Joined Jul 2012
Need some practical advice on FPV & OSD
I have decided to buy Fat Shark Predator RTF FPV Headset System w/Camera and 5.8G TX from HK (any buddy coded for me?)
I have read i may need to buy a better VTX with 200 or 600mw .. (is this correct? unfortunately backorder now ... Assuming i m ok with predator (though i m sure Dominator is better) Then i would like to see some info thru the goggle ... OSD? What would be the easiest and good to have? technically i m NEW. things like where is home, distance from home? height? speed? voltage? mayb not all is important, mayb you can recommend. I am on turnigy 9x, modded to er9x with frsky tx diy module flying a dji naza quad 450, with gps and often with a gopro. Do i need this 5.8GHz Circular Polarized spiroNet Antenna too? Pls spare me a minute or so .. a little from U guys with experience helps a great deal. |
for the antenna, make it your self, trust me its worth it ive made about 8 of this antennas on different fqs, and you will defenitly need this for your predator, get the predator set, its the cheapest and probably the easiest, but for me i got my self the 200mw too. as its the best out there, get the 600mw if you want from immersion. i just dont see this one working for me, and i would stay for 200mw
for remzibi with gps, you will get home arrow, home distance, and everything you need. download remzibi config and you would see how much it can provide you , its the best. and the remzibis gps from himodel has alot of use, i used it on my rabbit and crius boards
Joined Jul 2012
i m waiting/checking for buddycode for predator now lol
less to worry for es my quad usually uses 2200 when on normal flying and u put my 3600 or my 5000 when fpving less things to worry and much more easier
Joined Jul 2012
Thanks bros! Been reading in fpv section ..
Still can't make up mind to change out dji frame for a true FPV frame or not .. Any good recommendation .. ? Have not found a good fatshark predator + remzibi connection details .. Any comment abt cyclops osd? Or shld i stick to remzibi ? |
| Thread Tools | |
| Discussion FPV Newbie wanting some advice | midrian | Video Piloting (FPV/RPV) | 5 | Aug 10, 2012 02:31 AM |
| Help! Need some advice on upgrading my EDF | Gliding-Peter | Electric Ducted Fan Jet Talk | 5 | Jun 27, 2012 07:24 AM |
| Discussion need some advice on buying the MJX-F45 or the G.Tec 9019 | alcatres | Large Electric Helis | 7 | May 27, 2012 12:13 PM |
| Help! Buying FPV gear.. need advice on initial setup | neo__04 | Video Piloting (FPV/RPV) | 22 | Mar 08, 2012 10:25 PM |
| Help! landing gear on an fpv radian. need advice. ne1 try it? | g3f0rc3 | Video Piloting (FPV/RPV) | 5 | Feb 27, 2012 11:48 PM |
