Old Aug 31, 2012, 11:30 PM
Crissbrasil is offline
Find More Posts by Crissbrasil
BRAZIL
Joined Jul 2010
New MultiWii SE V2.0 Flight Controller w/FTDI
New version V2.0
[IMG][/IMG]
http://www.hobbyking.com/hobbyking/s...108&aff=171252
The Multiwii SE V2.0 is a gyro/accelerometer based flight controller that is loaded with features. With expandability options and full programmability, this device can control just about any type of aircraft. This is the ideal flight controller for your multi-rotor aircraft.
Features:
Small size, 35x35mm mounting holes
6 input channels for standard receiver and PPM SUM receiver
Up to 8-axis motor output
2 servos output for PITCH and ROLL gimbal system
Can utilize a servo's output to trigger a camera button
FTDI/UART TTL socket for debug, upload firmware or LCD display
I2C socket for extend sensor, I2C LCD/OLED display or CRIUS I2c-GPS NAV board
Separate 3.3V and 5V LDO voltage regulator
ATMega 328P Microcontroller
MPU6050 6 axis gyro/accelerometer with Motion Processing Unit
HMC5883L 3-axis digital magnetometer
BMP085 digital pressure sensor
On board logic level converter
Flight mode:
One of the following basic mode
- Acro
- Level
- Alt Hold
- Head Lock
Optional mode
- HeadFree (CareFree)
- GPS Hold (Need GPS receiver + I2C-GPS NAV Board)
- GPS Return to home position (Need GPS receiver + I2C-GPS NAV Board)
Specs:
Dimension: 40mmX40mm
Height: 11.6mm
Weight: 9.6g
Fixing hole spacing: 35mm (It can be changed to 45mm by CRIUS Distribution Board)
Hole diameter: 3mm
Package content:
SE FC x 1
USB program board x 1 (Mini USB cable required but sold separately)
3Pin to 1Pinx3 cable 100mm x 2
3Pin to 3Pin cable 100mm x 1
Crissbrasil is offline Find More Posts by Crissbrasil
Old Sep 01, 2012, 03:00 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Crius se v2.0
what's new then?
not even a "MS5611-01BA01"
the same old rubbish like this.
-> http://dx.com/p/mwc-multiwii-mwc-se-...d-black-149348
Cheaper only $ 34.00
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Sep 01, 2012, 03:47 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
gyro is a mpu it s the only thing who is different
titeuf007 is offline Find More Posts by titeuf007
Old Sep 01, 2012, 05:28 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Hobbyking jumped onto the Multiwii wagon about 9 months too late.
Good for them, I guess.
Sad Sack is offline Find More Posts by Sad Sack
Old Sep 01, 2012, 07:14 AM
JackinFtLaud is offline
Find More Posts by JackinFtLaud
Joined Jul 2012
Originally Posted by JUERGEN_ View Post
what's new then?
'New' for Hobbyking......?
JackinFtLaud is offline Find More Posts by JackinFtLaud
Old Sep 01, 2012, 07:50 AM
Joined Jun 2006
yes hk have a news flight controll in stock
Old Sep 12, 2012, 09:48 AM
Torque66 is online now
Find More Posts by Torque66
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
So what's a good FC then these days... i have a F450 and naza and would like to replace the naza with an FC that will allow me to do tight axis flips???
Torque66 is online now Find More Posts by Torque66
Old Oct 20, 2012, 04:28 AM
caneraydeniz is offline
Find More Posts by caneraydeniz
Joined Aug 2011
Hello
Hello
friends
I showed the picture instead of the track
Which parts can I use
Can you help?
caneraydeniz is offline Find More Posts by caneraydeniz
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Sold *NEW* MultiWii SE Standard Multicopter Flight control board+FTDI USB PRGMR+PID LCD beachflyer Aircraft - Electric - Multirotor (FS/W) 2 Sep 02, 2012 11:31 AM
Sold 6x DJI ESC, Crius SE w/ FTDi, KK2.0 w/ programer blade strike Aircraft - Electric - Multirotor (FS/W) 1 Aug 25, 2012 12:21 AM
Sold Crius Multiwii SE version 0.2 w/ Power Distribution, NEW readerror67 Aircraft - Electric - Multirotor (FS/W) 1 Jul 18, 2012 10:43 AM
Sold CRIUS MultiWii SE V2.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 4 Apr 19, 2012 12:06 AM
