Old Aug 31, 2012, 06:07 PM
romanxdsouza is offline
Find More Posts by romanxdsouza
Joined Aug 2012
want to build a 24 inch plane
hi guys,im new to rc airplanes want to build a 24 inch plane slow stick,for easy transport dont want to go bigger in size,need plans with sizes for fuse,wing.elev, rudder,wing post,dihedral PLEASE HELP GUYS
ive got a, futaba transmitter t6ex and a r6106hf futaba recievers Size: 0.85 x 1.53 x 0.48" (21 x 39 x 12mm)
Weight: 0.24 oz (6.7g)
Voltage Range: 4.8 - 7.4V
motor Brushless motor BLM5055-8T 0.4 kg static thrust (with 8x6er propeller)
100W power class (9A / 3S)
Hochweritge Koyo or SKF
Complete with drivers, installation material and 3.5 mm gold plated plug
Tremendous torque
Weight: 29g
1360 RPM / Volt ,-,
esc -Magic Seed Brushless ESC 18 A,Dimensions: 34 x 22 x 7mm
Weight: 18g
, flight battery SLS APL 2200mAh 2S 7.4V 30C +60 C TRX
romanxdsouza is offline Find More Posts by romanxdsouza
Old Aug 31, 2012, 06:46 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The gear you have is quite large for a 24" plane unless you don't mind it being rather heavy and fast. You'd probably need a minimum of a 7" prop to get any useful power out of the motor on 3S, which is almost a third of the target wingspan.
Take this plane, for example. It's got a 22" span and weighs 3 ounces. It has a ten-gram motor swinging a 4.5" prop, 250mAh 2S lipo, and a 6A ESC. It's small and slow enough to fly in a small park, but only barely.
Piece is offline Find More Posts by Piece
Old Aug 31, 2012, 09:50 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I think that is a 270 gram 1500 Watt motor, I don't think a 24" wing span is going to be enough airplane to fly that motor.
http://www.modellbau-berger.at/antri...b202/index.php
Jack
jackerbes is offline Find More Posts by jackerbes
Old Sep 01, 2012, 02:25 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gvleborg County
Joined Jan 2004
The one he have is probably this: BLM2822-27T
I agree with C₄H₁₀, too heavy motor for such small plane.
MagnusEl is offline Find More Posts by MagnusEl
Old Sep 01, 2012, 07:41 AM
Jack
USA, ME, Ellsworth
Joined May 2008
OK, the 29 gram motor might be OK for a Blu Baby 24, the part drawing for that can be seen here:
http://www.rcgroups.com/forums/showa...0&d=1209747379
With that much power I would go with the stronger 24" KFm2 wing and the plans for that are here:
http://www.rcgroups.com/forums/showa...4&d=1220529756
And post #1 here has some other plans for the BB 24:
http://www.rcgroups.com/forums/showt...hp?t=%20681556
Jack
Old Sep 02, 2012, 06:37 AM
Joined Aug 2012
thanks for your replies ,how about this plane guys .simple split stick
http://www.rcgroups.com/forums/showthread.php?t=254490
yes magnus the motor i hav is BLM2822-7T,http://www.modellbau-berger.at/antri...2530/index.php
carbon prop 6.5 x4,http://www.wiredrc.com.au/shop/prope...propeller.html,
battery- http://www.stefansliposhop.de/liposh...-trx::951.html
ESC- it is the Magic Seed Brushless ESC 18 http://www.simprop.de/Seiten/Modellb...Speed10_18.htm
servos- http://www.servodatabase.com/servo/jamara/5g-digi
Old Sep 02, 2012, 07:05 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The motor you have might still be a bit much for that SSS build. That has a 3 oz./85 gram AUW and in that build used a 12 gram GWS reduction gear drive. That drive had an input power of 5 to 7 Watts or so. Your 29 gram motor will be be about twice as heavy and 7 to 10 times as powerful.
If you scale up the components (wing thickness, fuselage stick size, servos, battery, etc.) to better match your motor it would probably work.
Jack
Old Sep 02, 2012, 07:16 PM
Joined Aug 2012
should i give it a try jack im going to use v shaped dihedral for wings,and wing post like the hangar rrat,im worried abt the battery weight ,what u mean by" scale up the components "" pls advise im new in the field,
Old Sep 02, 2012, 07:24 PM
Joined Aug 2012
only option left besides sss is gws slow stick.problem is im workining on a cruise ship need to travel with the plane every trip once built,so need somthing easy to travel with especially with security level these days,tgats why was planin on 24 inch wing
Old Sep 02, 2012, 09:49 PM
Jack
USA, ME, Ellsworth
Joined May 2008
To scale it up would be to make all the parts proportionally larger. A 24" wingspan plane scaled up to a scale of 1.5:1 would become a 36" plane as an example.
It you strengthen the wing and fuselage it might work with your motor. I was just thinking that at 85 grams the materials might not be strong enough to handle the weight and flying stresses.
I can understand your concerns about portability with your job and the desire for it to be more portable.
If a flat, more rectangular form would be easier to store and transport you might want to consider a flying wing like the Divinity 42. That would store in an area that is about 12" x 44" and just 2-3" thick. And your motor would be a good choice for that plane:
http://www.rcgroups.com/forums/showthread.php?t=1023254
Can you fly already? The Divinity will fly slow and and is a very stable flyer too. If you have a little flying experience it will not be too difficult to fly. It would not be quite as easy for a new pilot to fly as the SSS or a smaller slow stick.
Jack
Old Sep 03, 2012, 01:56 AM
Joined Aug 2012
never flew b4,looking to build a stick planes basicly and slow flyers.the electronic i pickd were from germany,should hav gone lighter.what u thing abt d GWS slow stick may hav to go to a 48 inch wing i think ive got the plan
Old Sep 03, 2012, 07:47 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The slow stick is a good choice for a slow flyer like the SSS. The SSS as you posted the link to it is really more of an indoor plane. Or course you can fly it outdoors but outside you really need a day with no more than a breathe of air moving.
The SS is sold in 46" and 37" wing spans but you can build it in almost any size. I build a clone of the SS I called the KFoenix Stick that had a 48" Kline-Fogelman wing:
http://www.rcgroups.com/forums/showthread.php?t=1408747
You can get the square sticks in wood, fiberglass, CF and various sizes like 8mm, 10mm square. If you want to build to a smaller size for better portability it is not too difficult.
Your motor should work fine for a 48" or so SS build. It will have about 50-70 Watts of power will work well with slow flyer and park flyer type planes like the SS up to about 500-600 grams or so
If you have a plan and want to change the size, post it here or post a link to where it is. Maybe it can be resized to what you want to have.
Jack
Old Sep 03, 2012, 08:39 AM
Joined Aug 2012
hey hi jack,this is the plan i found for the slow stick its neat,but i find the fuse 2 big and cant figure out the wing post sizes scroll down the page there is a drawing of fuse and wing post http://www.wattflyer.com/forums/showthread.php?t=16392
Old Sep 03, 2012, 08:41 AM
Joined Aug 2012
i tried all electronics one servo dosent seem to be working now,tried on all channels on reciever
Old Sep 03, 2012, 09:36 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Is that the drawing I have attached? It that what you want to use?
Jack
Sold Wanted cowl for Great Planes SU-31, the 77 inch WS. Part # GPMA3073 PropsnWings Aircraft - Fuel - Airplanes (FS/W) 5 Aug 03, 2012 10:07 AM
Discussion 24 inch laser scratch build Hobiestoke Sailboats 50 Jan 28, 2012 03:12 AM
Build Log 24 hour build log. 10 inch biplane. nemoskull Scratchbuilt Indoor and Micro Models 9 Jan 23, 2012 10:19 AM
Discussion The build of my 24 inch delta Started in 05 updated 2010 epoweredrc Foamies (Scratchbuilt) 15 Jan 31, 2010 10:51 PM
New 24 inch wing with GWS 300 Motor (scratch build) Qrome Flying Wings 15 Sep 24, 2005 04:23 PM
