Old Jul 19, 2001, 08:15 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Beware of Great Planes Magic Magnetic Building Board System
I put this here rather than "Consumer Advocacy" because it's more of a tip than an issue and I think people read this group more often. Of course you can move it if you see fit Andy.
IMO, it's big bucks ($130) and I thought long and hard before buying it, but I believe it's a good system. The problem is that it isn't a building board. It's a sheet of heavy metal that bends. I figured that for the price it would at least be laminated to some particle board or have an aluminum frame so that it would be perfectly flat.
As far as I'm concerned flatness is one of the defining characteristics of a building board. If I'd known I'd have to scrounge around the house, remove a sliding closet door from a "storage" bedroom and then put the two layers of cardboard the "board" came in between the "board" and the slightly wavy door to get it perfectly flat, I might not have bought it.
Now that it's all set up I'm glad I have it, but I wanted to warn prospective buyers that you'll need to already have a perfectly flat surface in order to use it.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Jul 19, 2001, 09:05 AM
Alan W is offline
Find More Posts by Alan W
Alan W's Avatar
NY
Joined May 2000
Building boards ?? One word....
HOMASOTE !!!
Alan W
Alan W is offline Find More Posts by Alan W
Old Jul 19, 2001, 10:00 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
RB
Now that's what I call a real determined Model Builder!
GregG is offline Find More Posts by GregG
Old Jul 19, 2001, 10:33 AM
mml4 is offline
Find More Posts by mml4
Joined Jul 2001
Hi! I bought my magnetic building board many years ago (at a model show) from it's inventor Eldon J. Lind. I tried to use it and had the same complaint you did! It languished under my bench for YEARS until I got angry at a fuselage warp induced by my then current building board.I bought a granite kitchen counter top from a display that was being taken down at a store($350.00).I placed the metal sheet on top of the granite. BINGO!!!!!! Everything I build now is dead on straight! Iknow the investment is a lot in terms of dollars but the results are well worth it. With the use of the various presses and holders available for the magnetic board it's akin to building models in a fixture. You assemble everything using the magnets and when you are satisfied you just glue it up with your favorite adhesive. Ifind I am building lighter as well.
[This message has been edited by mml4 (edited 07-19-2001).]
mml4 is offline Find More Posts by mml4
Old Jul 19, 2001, 10:38 AM
AerodromeRC is offline
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
I made up my own using a hollow core door and contact cemented galvanized sheet metal to the top (Home Depot). I supported the door with 2 saw horses. The whole top surface is a building board. I found good and low cost magnets at a craft store(Crafts Unlimited). Makes a fantastic building surface and it is flat. Haven't used pins on my last dozen models.
Kurt
AerodromeRC is offline Find More Posts by AerodromeRC
Old Jul 19, 2001, 01:00 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I didn't buy a magnetic board for the reasons stated above. I had thought about getting one because I had used an original Magna-Jig that my college room-mate had back in the 60's. That board was like a piece of boiler plate - you'd have to hit it with a sledge hammer to flex it. The ones I've seen are nowhere near the integrity of that board/jig.
WRT sliding doors, etc. The bottom of a dresser drawer makes a good flat work surface. If you check the bottoms of the dresser drawers in motels across the country, you'd find a lot of Xacto knife cuts and puddles of glue and dope from models built/repaired/prep'd the night before a contest.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Jul 19, 2001, 01:48 PM
Newark, DE USA
Joined May 2001
Ah, the joys of being single.
At least I didn't cut it to fit it's new use better. That was only because I didn't know what I'd find inside.
RB
Old Jul 19, 2001, 08:13 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
- Roger
One of my most serious blunders was abandoning my Magna-Jig board when I came out to the land of fruits and nuts 40 years ago.
Still have most of the magnets, which come in handy, but sure miss that flat stiff heavy board!.
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul http://www.angelfire.com/indie/aerostuff
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 19, 2001, 10:24 PM
ninpofox is offline
Find More Posts by ninpofox
United States, OH, Franklin
Joined May 2001
I have been using mine for years and love it. I do all my building on a solid, old drafting table. It did take a while to get accustom to it though.
Bob Fox
ninpofox is offline Find More Posts by ninpofox
magic magnet building board system jojo Electric Plane Talk 16 Jul 27, 2008 11:29 PM
Found WTB: Great Planes Magic Magnet building board turbojoe Aircraft - General - Miscellaneous (FS/W) 3 Aug 29, 2006 09:55 PM
Great Planes Magic Magnet Building Board cdw3423 The Builders Workshop 20 Feb 16, 2005 12:18 AM
Great Planes' Pro Building Board Scott C The Builders Workshop 2 Dec 03, 2002 10:15 PM
Great Planes Goldfire Motor System Allan Wright Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2002 11:53 PM
