Old Sep 02, 2012, 03:53 AM
glazzies is offline
Find More Posts by glazzies
United States, CA, Torrance
Joined Feb 2012
Build Log
#6 Model Airplane Building Clinic >> Mountain Models Lucky ACE <<
I am starting my build log for my Mountain Models Lucky Ace. I am participating in the Building Clinic started by Murocflyer (Frank) which can be found here.
I have started to build a couple planes when I was a kid (20 years ago), but never finished them, so consider myself a newbie at building. I will update this thread as often as I can, and try to take as many pictures as possible.
Let's start with a clean workbench, a stack of balsa and some hardware!
glazzies is offline Find More Posts by glazzies
Old Sep 02, 2012, 04:10 AM
glazzies is offline
Joined Feb 2012
I completed steps 1-5 and on step 6 already ran into a question. The kit came with 1 magnet. Step 5 clearly states to glue it into the hole inside the hatch that I made in step 4. Step 6 states to follow the hatch lock assembly instructions located on the plans (see picture below). Step 4 of those instructions has me putting something into the space created which is what will interact with the magnet to keep the hatch shut. The issue is that I do not know what to put there. I have all the parts per the parts list, I went through everything first thing and checked off items. I was actually missing 2 of the 6 blind nuts (Mountain Models is taking care of me, good service). Do I put another magnet? A piece of metal? The only thing that it might be is that there is a #4 washer that came with the kit and was listed in the parts list. It seems a little too big to go there. I do not recall if I could find anywhere else in the instructions where it was used (I read through them twice but that was a few days ago). The washer would probably go in with just a little pressure (which may have been intended in order to keep it in along with some CA). The washer would also do the job, but I hate not knowing (by the instruction telling me exactly what goes there and not just a picture that does not look like a washer).
What goes there?
Old Sep 02, 2012, 06:22 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
It looks to me like the magnet was to be glued to the crutch not the hatch and that possibly the washer is glued to the hatch.
Welcome to the wonderful world of model building.
It will both bring you joy and drive you nuts.
Joe
Joe
Thermaler is offline Find More Posts by Thermaler
Old Sep 02, 2012, 10:58 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
That little #4 in the circle "should" correspond to whatever item is #4 on your inventory list. If not, I'm pretty sure a washed goes there. I just built a Switchback and it used the same hardware, magnet and washer, to hold the canopy on. The washer was glued to the structure and the magnets on the canopy.
And if you want to be certain, you can always wait and glue the washer on last. That way you will know for sure.
Hope that helps,
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Sep 02, 2012, 02:03 PM
glazzies is offline
Joined Feb 2012
Hope that helps,
Frank
Thanks. I will just wait until the end. The parts list does not specify what it is, I am sure it is the washer at this point but will wait to make sure.
Thanks again!
Old Sep 02, 2012, 09:31 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
So when you glue the washer on, rough it up with some sandpaper first. The glue will stick better to all the little grooves created by the sandpaper.
JimTMich is offline Find More Posts by JimTMich
Old Sep 02, 2012, 09:40 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
I would add that you should also do a final cleaning using industrial alcohol prior to gluing.
loNslo is offline Find More Posts by loNslo
Old Sep 02, 2012, 09:51 PM
buzzltyr is online now
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Glazzies, I just finished building my second ACE: http://www.rcgroups.com/forums/showp...&postcount=591
I glued the magnet to the hatch, and the washer into the support glued to the firewall.
As this build is a recent one, if you have any questions, don't hesitate to shoot me a PM. I'll try and follow this thread as well.
Mark
buzzltyr is online now Find More Posts by buzzltyr
Old Sep 02, 2012, 10:19 PM
Murocflyer's Avatar
Joined Nov 2005
Thanks for helping out Mark. It's great to see folks stepping up to help.
Frank
Old Sep 02, 2012, 11:59 PM
glazzies is offline
Joined Feb 2012
Mark
Thanks, yours looks great! I am still trying to figure out what color and design I am going to do for covering. Thinking about a single color for covering with some trim tape for design and oreintation purposes.
Thanks!
Old Sep 03, 2012, 03:50 AM
glazzies is offline
Joined Feb 2012
I am not sure exactly how long this took, but it felt like no time at all. It could have been more than 2 hours, but I would be surprised if it was. This is a very easy straightforward build so far (great for a newbie like me). The fuselage is done!
And as you can see I put the washer in and it works great.
Old Sep 03, 2012, 12:56 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Thanks!
glazzies, your fuselage looks great. Yes, MM kits build quickly. I have frequently suggested that builders "savor every moment of the build" because it is over so quickly.
My first ACE was transparent yellow on the wings and tail, with a red fuselage. When I did the second one, I did not want to use transparent again. While it looked great, I did have issues with determining orientation. So the second one got the checkerboards on the top and the white stripes on the bottom. This one I can see clearly, even at a distance. It never hurts to have contrasting colors top and bottom, along with stripes, roundels, patterns, etc. on one side. I'm older, so having a clearly distinguishable top and bottom really helps with orientation. The ACE does all the acrobatics my thumbs can handle, with the exception of knife edge. I've done inside and outside loops, rolls, spins, vertical 8's, square loops, lots of inverted, immelman's, cuban 8's, stall turns, etc. with mine. So orientation is important to me.
Mark
Old Sep 03, 2012, 12:57 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Frank
Thanks, Frank! I do appreciate all your effort to get this effort underway. I'll help in any way I can!
Mark
Old Sep 03, 2012, 01:30 PM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
Looking good. Nice pictures as well.
Jim
Old Sep 03, 2012, 01:34 PM
glazzies is offline
Joined Feb 2012
Mark
Your telling me... I stayed up a little later last night (this morning) and nearly finished the wing. I dry fitted most of it but decided to wait to glue today when I am more awake. I will post more pics later.
Cool Model Airplane Building Clinic ~ Building A Kit Murocflyer Parkflyers 484 Mar 14, 2013 03:37 PM
Cool Balsa Model Airplane Building Clinic Murocflyer Beginner Training Area (Aircraft-Electric) 12 Sep 12, 2012 03:01 AM
