Old Nov 13, 2012, 05:06 AM
romanxdsouza is offline
Find More Posts by romanxdsouza
Joined Aug 2012
jack.what about pusher prop planes like this will it work with my electronics if i make ws 36 fuse 34 or shorter .....something like this..in the 1st post . http://www.rcgroups.com/forums/showthread.php?t=1000670
romanxdsouza is offline Find More Posts by romanxdsouza
Old Nov 13, 2012, 07:12 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I think they are more complicated to build and also bring some complications with them because of the limited prop clearance between the propeller and the fuselage.
They are attractive because it looks like the motor and prop will avoid damage but, all things considered, I do not consider them a better choice as a trainer...
Just one opinion. I think if you stay with what you have now or something like that you will succeed with the power system you have now. It oftern takes more than one try...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Nov 13, 2012, 09:35 AM
Joined Aug 2012
cool jack will do that
Old Nov 13, 2012, 09:56 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Here is another simple to build trainer that you can consider.
Trainer Type Plane - http://www.rcgroups.com/forums/showthread.php?t=1281056
That might work good with the materials you have been using so far. And you can simply scale the size up or down a little to suit your materials. There is a plan with dimensions in post #24:
http://www.rcgroups.com/forums/showp...7&postcount=24
Jack
Old Nov 13, 2012, 11:52 AM
Joined Aug 2012
jack im eager to know the full size of the fuse for the tuffy
Old Nov 13, 2012, 11:59 AM
Jack
USA, ME, Ellsworth
Joined May 2008
You can see it from the grid on the attached plan, it is a little over 40" with the wing tips.
Jack
Old Nov 13, 2012, 12:01 PM
Joined Aug 2012
very very neat did u make this plane, i cant figure out fuse size
Old Nov 13, 2012, 12:03 PM
Joined Aug 2012
look easy but i knw its not for a fresher like me,need to know how pusher props work n stuff
Old Nov 13, 2012, 01:55 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I did make it, it was sort of troublesome for me in flying. I kept breaking it and it went away eventually...
It was not really the plane's fault, more mine...
Jack
Old Nov 13, 2012, 01:59 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The grid sizes are not exactly right, And it will vary with the materials used. For mine I used 2" blueboard insulation for the fuselage and faced the sized with a layer of the 1/4" FFF. So the fuselage was 2-1/2" wide.
Jack
Old Nov 13, 2012, 09:35 PM
Joined Aug 2012
thanks jack ,does the tuffy work well with only 3channels throttle,elev ,rudder.so the full fuse including the boom would be around 32inches correct,i will get used to flying then go for this build but plan it slowly .if i want to build a 36 inches WS tuffy what will d wing cord b ,iwould want to use same measurments as slow stick,can u tell me wat size stabelizers ver/hor and fuse (fuse n boom),would be.......thanks again
Old Nov 14, 2012, 08:20 AM
Jack
USA, ME, Ellsworth
Joined May 2008
It could fly RET, I did not build it that way. With 1" of dihedral and a KFm2 wing the RET stability and rudder authority should be fine.
On the bottom line of the plan with the grid the inches are numbered. it is annoying to use because you have to scroll up and down to read the values but you can get the length dimension from there. Or you can simply count the number of squares. As an example, the nose is at 32.9" and the tail is at 65.2 so the length would be 65.2 - 32.9 or 32.3".
Don't look for too much precision or accuracy from that plan, just call it a 32" length and that is close enough. if you insist on it, you can call the length to be about 32-1/4".
The Tuffy has a 40" wing span. To scale it down to 36" you want to change all dimensions by a factor of 0.9 (40 x 0.9 = 36). Another way to think of it is to say that you want to build a plane that is 90% of the size of the Tuffy.
So if you write down all the dimensions you want to know and do the math, you will have the dimensions for the 90% or 36" version.
Warning! Don't let the math make you crazy! Round off the numbers or you'll be working in decimal fractions of an inch that will not come out to anything you can find on a ruler...
Jack
Old Nov 15, 2012, 08:50 AM
Joined Aug 2012
im planing to make the tuffy a slow flyer later , so what about the same sizes i used for the slow stck plan below ....only fuse changes to 32inch, jack if the WS is 36 what would i make the wing cord keeping in mind that im planning a very slow flyer.
Old Dec 18, 2012, 01:48 AM
Joined Aug 2012
hi john ,guess u busy with xmas im working on a slow stick again with alliminum fuse if it flies will post videos, till then fingers crossed,i am looking for a good combo for my futaba rx r6106hf futaba recievers Size: 0.85 x 1.53 x 0.48" (21 x 39 x 12mm) Weight: 0.24 oz (6.7g) Voltage Range: 4.8 - 7.4Vthat is prop ,motor,esc,battery to plan a good small 24inch wing span like a hangar rat, please let me know if u have any info on it
Old Dec 18, 2012, 12:40 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Are you looking for something like the Blu Baby 24? You can see one in this post:
http://www.rcgroups.com/forums/showp...ostcount=18557
If you search the Blu Baby thread for "BB 24" and "BB24" with an any date range you find hundreds of posts discussion that build.
Here are some links to info and plans for the BB 24
Blu-Baby 24 Parts Kit Tiled.pdf (http://www.rcgroups.com/forums/showa...mentid=1846489)
Blu-Baby 24 Parts Kit Full.pdf (http://www.rcgroups.com/forums/showa...mentid=1846490)
Blu-Baby 24.pdf (http://www.rcgroups.com/forums/showa...mentid=1846488)
Blu-Baby 24 KFm2 Wing.pdf (http://www.rcgroups.com/forums/showa...mentid=2047423)
Blu-Baby 24 KFm2 Wing Parts Full.pdf (http://www.rcgroups.com/forums/showa...mentid=2047424)
Blu-Baby 24 KFm2 Wing Parts Tiled.pdf (http://www.rcgroups.com/forums/showa...mentid=2047425)
Depending on the weights, the BB 24's seemed to generally be powered with 24 gram Wonder motors and 2S packs, when you find the builds you'll find the power system specifics too. Some of the lightest ones flew with the C10 10 gram motors too.
Jack
Sold Wanted cowl for Great Planes SU-31, the 77 inch WS. Part # GPMA3073 PropsnWings Aircraft - Fuel - Airplanes (FS/W) 5 Aug 03, 2012 10:07 AM
Discussion 24 inch laser scratch build Hobiestoke Sailboats 50 Jan 28, 2012 03:12 AM
Build Log 24 hour build log. 10 inch biplane. nemoskull Scratchbuilt Indoor and Micro Models 9 Jan 23, 2012 10:19 AM
Discussion The build of my 24 inch delta Started in 05 updated 2010 epoweredrc Foamies (Scratchbuilt) 15 Jan 31, 2010 10:51 PM
New 24 inch wing with GWS 300 Motor (scratch build) Qrome Flying Wings 15 Sep 24, 2005 04:23 PM
