Old Sep 12, 2012, 02:26 AM
DS Addict
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
I need specifics. All the info is spread too vast.
After a worksheet type thing that has step by step, what to use etc
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Sep 12, 2012, 11:32 AM
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
The entire setup of the Mamo is too complex to give a spreadsheet Alex
Different radio's different servos and mechanical setup will all change the Throttle and pitch curve parameters dramatically as will battery choice. I'm afraid to say its very much trial and error as anyone who has flown the Mamo will tell you
Andycap is offline Find More Posts by Andycap
Old Sep 12, 2012, 02:33 PM
"Free" in Christ!
Free's Avatar
United States, CA, SF
Joined Jan 2012
See the vid:
Aurora9 VPP (Variable Pitch Prop) Setup (6 min 38 sec)
Hope this helps,
Free
Free is offline Find More Posts by Free
Old Sep 12, 2012, 02:49 PM
Andycap's Avatar
Leeds
Joined Mar 2003
Originally Posted by Free View Post
Brandons video is very good to be fair and shows one way of looking at the VPP setup. Interestingly Brandon flies his setup much closer to normal aircraft mode than heli mode. Most pilots setups I have seen use a constant propeller speed and fly exclusively on the pitch of the prop with zero pitch at around centre stick. This is why its so difficult to put down in words or diagrams a typical setup. Most pilots also use a front mounted servo rather than the bellcrank lever supplied. Martin Muller uses a fairly basic sub 4g servo for his pitch servo (front mounted) the front mounted servo is favoured on the VTRVPP setups
Old Sep 12, 2012, 03:12 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
Video doesn't help me and I use a mamo unit :-)
Good infomercial on how to do on a hitec radio what is described in the manual. Which doesn't contain any actual details either.
Actual settings etc are purely experimental.
Normal mode first: pitch based on flying speed and power (battery & motor dependant). Need some pitch to start out. Not too little otherwise you risk overspeeding the motor. Add pitch until you have aircraft flying as you want. I had to change this as I changed the airframe (weight) and even more so when I changed packs. Too much pitch and it may bog, too little an no thrust. I actually ended up with very little as final airframe flies very nice at a slow constant rate.
Reverse pitch: just the same, experiment to give the thrust you desire. Throttle around the change over point is adjusted to try and maintain a constant'ish RPM. Again too much pitch bogs and too little gives no thrust.
Values on actual radio are irrelevant :-)
Dave
wildpalms is offline Find More Posts by wildpalms
Old Sep 12, 2012, 03:18 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
Brandon's is a combination of centre V and normal. How I do mine as well. Other than take off I only fly in this one mode.
Dave
Old Sep 19, 2012, 11:33 PM
Fly for God, not for the World
Not Free's Avatar
Joined Sep 2011
i have a question!:
Why would you setup a plane as a heli? (this might of been asked before. If it was, please inform me as not to waste your time
Thank you!!
Not Freejhuntil...
Not Free is offline Find More Posts by Not Free
Old Sep 20, 2012, 01:43 AM
Andycap's Avatar
Leeds
Joined Mar 2003
Q: Why don't people setup their Mamo VPP foamies as "airplanes" and run the pitch on the flap or AUX 2 channel?
Free
We want a non linear throttle to pitch mix that on most radios is only offered on Heli modes
Old Sep 20, 2012, 10:22 AM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
Question: Does "wing area" include elevator surface area?
Free
Old Sep 20, 2012, 11:06 AM
Andycap's Avatar
Leeds
Joined Mar 2003
No wing area is just the total area of the wing's planform from root to tip. I couldn't tell you what the wing area of any of my models is without going back to the cad program to calculate it. It really doesnt get discussed in F3P like it does for Gliders, particularly thermal machines
Old Sep 20, 2012, 11:18 AM
Not Free's Avatar
Joined Sep 2011
Free
Ok thanks
Old Sep 23, 2012, 12:44 PM
Excels at mediocrity.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I got a question that doesn't have to be listed:
Not Free: Where do you fly? (indoor)
acetech09 is online now Find More Posts by acetech09
Old Sep 25, 2012, 03:04 PM
Not Free's Avatar
Joined Sep 2011
Hey ACETECH,
I fly in my front yard, and sometimes I fly at the local park
Where do YOU fly
Old Sep 25, 2012, 05:26 PM
acetech09's Avatar
Joined Apr 2012
Hmm... maybe your location isn't accurate. I can't think of a single outdoor place in this bay area that's suitable for indoor models this time of year . I fly inside a pacifica gym once a month with my club, but that's too sparingly
Old Sep 25, 2012, 05:55 PM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
I fly near the same place that "Not Free", and it is actually not that bad flying, small, but not bad, you have to be picky though.
Free
Discussion The Official Teen Chit Chat Thread (Always Off Topic) Alex Schauer Chit Chat 20841 Today 08:47 PM
Discussion Official Eflite UMX Mig 15 DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 3436 Today 10:06 AM
New Product JR XG11 Owner's Thread ElIntocable Radios 246 May 10, 2013 12:26 PM
Discussion The official "anixs thank you thread" johnbyrne Trader Talk 281 Apr 10, 2013 05:16 PM
Question 450 Thread Lock and Maintenance (Answered) ailevin Mini Helis 2 Jul 06, 2012 02:48 PM
