Old Jan 31, 2013, 05:55 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
another cool project!
Waltjg is offline Find More Posts by Waltjg
Old Jan 31, 2013, 06:19 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
D,
I use a copper/aluminum tube sharpened on one end to push thru the foam to cut the hole for the wire to fit into the duct or fuselage cavity. Just about everything else you outlined in your highlighted post is parallel to what I learned and figured out. BTW just twist the tube as you push it in and it cuts a hole pretty clean.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 01, 2013, 12:50 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I like that method too. works awesome. I've also heated it with a Bic lighter and that works good too, but you gotta watch out for burning the foam.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 01, 2013, 03:50 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Originally Posted by D_FAST View Post
Lmeano, glad you popped in.
I fallowed that thread, using it now for reference.
I touched base on some of my steps in another thread
http://www.rcgroups.com/forums/showp...2&postcount=45
http://www.rcgroups.com/forums/showp...9&postcount=46
D,
Thanks for the reference links. I want to try that, your cut pieces look great. I recently acquired hot wire equipment for wing cutting and a wire cut table for fuse sections. I will be in touch for some section patterns to try out. Rock on with the Dart it looks great!!!
Jeff
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Feb 01, 2013, 05:44 PM
Joined Jan 2009
yeah, I wouldn't mind one of these birds in my stable. they are so cool.
Old Feb 06, 2013, 02:15 PM
au117 is offline
Find More Posts by au117
Joined Jun 2010
D_FAST
Very nice. I love the 106
au117 is offline Find More Posts by au117
Old Mar 30, 2013, 09:00 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Juggling a lot of different projects lately.
Got this back onto the table yesterday. Got the power system all fine tuned, checked ,double check,triple check and installed. As its a one time install,
I wrapped this design as tight as i could to the power system. So im dealing with 2-3mm wall thickness around the shroud So no hatch.
This was installed before gluing the remaining sections together.
Ill come back later and cut out an area for the esc and wire routing.
I increased my wing chord thickness after the intial cad work.
So if i choose i can install These mini retracts at a later date.
Got the wood roots install onto the Fus, with the new chord thickness i laminated some 3mm derpon and sanded to the root rib to blend it all in.
The wing cores got there wood treatments around the LE,TE and root.
Now to get some filler on her and get to glassing.
D_FAST is offline Find More Posts by D_FAST
Old Mar 30, 2013, 10:51 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
hatch tackled, Ill line it with balsa later, spars figured out, got the rudder all done as well.
Ready for fill.
11oz with unit installed.
Old Mar 30, 2013, 11:15 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
I was hoping for some pics - looking great!
BillO is offline Find More Posts by BillO
Old Mar 31, 2013, 07:15 AM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
sweet. Phil
mrshea is offline Find More Posts by mrshea
Old Mar 31, 2013, 09:33 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
progress
Old Mar 31, 2013, 09:44 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Looking sweet D!!!
unclecrash is offline Find More Posts by unclecrash
Old Apr 01, 2013, 06:29 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by unclecrash View Post
Looking sweet D!!!
+1, good to see you back into this project.
I have been a little under the weather and this will help kick start me.
Cheers,
Eric B.
Old Apr 02, 2013, 12:51 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
thanks guys. not much going on to show off.
Unless you all like watching epoxy dry, as much as me. :P
Old Apr 02, 2013, 01:13 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Very nice D.
The 106 has been on my list for a long time, need to get around to it.
J
J Morgan is offline Find More Posts by J Morgan
Build Log F-106 Delta Dart... DanSavage Electric Ducted Fan Jet Talk 270 Mar 23, 2012 05:58 PM
Build Log F-106 Delta Dart jgmtens Pusher Prop Jet Models 50 Jul 31, 2007 03:55 PM
Discussion Aero Ace F-106 Delta Dart sr71fan Scratchbuilt Indoor and Micro Models 7 Apr 10, 2007 01:37 AM
Question F-106 Delta Dart Aceshigh84 Electric Ducted Fan Jet Talk 18 Jan 20, 2007 04:10 PM
F-106 Delta Dart dirtdiver Electric Plane Talk 22 Dec 22, 2002 09:17 AM
