Old Sep 09, 2012, 09:26 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Ahhh.. Great.. Thank you gentlemen.
The Hobby B photo's, with their total lack of reference scale, make it look just like the adh300 Don's wicked motor which is 23mm diameter.
Clearly then it is not one of those.. it seems to be it's baby brother.
Too bad, as I have a couple needing homes.
Bare is offline Find More Posts by Bare
Old Sep 14, 2012, 07:16 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
The more I fly this, the better I like it. Compared to the ELERC A-10, this behaves much better with a much lower amp draw. This one will fly inverted with great control where the ELE is not happy inverted. the 2s 800 mAh 40C gives pretty long flight times when you cut back to about half throttle and cruise around. I wish my pair of motors were a little better matched, the harmonics between the two are a little loud, it's evident one motor is a little faster than the other, as I can put just a little drag on the motor bell of the faster one and they match right up in speed. Oh well, not a big issue but matched motors would make the package really sweet. I have a really good pair in my F-15 and it's simply awesome, especially on 3s.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 16, 2012, 12:12 AM
Tom77 is offline
Find More Posts by Tom77
Joined Feb 2009
I decided to get one of these and it just came today. It looks really nice. I have the ESCs to convert it to 3S, but was thinking of trying it on 2S first. Joe, am I reading correctly that you still run yours on 2S? (and you must be happy with it?) I have some 800mah 2S batteries.
Tom77 is offline Find More Posts by Tom77
Old Sep 16, 2012, 12:14 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Yep, pretty satisfied on 2s. There isn't much vertical performance, but for all other situations, the power is suffecient. The speed is decent, enough power for loops, some limited vertical, rolls, inverted, etc. Full throttle isn't necessary once you're in the air, 1/2 to 2/3 throttle gives good flight times. Just know that with an 800 mah pack, you will need extra weight in the nose for the correct CG of 20mm back from the wing to fuse joint.
Old Sep 17, 2012, 03:54 AM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
In the vid you can hear one (?) fan make an unhealthy sound.
I recognize this from my 35mm Skyangel fan. I balanced it using the method NitroCharged described in a dedicated thread. It's a bit less now but I've got no clue what the problem is?
Maybe bearings or..?
Thanks for reviewing the Thunderbolt!
RNAF is offline Find More Posts by RNAF
Old Sep 17, 2012, 06:38 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Any time that one fan turns faster or slower than the other, there will be harmonics that can be pretty darned loud. Each fan by itself is quiet, when spooled up together it is obvious that they are not quite in sync. That and the A-10 nacelles aren't as thick as the fuse in the F-86 or Mig so there is less sound dampened. Since I pulled these fans from the Mig-29, the same sound was apparent in the mig, it just wasn't as loud. The F-35 does the same thing at lower throttles but on 3s and three blade fans, the harmonics essentially are a much higher frequency and are pretty much inaudible at wide open throttle. Evidently getting matched motors is much harder the higher the KV you have.
Old Dec 16, 2012, 07:05 PM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
Hey Brother
What's your wattage on 2S?
Know it might be in one of these many threads but I got a A-10 and F-29 that I
trying to get into the air soon and wanted to get some new batteries that will fit.
Thanks for your help on the 50mm jet thread also
Larry
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Jan 16, 2013, 10:41 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by SPEED-E-FLYER View Post
Hey Brother
Larry
I'll need to put a meter on it. On 3s I get roughly 14.5A, no doubt that 2s will be noticeably lower.
Old Apr 06, 2013, 02:26 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Finally, a video of the A-10 stepped up to 3s lipo. What a monster now! I would have to say that vertical authority is stellar for a micro EDF. I can just cruise around at less than half throttle, punch it and pull straight vertical until out of sight. This little beastie is a hoot.
A-10 35mm modified (1 min 59 sec)
Old Apr 11, 2013, 09:16 PM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
great vid/info
thanks for doing.....
Q . I got a guan li -eps (lightweight and old) 64mm A-10
do you have any suggestions for me / It ...
I was thinking with the improved EDFs ( dr thrust units?)
that a 50 mm rework of nacels might make a much better looking (scaleish )
unit and still fly well on 3s 2200 s I like lite craft
any thoughts you care to share would be appreciated.
thanx
K9
K9000wner is offline Find More Posts by K9000wner
Old Jul 09, 2014, 06:05 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Joe,
What ESCs do you use?
Gene K
speedy01 is online now Find More Posts by speedy01
Old Jul 10, 2014, 08:37 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
A pair of Turnigy plush 10 amp or hobbywing pentium 10 amp for 3s voltage. If 4s, you need a 12 amp.
Old Jul 10, 2014, 10:00 PM
Gulf Breeze, FL
Joined Jul 2006
A pair of Turnigy plush 10 amp for 3s....
Thanks, Joe. Appears these kits are getting hard to find. I may try to get another one to paint in European camo ... and repaint my "desert" in gray.
Is yours still flying strong?
Gene K
Old Jul 14, 2014, 08:30 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Gene K
It would be if my lipos weren't toast. I actually have a couple of them. One on 2s with landing gear and a belly flopped on 3s.
Old Jul 15, 2014, 01:13 PM
ChickenDrumstick is offline
Find More Posts by ChickenDrumstick
ChickenDrumstick's Avatar
United Kingdom
Joined Jan 2013
Can you still get the A-10?
ChickenDrumstick is offline Find More Posts by ChickenDrumstick
Data CG specs for the 35mm EDF jets by Jpower, Skyangel, Blitzrc, etc. and FAQs Joe 1320 Micro EDF Jets and Power Systems 5 Mar 30, 2016 01:54 PM
Mini-Review F-15 Eagle twin 35mm EDF by Skyangel / Jpower Joe 1320 Micro EDF Jets and Power Systems 60 Aug 25, 2015 08:37 AM
For Sale Sky Angel/Jpower 35mm A-10 EDF PNP pick up in New York xzd Aircraft - Electric - Jets (FS/W) 1 Jul 21, 2012 03:51 PM
For Sale Skyangel/JPower 35mm EDF Jet Nano MIG29 PNP(ARF) hobbyeasy Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2012 10:14 AM
For Sale Skyangel/JPower 35mm EDF Jet Nano A10 Warthog PNP hobbyeasy Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2012 10:04 AM
