Old Oct 12, 2012, 09:58 AM
romanxdsouza is offline
Find More Posts by romanxdsouza
Joined Aug 2012
jack , can u please tell me if the radder and eleveator has enough of room to move check these pics
romanxdsouza is offline Find More Posts by romanxdsouza
Old Oct 12, 2012, 10:11 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
It has more than enough travel. You'll want to set the servo travel on the TX to limit the up and down travel on the elevator to 1/2" of up travel and 1/2" of down travel. Set the rudder about the same.
Make that your Low rate if the have a High/Low Rate switch. For the High rate you can set it for more travel but you'll find the controls very touch with the large amount of surface on the elevator and rudder.
Setting the Exponential to 30% or so will also slow the travel for the initial stick movement and help with the learning phase. It makes the plane less likely to be very touchy to the initial stick movements.
You almost ready to fly?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 12, 2012, 03:18 PM
paulatgis is offline
Find More Posts by paulatgis
United States, FL, Melbourne
Joined Apr 2009
this is a little one with polyhedral wings. keeping all up elevator as possible allows it to parachute straight down with the throttle off. I guess full up elevator works hand in hand with the "up" wing tips. it literally just parachutes straight down nice and level.
paulatgis is offline Find More Posts by paulatgis
Old Oct 12, 2012, 03:22 PM
Joined Apr 2009
here's the all foam version at 30 inch wing span
Old Oct 19, 2012, 09:12 PM
Joined Aug 2012
still waiting for servos and basswood
Old Oct 20, 2012, 12:22 AM
Joined Aug 2012
hey jack ive got carbon rod any ideas how to make pushrods for it, the CF fits very loosely what should i do about it
Old Oct 20, 2012, 07:10 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Rough up the outside of the CF just a little bit with sand paper, then fill the socket with a two part epoxy and stick it in.
One end should have a wire on with a "Z" bend so you can adjust the length. Or you can use a straight wire with something like the DuBro Mini EZ adjusters. Those off the easiest and quickest length adjustment.
Jack
Old Oct 21, 2012, 09:14 AM
Joined Aug 2012
hi jack, wat is " outside kf " sorry new term for me ,how abt sandpapering CF rod rolling it with thread then puting glue and sticking it in ,will it work
Old Oct 21, 2012, 11:11 AM
Jack
USA, ME, Ellsworth
Joined May 2008
That is a stupid typing error that I ignored! "kf" should read "of".
Blame it one my fat old fingers and failure to check my work.
Jack
Old Oct 22, 2012, 04:23 AM
Joined Aug 2012
haha ha thats k ,i got the servos now,will check all electronics n get back to u
Old Oct 22, 2012, 12:35 PM
Joined Aug 2012
hey jack im charging my futaba transmitter t6ex till what volt should i charge it wat is the max volt ,what volt should it say on the LCDscreen ,ive charged mine til 11.0volts wats the max charge.........im lost in the futaba world were can i get info manual not helping
Old Oct 22, 2012, 06:19 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The battery type and cell count on the battery pack usually dictates that. If is is a 8 cell NiMH it will be about 1.4V per cell fully charged or 11.2V. Most NiMH chargers will get it up a little higher before it cuts the charge off.
The markings on the pack should help sort it out. The nominal voltage for NiMH is 1.2V per cell and fully charged voltages can be 1.4V or even 1.6V per cell in some cases.
http://en.wikipedia.org/wiki/Nickel%...ydride_battery
Jack
Old Oct 23, 2012, 12:22 AM
Joined Aug 2012
what should b the volt on the tx after charging mine shows 11.0v till wat volt should i charge ,wat it should read ,im using eneeloop
Old Oct 23, 2012, 05:44 AM
Joined Aug 2012
hey jack replaced the skid with detachable wheel made them below are the pics check the rods aswell
Old Oct 23, 2012, 07:19 AM
Jack
USA, ME, Ellsworth
Joined May 2008
11 volts is about right and probably fully charged. The TX will stop charging when they are fully charged. If it is this cell and there are 8 of them it would be about 8 times 1.4 or 11.2V:
http://www.batteryspace.com/nimhrech...elyusable.aspx
Jack
Sold Wanted cowl for Great Planes SU-31, the 77 inch WS. Part # GPMA3073 PropsnWings Aircraft - Fuel - Airplanes (FS/W) 5 Aug 03, 2012 10:07 AM
Discussion 24 inch laser scratch build Hobiestoke Sailboats 50 Jan 28, 2012 03:12 AM
Build Log 24 hour build log. 10 inch biplane. nemoskull Scratchbuilt Indoor and Micro Models 9 Jan 23, 2012 10:19 AM
Discussion The build of my 24 inch delta Started in 05 updated 2010 epoweredrc Foamies (Scratchbuilt) 15 Jan 31, 2010 10:51 PM
New 24 inch wing with GWS 300 Motor (scratch build) Qrome Flying Wings 15 Sep 24, 2005 04:23 PM
