Week 27: Paints and plans
Painting. Painted the side cabinets a toffee color to see how that looked. Might do the back wall the same. Then did the gold edging on the head rails. It really helps to blend the gold of the stem into the bow. Happy, happy. I also repainted the timberheads and knightheads brown to make the black of the swivel guns show up a little better.
Plans. Sanded down the tip of the forecastle deck so it can fit over the bowsprit. Still not sure how to attach the deck piece yet. Because of the more fragile figurehead I also need to have the bowsprit in place before I transport the ship. Meanwhile I'm trying to figure out how I'm going to get the rudder axel pin in place so it can be attached to the servo. I was able to file down the front edge flat like Dan suggested so I might be able to drill and then insert a setscrew. Got to see what sizes Loews has. Picture day namings. I figured now was a good time to take some more pictures with everything on board, including some with four newly named Theresa Maries. As a shout out to some friends and family, we now have Surgeon Gary, Midshipman Will, pirate girl (and suspected Viking princess) Astrid and Carpenter Carl.
Thanks again Dan. I mailed the stuff yesterday. Nope, don't have an ESC yet and haven't done any prep work for any of the electronics other than installing the servo mounts inside the hull.
Here's the info Rick included on the drive unit: "The unit only needs one thing; Oil the shaft and seal before and after every run. Regular petro motor oil will do fine. You need to get a bottle or syringe with a fine metal tube so it can fit in between the prop and housing. You can gently pull the propeller aft to help fit the oiler tube. "There are two O rings cast into the rear housing that are sealing the unit. They like to be lubed. Put some oil and run in forward and reverse for 10 seconds each to get it worked in. "Whatever ESC you choose it will need to be able to handle 12 volts @ 12 amps max. You may use lower voltage as the unit may be powerful enough with 7.2 volts. But inversely don't go over the 12 volt of the 3s pack. "The unit as tested pulled 7.5 amps at full load." I'll be using the Futaba 7C transmitter I got for my Beagle and probably the same Futaba transmitter. Per Rick's advice I also got a switcher and a second battery: Turnigy 4.0. |
| Thread Tools | |
| Discussion Syren, Brig, SC&H R/C Square Rigger, 1/24 scale | DanL | Scale Sailboats | 271 | Yesterday 01:40 PM |
| Discussion Prince de Neufchatel, SC&H 1:24 Scale Schooner | Capt.Crash | Scale Sailboats | 182 | Nov 16, 2012 01:11 PM |
| Video SC&H Brig - clip C | DanL | Dock Talk | 3 | Jul 23, 2008 12:01 PM |
| Video SC&H 1/24 brig | DanL | Dock Talk | 3 | May 27, 2008 11:47 AM |
| Video SC&H 1/24 scale mpeg | DanL | Dock Talk | 1 | May 26, 2008 11:37 PM |
