Old Sep 01, 2012, 08:40 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
HobbyKing MultiWii SE V2.0 Flight Controller
A new MultiWii board from Hobbyking. Haven't seen them do a MultiWii board before.
It looks similar to a Crius.
http://www.hobbyking.com/hobbyking/s...er_w_FTDI.html
The Multiwii SE V2.0 is a gyro/accelerometer based flight controller that is loaded with features. With expandability options and full programmability, this device can control just about any type of aircraft. This is the ideal flight controller for your multi-rotor aircraft.
Features:
• Small size, 35x35mm mounting holes
• 6 input channels for standard receiver and PPM SUM receiver
• Up to 8-axis motor output
• 2 servos output for PITCH and ROLL gimbal system
• Can utilize a servo's output to trigger a camera button
• FTDI/UART TTL socket for debug, upload firmware or LCD display
• I2C socket for extend sensor, I2C LCD/OLED display or CRIUS I2c-GPS NAV board
• Separate 3.3V and 5V LDO voltage regulator
• ATMega 328P Microcontroller
• MPU6050 6 axis gyro/accelerometer with Motion Processing Unit
• HMC5883L 3-axis digital magnetometer
• BMP085 digital pressure sensor
• On board logic level converter
Flight mode:
• One of the following basic mode
- Acro
- Level
- Alt Hold
- Head Lock
• Optional mode
- HeadFree (CareFree)
- GPS Hold (Need GPS receiver + I2C-GPS NAV Board)
- GPS Return to home position (Need GPS receiver + I2C-GPS NAV Board)
Specs:
Dimension: 40mmX40mm
Height: 11.6mm
Weight: 9.6g
Fixing hole spacing: 35mm (It can be changed to 45mm by CRIUS Distribution Board)
Hole diameter: 3mm
Package content:
SE FC x 1
USB program board x 1 (Mini USB cable required but sold separately)
3Pin to 1Pinx3 cable 100mm x 2
3Pin to 3Pin cable 100mm x 1
More information can be found on the Multiwii Website.
http://www.multiwii.com
Erknie is offline Find More Posts by Erknie
Old Sep 02, 2012, 02:51 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
pffff....
.. 34$ Free Shipping
-> http://dx.com/p/mwc-multiwii-mwc-se-...d-black-149348
GPS -
-> http://www.rctimer.com/index.php?gOo...3&productname=
-> http://www.rctimer.com/index.php?gOo...2&productname= ..... I2C
even better, ... 256MB and better Baro "MS5611-01BA01"
-> http://dx.com/crius-all-in-one-pro-v...troller-149346
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Sep 02, 2012, 03:50 AM
Erknie is offline
Joined Nov 2011
Gee the price on MultiWii boards has come right down, I paid over $40 for my Crius Lite only 6DOF.
Old Sep 02, 2012, 04:08 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
blame yourself.
you can also purchase, 6DOF for U.S. $ 53.99
-> http://www.ebay.com/itm/170843651792 ...
or 10DOF for > $ 110 . . .
Old Sep 02, 2012, 04:23 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
it s a great thing to see more and more multiwii board (openpilot is never in stock and not really open source because we can t use an another hardware...)
i hope we could see a grown up communauty and perhaps more coder for multiwii!
titeuf007 is offline Find More Posts by titeuf007
Old Sep 02, 2012, 04:53 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
what is open pilot.
if it "FunFly controller Naze 32" are.
why wait ?
-> http://abusemark.com/store/index.php...f698efe32bfa21
-> http://www.rcgroups.com/forums/showthread.php?t=1595761
circuit diagrams and documentation, no problem.
-> http://code.google.com/p/afrodevices/wiki/AfroFlight32
Old Sep 02, 2012, 05:21 AM
Joined Jun 2006
yes it s true i forgot naze 32
i ve never had a deception with timecop product! good support and great quality
Old Sep 02, 2012, 11:46 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by JUERGEN_ View Post
pffff....
This is for a V2 board, and you are linking a $35 v1 board.
Find a V2 board under $45 and then report back to us.
AcroFPV is online now Find More Posts by AcroFPV
Old Sep 02, 2012, 05:31 PM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
I think a better choice for the BMA180.
unfortunately is no longer manufactured the BMA180.
Old Sep 02, 2012, 07:35 PM
NPu is offline
NPu
Find More Posts by NPu
NPu
Joined Jan 2006
So what are the updates of this V2 board?
NPu is offline Find More Posts by NPu
Old Sep 02, 2012, 08:04 PM
Erknie is offline
Joined Nov 2011
The V1 has:
·ITG3205
·BMA180
·HMC5883L
·BMP085
The V2 has:
• MPU6050
• HMC5883L
• BMP085
Old Sep 02, 2012, 09:37 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Nobody really cared what you think. You said we could find this board cheaper but then you posted the older version.
So...
Old Sep 02, 2012, 10:28 PM
kad is online now
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Ordered one yesterday. We'll see how it performs on a Hunter V-Tail Mini.
-K
kad is online now Find More Posts by kad
Old Sep 02, 2012, 10:30 PM
kad is online now
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
pffff....
After the horrible customer service, 2 month ship times and complete lack of data security, I'll never order anything from dx.com again. Beware one and all.
-K
Old Sep 02, 2012, 10:53 PM
Erknie is offline
Joined Nov 2011
-K
I had never heard of dx.com prior to this thread, I was going to ask about them, thanks.
Discussion Crius mini MWC MultiWii SE Standard Edition flight control board eyeinsky1 Multirotor Electronics 7 Sep 10, 2013 02:08 PM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 09:36 PM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 05:28 AM
Sold *NEW* MultiWii SE Standard Multicopter Flight control board+FTDI USB PRGMR+PID LCD beachflyer Aircraft - Electric - Multirotor (FS/W) 2 Sep 02, 2012 12:31 PM
Sold CRIUS MultiWii SE V2.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 4 Apr 19, 2012 01:06 AM
