want counter rotation, reverse the connection on one motor)
This setup will give better performance, but draw more amps through your ESC.
Cheers
G-O
Old Sep 11, 2012, 06:25 PM
6789boat is offline
Find More Posts by 6789boat
Model trains, Rc Boats, Rc air
United States, CA, SF
Joined Mar 2009
Nice boat, those are 600 Graupner motors right?
6789boat
6789boat is offline Find More Posts by 6789boat
Old Sep 12, 2012, 04:23 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
6789boat
yes 6789boat... actually they are 600 race....they sounded nice in some tests i did...
Old Sep 12, 2012, 04:29 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Gimpdiggity and GO
thanks a lot for your help...you cleared every questions i had in my mind about these connections...finally i can say that i connected them in parallel but in a different way.my esc wires are going to the first motor and then from the first motor's poles to the second..i 'm getting 7.4 volts on each motor in full speed...
Help! Graupner Portofino Classic Boat npdp72 Racing Boats - Electric 10 Sep 11, 2012 12:01 AM
Discussion Graupner Multi Jet Boat fvasileios Scale Boats 22 Aug 28, 2012 10:00 PM
Help! Graupner mini jet muccy Racing Boats - Electric 30 Mar 14, 2012 08:23 PM
Jet boat: Graupner Commodore for 23cc Zenoah zee Racing Boats - Internal Combustion 5 Sep 20, 2010 01:04 AM
For Sale Graupner Jet rescue boat "Hecht" JoeR1 Boats (FS/W) 0 Sep 23, 2007 05:04 AM
