Old Aug 31, 2012, 08:25 PM
michael88997 is offline
Find More Posts by michael88997
United States, TX, Lewisville
Joined Jan 2011
Dle 20 clunk line
I got a prox 260 I'm putting a dle 20 on, have a Sullivan 8oz tank. I was trying to use the standard gas line for a clunk but it's pretty stiff and doesn't let it go to the front, I was gonna load it up with weight but is there a more flexible gas line I could get?
michael88997 is offline Find More Posts by michael88997
Old Sep 01, 2012, 04:02 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The clunk should never ever go to the front of the tank under normal conditions
As long as the clunk freely touches the bottom, top and sides of the tank as you rotate it, you should be fine.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Sep 01, 2012, 04:27 PM
Joined Jan 2011
Well right now if the tank was half full and I was noes down it will be sucking air...
Old Sep 01, 2012, 07:35 PM
pilotpete2's Avatar
Joined Jun 2004
When you push the nose down in flight, the fuel will experience momentary negative G's.
Most dives and spins are not of long enough duration to be a problem, especially for gas engines, where the carb is pumped and has enough of a supply to see you through the maneuver.
I've never setup a tank where the clunk could fall to the front of the tank on it's own. It usually take a run off the runway into grass and nose over to do that, and then you will have a deadstick on the next flight if you don't catch it
Pete
Old Sep 03, 2012, 06:44 AM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
As much as I hate to say it,those new "space age" tanks are looking mighty good! It's all sealed at the factory,and has a rotating pickup near the center of the tank. Prohibitively expensive,but going in all my prohibitively expensive models from now on !
Very few models run out of fuel during gyrations...the black rubber smoke system lines are very flexible,and could be installed for fuel also.
Fuel doesn't lie still in model airplanes....someone put a camera in one to watch the activity in a tank that was mounted on the CG..At times fuel was at the top of the tank in level flight-it's always moving. Centrifugal/centripetal forces take the pickup along with the fuel,wherever the fuel goes in the tank.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Sep 03, 2012, 07:45 AM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
michael,
As mentioned the engine really doesn't need fuel from the front of the tank, ever. I saw something come off my gas 3D profile one day while playing pretty hard. Not knowing what it was, I cooled it bringing it back around for a slow pass while gently feeling it out for handling issues. Seemed fine, and I didn't see anything wrong? While wondering "what the heck?" the engine quit, telling me immediately what happened. What I had seen was the fuel tank falling! The engine quit a good 45-60 seconds after seeing the tank fall. It had been running on the contents of the 4" fuel line (minus what leaked from that) along with the contents of the carb that entire time!
I run a 6oz tank, and just getting/keeping the clunk able to contact the rear sides of the tank can be a pain because the line's so short. I run extra weight in the form of a 5/16 nut right above the clunk. That seems to work pretty good. -Al
ahicks is offline Find More Posts by ahicks
Old Sep 03, 2012, 06:21 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I run viton tubing inside the tank. It costs a bit more but stays flexible for years unlike the yellow stuff.
I also have one of the "space age" tanks from "Rotoflow" in my Giant Big Stik, feeding a Syssa 30cc. The clunk in them does not move fore and aft, only rotates. I have never had it fail to feed fuel no matter what attitude the plane is in. Yep, I love these things since they are maintainence free and have no stuck in the front clunks after a bad landing!
Fokker DII is offline Find More Posts by Fokker DII
Old Sep 03, 2012, 07:28 PM
pilotpete2's Avatar
Joined Jun 2004
Been there, done that one Fokker
Those Rotoflow tanks look interesting, but I'll stick with the Tygon F-4040-A (what Dubro sells) and change the clunk line each season.
For gas engines, the Walbro felt filter clunks are da bomb. As long as gas sloshes on them, you'll never suck air. The only issue with using filter clunks is having to use a third line for fill/drain, but NOT with a clunk, just a tube down into the very front of the tank. I just lift the tail to get out the last of the fuel.
Pete
Old Sep 03, 2012, 08:13 PM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
B&B sells a gas fuel line thats more flexible than tygon. I've been using it in 16oz tanks for awhile. Hasnt gotten stiff yet.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Sep 03, 2012, 11:07 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Originally Posted by edwin1 View Post
B&B sells a gas fuel line thats more flexible than tygon. I've been using it in 1mcmasters.6oz tanks for awhile. Hasnt gotten stiff yet.
Edwin
I buy my Viton tubing from McMasters industrial supply. A lot cheaper than the hobby suppliers. That stuff is impervious to gasoline and never gets hard. Use Shore 60 for flexability.
Old Sep 06, 2012, 03:19 PM
barracudahockey is offline
Find More Posts by barracudahockey
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Viton and a felt or ceramic clunk
barracudahockey is offline Find More Posts by barracudahockey
Old Sep 06, 2012, 07:35 PM
JeffinTD is offline
Find More Posts by JeffinTD
United States, OR, The Dalles
Joined Apr 2011
The vitron I got from the hobby shop is pretty thick walled. Viteron from the chain saw shop has a slightly thinner wall, and is much more flexible.
I agree, though, you don't want the clunk to go to the front of the tank.
JeffinTD is offline Find More Posts by JeffinTD
Old Sep 06, 2012, 08:05 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Viton from McMasters is 1/16" thick wall and comes in many diameters. Shore 60 is the flexible stuff. There is also a stiffer Shore # but it is not good for a clunk line. They sure beat the hobby store prices.
BTW: Be careful buying at the LHS, The black tubing that many carry is "Neoprene". It will get rock hard in less than a year......ask how I know...
Old Sep 07, 2012, 11:47 AM
Joined Sep 2004
Yea, make sure you're buying Viton and not Hayes clunk line for glow fuel.
Old Sep 18, 2012, 11:08 PM
digiex_chris is offline
Find More Posts by digiex_chris
Joined Apr 2011
I find my tygon doesn't get stiff if I leave the tank full. I only drain it to transport it. I have no idea what other effects that is going to have long term, but my clunk line seems to like it.
digiex_chris is offline Find More Posts by digiex_chris
Wanted Wanted DLE-55 & DLE-20 cncmachine Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 14, 2012 12:20 PM
Question DLE-20 and DLE-30 have same Ignition? snoshoe62 Engines 17 Apr 22, 2011 04:52 PM
Discussion 3 lines into tank. 2 clunks needed. rubble Fuel Plane Talk 4 Jul 01, 2010 07:59 AM
Discussion Clunk line: Nose down attitude = engine cut syousef Fuel Plane Talk 8 Mar 29, 2009 10:56 AM
Help! bad clunk line question creepin Fuel Heli Talk 4 Mar 02, 2007 01:50 PM
