Old Sep 26, 2012, 05:30 PM
g_munu is offline
Find More Posts by g_munu
_
Joined Aug 2012
Foam prototype under construction.
g_munu is offline Find More Posts by g_munu
Old Oct 09, 2012, 09:00 AM
g_munu is offline
_
Joined Aug 2012
Well, the prototype's got wing trouble. I took a chance by mounting the wing "upside down" with the larger KF step on top. The resulting configuration requires a ton of up trim to fly right and has a nasty tip stall. Oh well, I'll probably revisit this design again soon.
Old Oct 09, 2012, 09:48 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
One large step on top would not be "upside down". That is simply a KFm2 type airfoil and should be a decent choice for prototyping this sort of wing. i would not give up so easy. Just move the CG back a touch at a time.
Did you test glide the model before truing to take to the sky? I always give my prototypes short test glides (neutral trim) to see how they go. I toss them from the bedroom door onto the bed (soft landing) and see if they come down nose first, tail first, or land flat on their belly. 5 - 10 tosses like that will give you a reasonable idea as to where your CG is, and get you ball parked enough to head out to the field. About the only thing I would of done differently this the wing is given it a KFm4 airfoil as it is a symmetrical type and usually works a bit better with flying wings than the type 2. I personally like using the KF airfoils for prototyping as they are very fast and cheap to build while allowing one to test new designs for flight worthiness.
Mark
Quick61 is offline Find More Posts by Quick61
Old Oct 09, 2012, 12:19 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
And I thought I was the only one using the duvet landing strip.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Oct 10, 2012, 09:49 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Build in more washout. With that extreme a taper and the sweep of the 25% chord line in the outer panels a higher washout twist will both reduce the wing tip stalling AND promote a more pitch stable model.
You may be running into some of the swept wing angle of attack issues related to sweep angle as well. I've done a bit of playing with a test chuckie enough to realize that the effect is quite real and needs to be considered. I've got around 4 degrees of washout on the chuckie and it's not enough. Weather and other duties have prevented me getting back to it. But I've learned enough to suspect that it could easily be an issue in your case. Off the top of my head I'd suggest a good 6 degrees of washout at the tip compared to the gull dihedral break.
BMatthews is offline Find More Posts by BMatthews
Old Oct 10, 2012, 10:10 PM
8thelephant is offline
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
Unique find and nice work so far :-)
-8th
8thelephant is offline Find More Posts by 8thelephant
Question Wing taper: strait LE, strait TE, or dual taper? psguardian Foamies (Scratchbuilt) 5 Jul 15, 2012 11:11 AM
Discussion Plank tapering techniques b15605 Scale Boats 4 Jul 15, 2012 09:15 AM
Discussion foam cutting highly tapered tips GaryO The Builders Workshop 6 Oct 04, 2008 03:34 PM
Tips for cutting high-taper core? BillO Composites Fabrication 16 Dec 15, 2005 09:30 AM
Avoiding overburn on highly tapered wings? Brian Koester Slope 12 Jun 01, 2003 12:52 AM
