Old Sep 02, 2012, 04:07 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
How to attach coroplast fins to epp
I am having some problems keeping my fin on my wing. What are you guys using to hold the fins on the wing. My FPV wing is about 2kg and they seem to be ripping off all the time. I have tried super glue, hot glue and expoy.
Oh even in soft landings they come off.
whakahere is offline Find More Posts by whakahere
Old Sep 02, 2012, 04:34 AM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
I use hot glue and it's worked fine on wings up to 1.2kg. I use 4mm symmetrical coroplast fins (meaning they're both above & below the wing). Care to share a picture of the fins on the wing?
hawkz is offline Find More Posts by hawkz
Old Sep 02, 2012, 06:51 AM
fnffishcore is offline
Find More Posts by fnffishcore
fnffishcore's Avatar
United States, MD, Chesapeake Beach
Joined Jan 2011
I was having the same problem with winglets ripping off, especially when using hot glue. I forget where I had seen this method (I think a Ritewing video), but what I started to do was tack the winglets on with hot glue and then spread a bead of Goop around the entire joint where the winglet meets the wing. Comes out rock solid and I haven't had a winglet rip off since.
fnffishcore is offline Find More Posts by fnffishcore
Old Sep 02, 2012, 07:33 AM
mdennis is online now
Find More Posts by mdennis
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Try gluing a couple of 1" to 1 1/2" pieces of 3/8" diameter dowel rod into the end of your wing. Then use a screw in each to hold the tip on. I use a bamboo skewer pushed into the coroplast to stiffen it, but you can just glue it on like before.
mdennis is online now Find More Posts by mdennis
Old Sep 02, 2012, 11:29 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
thanks guys. I have ended up trying screws and hot glue. I will see how this works out.
Old Sep 02, 2012, 12:38 PM
Stone1295 is online now
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
I cut an oversized slit in my fin and then feed Extreme Tape through it and tape it to the wing. Wrap the tape through the slit so it can be taped on both the top and the bottom of the wing.
You'd need 2 slits if the fin extends both above and below the wing.
-Mike
Stone1295 is online now Find More Posts by Stone1295
Old Sep 04, 2012, 04:55 AM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
i use hk's blue velcro.. im amazed mine didn't come off yet :P
on other wings I have often used goop-like/por-like glues. those hold well.
hotglue is great in many cases, but for winglets, not so good, since it has nearly zero flex (ca being equally bad)
CrashMeUp is offline Find More Posts by CrashMeUp
Old Sep 04, 2012, 06:29 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yea I found that hot glue or CA just didn't work. Epoxy doesn't work either. I had to use hot glue top even the surface after cutting off my old winglets (they were half off anyway) I used hot glue to level the surface. I also have two plastic screws each for the winglets. later in winter when hot glue fails I will glue the winglet on with uhu por and bolts.
Thanks again guys.
Old Sep 05, 2012, 12:14 PM
flymess is offline
Find More Posts by flymess
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
depends what your wings are made from. I use small cable ties to attach coro tips to coro wings. Then some hot glue. If the hot glue fails the tips will stay on. they'll have some flex but will still do the job until you land.
just noticed its about epp wing. cable ties might tear through EPP
flymess is offline Find More Posts by flymess
Old Sep 06, 2012, 10:40 PM
galognu is online now
Find More Posts by galognu
galognu's Avatar
United States, NY, Jamestown
Joined Dec 2004
Best way in my opinion is the way Jeremy of Ohio Combat taught me. Use the hollow yellow plastic pushrod, (forgot the actual name/manufacturer), then place a screw through the coroplast into a small section of the pushrod that has been imbedded and hot glued. Just like using plastic anchors on drywall.
galognu is online now Find More Posts by galognu
Old Sep 07, 2012, 01:39 AM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
There are lots of different types of hot glue and many different guns. With epp and coroplast winglets use high temp. Low temp just doesn't cut it.
Lammergier is offline Find More Posts by Lammergier
Old Sep 09, 2012, 05:34 PM
HighwayChild is offline
Find More Posts by HighwayChild
Joined Nov 2010
I also use 2 slits in the wing tip, with folded over extreme tape pushed through as a strap, then tape that onto the surfaces of the wing. It's stronger than the wingtip itself and doesn't add weight. Plus won't damage your model if u have a bad crash.
HC
HighwayChild is offline Find More Posts by HighwayChild
Old Sep 09, 2012, 09:56 PM
Piledriver is offline
Find More Posts by Piledriver
almost slackin
United States, MO, St Peters
Joined Dec 2005
Goop, strong enough without being brittle.
Piledriver is offline Find More Posts by Piledriver
Old Sep 10, 2012, 06:16 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yea .. hot glue and bolt while stronger ... not strong enough
I'll use some of the ideas above.
Old Sep 10, 2012, 02:27 PM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
What I do is cut a couple of 1/4" dowels about 1" long for each wing tip. I embed them in the wing tip with about 1/4" sticking out using hot melt glue. I then drill matching holes in the fins. Finally, I use the slit and strapping tape method to hold the fin on. The idea is that the dowels keep the fin from moving around, so the tape holds them on. So far, it's worked really well.
michaelingp is offline Find More Posts by michaelingp
Idea Attach fin to plank ddashk Foamies (Scratchbuilt) 4 May 14, 2012 01:48 PM
Question How to attach winglets/fins? RobinBennett Flying Wings 18 Aug 14, 2010 10:06 PM
Discussion How do you guys attach your fins? tekrunner Flying Wings 7 Sep 10, 2009 08:12 AM
Question How do you guys attach your fins? Skycruiser Flying Wings 16 Sep 10, 2007 10:13 AM
Discussion How do you build an aero EPP tail fin? Kahnx Slope 2 Jun 22, 2007 12:41 PM
