Old Sep 11, 2012, 02:27 PM
darook is offline
Find More Posts by darook
darook's Avatar
Johannesburg, South Africa
Joined Apr 2006
WBPU and talc mix is awesome. It is very light and sands down very smooth. It will fill all the gaps very well and leaves a very smooth finish. You can use different mixes with it, I go from a fairly viscous consistency to fill the weave on fg right up to a peanut butter kind of paste. Play around with it until you find the mix that suites but use it as thin as possible.
darook is offline Find More Posts by darook
Old Sep 11, 2012, 02:42 PM
bamiller is offline
Find More Posts by bamiller
bamiller's Avatar
United States, CO, Castle Rock
Joined Dec 2009
Thanks! Any particular brand of wbpu you recommend? I've never used the stuff before.
bamiller is offline Find More Posts by bamiller
Old Sep 11, 2012, 03:00 PM
vicentel is offline
Find More Posts by vicentel
vicentel's Avatar
United States, CA, San Diego
Joined Aug 2010
Minwax
vicentel is offline Find More Posts by vicentel
Old Sep 11, 2012, 03:41 PM
superinstaller is online now
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
hey! You just answered my ?, Im building a Nacelle for my 80mm deltav32 and was looking for somthing lighter than bondo.
superinstaller is online now Find More Posts by superinstaller
Old Sep 11, 2012, 04:24 PM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Excellent, I am picking some up on my way home tonight.
Old Sep 11, 2012, 05:20 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Minwax works great, Im sure that other brand polys would be fine too as long as they are water based. As far as I can tell those motors should be fine on 4s, looking at the specs. The units I have are the Detrum 70mm combos from Hobbypartz, for about 50 bucks they seem to be a great deal They perform great on 4 or 5s, I havent tried 6s yet but I have seen where people have. I might give it a go
Lt599 is offline Find More Posts by Lt599
Old Sep 11, 2012, 05:22 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Guys, the poly/powder mix is great, I use it quite a bit but, be careful it can add the weight fast.. Experiment on scrap with different amounts of powder, to get it where you like it.. Then, apply first coat, let dry, sand, second coat, sand with finer grit. You'll find this stuff not only fills but makes a super slick finish to apply your paint to... Good luck!w
Waltjg is offline Find More Posts by Waltjg
Old Sep 11, 2012, 05:28 PM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Excellent, I need to look at those motors. I wonder what the amp pull will be. (upgrade my esc's)
Old Sep 11, 2012, 05:35 PM
vicentel is offline
vicentel's Avatar
Joined Aug 2010
Water based for the poly urethane is a must anything else could potentially dissolve the foam.
I have the same Detrum 70mm combos and tried both 4S and 5S, but 6S sounds crazy I've put these fans on a watt meter and it will draw 33amps and 54amps on 4S and 5S, respectively. So I'm guessing it will be well beyond the ESCs rated amps once you go to 6S. Also people on this forum who are using this combo on 5S suggest that before you do that that you balance the fans, which I have...just to be sure.
Old Sep 12, 2012, 10:45 AM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Thanks for the adding info Walt! I picked up a can on my way home last night and applied a "paranoid" thin layer later on my fuselage. I really like the take so far. It also seems to dry nice and fast.
I did have a hard time getting the talc to mix properly. Some general questions if anyone can help...
1. It seems like it would take a lot of talc to make it "thick". I'm wondering what the recommended ratio is for a "general" cover mix. It just seemed like its going to take a lot of talc so maybe that's normal.
2. Is there any need to thin the wbpu? If so do you thin it with water?
3. Are there mix options other than talc that can be substituted? I've heard of corn starch but I wondered about experimenting with thinned LWS.
4. Does the finished product leave a protected shell over the foam to help prevent pits and dents? Or is that too thick? (I guess that depends on ones weight concerns)
Thanks everyone for the help!
Old Sep 12, 2012, 11:53 AM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
B, yes, it seems like it takes alot of talc, and make sure it is talc and not cornstarch based... No don't thin it... It does offer a small amount of protection but will still dent and scratch. w.
Old Sep 12, 2012, 07:40 PM
Peacemakr40 is offline
Find More Posts by Peacemakr40
Peacemakr40's Avatar
United States, TX, Burleson
Joined Aug 2011
Excellent job on the Hawg. I do also recommend going to the servoless retracts but you want to really reinforce that you're mounting them to. one hard landing and you'll drive them through the top of the wing or fuse.
Peacemakr40 is offline Find More Posts by Peacemakr40
Old Sep 13, 2012, 03:08 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
What airfoil are you using? I have my plans scaled and printed but I cannot decide on the airfoil. The full size plane uses a NACA 4616 at the root and 4613 at the tip. I have printed these out along with the 4212 and Clark Y. The scale airfoil as a very unique shape. It is quite thick and has a negative sweeping TE. I am just not sure if I can get away with the scale airfoil on the model,my WS is 50" . Any thoughts? Im ready to start cutting Greg
Old Sep 13, 2012, 11:16 PM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Hey Greg! I went with a vanilla clark y. Works awesome. Takes off and flys very stable. I also was going to use the scenario you mentioned above. But it just seemed too thick for what I wanted to cut and I ended up not wanting the hassle. Its doable but I just felt more comfortable with the clark y.
I'll post some updated pics by Saturday (should have a rough coat of paint). Its taken apart right now for wbpu and is looking good. I had to sand all the darn latex paint off because it looked terrible and seemed too heavy. Let me know what you decide to go with.
Old Sep 13, 2012, 11:18 PM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Thanks again Walt... the wbpu and talc works great. - Brent
Discussion Scale A-10 Warthog Build AirborneRME Jet Turbines 1 Jul 20, 2012 12:03 AM
Sold GWS A-10 Warthog Kit, Pusher and Ducted Fan Options Included lagoonatic Aircraft - Electric - Jets (FS/W) 5 Jul 17, 2012 07:19 AM
Sold A-10 Warthog Thunderbold II V2 RC Fighter Jet RTF w/ Twin 64mm EDF Jace759 Aircraft - Electric - Airplanes (FS/W) 4 Jun 17, 2012 09:45 PM
Sold A-10 Thunderbold II Super Warthog wbrannies Aircraft - Electric - Airplanes (FS/W) 4 Jun 12, 2012 06:41 PM
Sold A-10 Thunderbold II Super Warthog wbrannies Aircraft - Electric - Jets (FS/W) 0 Jun 12, 2012 10:36 AM
