Old Sep 10, 2012, 07:35 PM
Joined Feb 2012
Originally Posted by Dezader View Post
Im thinking of buying a new fc for my quad, should i get KK 2.0 multiwii v1 or multiwii v2 ? Im doing both acro flying and sometimes theres also a cam onboard. What should i get?
Some info here regarding V1 and V2 http://www.rcgroups.com/forums/showt...7#post22688457
Post 2792
Flying By is offline Find More Posts by Flying By
Old Sep 10, 2012, 07:37 PM
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Quality aside, get multiwii. It has more tunability (PID) where the KK board uses simple gyro gain. Also has options for other sensors
zanek is offline Find More Posts by zanek
Old Sep 10, 2012, 07:58 PM
beginning night flyer
RCpilotwantabe's Avatar
Anacortes,WA
Joined Dec 2007
hey guys i just got my board and set it up according to:http://www.hobbyking.com/hobbyking/s...X178383X15.jpg
but im not getting any pitch/roll response. anyone else experiencing this?
RCpilotwantabe is offline Find More Posts by RCpilotwantabe
Old Sep 10, 2012, 08:34 PM
Joined May 2006
Did you install and set up the audrino firmware ?
skizziks is offline Find More Posts by skizziks
Old Sep 10, 2012, 08:43 PM
Anacortes,WA
Joined Dec 2007
yes i believe so, but ill try again
Old Sep 10, 2012, 09:20 PM
Anacortes,WA
Joined Dec 2007
installed again and rechecked every setting, still no roll/pitch
Old Sep 20, 2012, 02:38 PM
Joined Sep 2012
Have you already tried the ino file, under the files tab on the hobbyking site?
streamteam is offline Find More Posts by streamteam
Old Sep 22, 2012, 12:04 PM
Austria
Joined Jan 2004
Originally Posted by zanek View Post
Because the multiwii board doesn't have enough power to process the serial output of the gps. You need a i2c gps. What that does is it is a gps reciever with a atmel processor connected so it ouptuts a preprocessed signal, so it doesn't overload the main FC
Or you could just get this http://www.hobbyking.com/hobbyking/s...PS_Module.html
False
Gps can be connected directly, no gay i2c board is needed
I hacked mulitiwii 2.1 wthout much problem for do it
The trick is that on tge air you don't really need the serial guistuff
Tchuss
E_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Sep 22, 2012, 12:06 PM
Austria
Joined Jan 2004
Kk2.0 is very easy to configure
Multiwii is more flexible, but if you don't care of gps or baro or magnetometer, kk2.0 is better
Tchuss
E_lm_70
Old Sep 27, 2012, 09:09 AM
Agressive driver
Joined Jun 2011
Tchuss
E_lm_70
Yeah. Multiwii is plug and play, with 1 adjustment for the gyro on that axis. Multiwii is a little less plug and play, and uses a PID loop. So it really depends on wether you want more features and adjustability or just plug and play
Old Oct 01, 2012, 05:46 PM
www.ParkFlySac.com
subaru4wd's Avatar
United States, CA, Rocklin
Joined Aug 2012
Does anyone know if this board will run MegaPirate?
subaru4wd is offline Find More Posts by subaru4wd
Old Oct 02, 2012, 10:23 AM
Austria
Joined Jan 2004
MegaPirate as far as I know need a bigger ATMega chips ... with multiple serial ports (but this is a details) ... but it require bigger memory then 32kb of Flash.
Still MultiWii, can be used for import some MegaPirate functions ... as soon I'm happy with GPS holding, I will add some basic navigation on MultiWii 2.1 ... my version is only 25k ... so I have 5k free for add some stuffs ... and in 25k I have already the GPS support over the stock serial interface ... without the need to use a i2c gps board
Tchuss
e_lm_70
Old Oct 02, 2012, 11:55 AM
United States, NM, Santa Fe
Joined Mar 2005
I have two questions about my HK MultiWii V2 Board
Q#1 - When I run MultiWii Conf 2.1, I get Semi Flat output line data for about 30 secs after Calibrating (Acc & Mag)...then all of a sudden the lines shift.(see below):
Description: Calb Shift mid scale
Is this a normal occurance?
Q#2 - When I do a Field Calibration (rt stick pulled all the way back & Throttle to lower left corner) shouldn't I see that calibration occur on the screen while running MW Conf?? If so what am I doing wrong?
I have had 2 flights with very dissapointing results...especially when I turn on Alt Hold. Copter heads to the ground.
I'm using HK MultiWii SE V2..with MW 2.1 software - in Tricopter Mode
lfield is offline Find More Posts by lfield
Old Oct 02, 2012, 03:33 PM
Joined Sep 2012
Multiwii 328P Flight Controller w / FTDI & DSM2 Port
Good afternoon srs, I bought this card 328p MultiWii Flight Controller w / FTDI & DSM2 Port. And I wonder what use wiring diagram for a hexa +?
http://www.hobbyking.com/hobbyking/s...g/27033(1).jpg
Sorry friends, I do not have much experience, but I am keen to learn.
Thank you.
robson.augusto is offline Find More Posts by robson.augusto
Old Oct 02, 2012, 06:08 PM
Austria
Joined Jan 2004
Thank you.
Yes you can handle up to 8 motors with this board
But, you will have to make/compile your own firmware from the multiwii 2.1 arduino code
Mainly you need to set the config.h file for match your multicopters and your wishes ... plus I'm afraid you need to create the definition of this board, since I'm not sure this is already in the list in the def.h file
Tchuss
E_lm_70
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Crius mini MWC MultiWii SE Standard Edition flight control board eyeinsky1 Multirotor Electronics 6 Mar 17, 2013 05:13 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 04:28 AM
Sold *NEW* MultiWii SE Standard Multicopter Flight control board+FTDI USB PRGMR+PID LCD beachflyer Aircraft - Electric - Multirotor (FS/W) 2 Sep 02, 2012 11:31 AM
Sold CRIUS MultiWii SE V2.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 4 Apr 19, 2012 12:06 AM
