Old Aug 30, 2012, 11:15 PM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
5 watt led on 4 cell
I'm looking for advice to hook up a 5 watt led spot light to my quad.
How would you fellas wire this up so I can power it along with attach it to a receiver so I can switch it on and off.
Dan
PS...I'm using a 4 cell set up would like to wire it up so I just use the one lipo for all.
Kaw1000 is offline Find More Posts by Kaw1000
Old Aug 31, 2012, 12:27 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
What's the LED's voltage rating? You could directly power it off the lipo if you wire it in series with a resistor of an adequate value, but its brightness would change a bit as the pack's voltage fluctuates due to motor loads and such.
You could also probably use a voltage regulator of some sort to keep it steady. That could feed power into a receiver-controlled switch so you can switch it on and off.
Piece is offline Find More Posts by Piece
Old Oct 04, 2012, 01:36 PM
Barn-E-Stormer is online now
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Post the data sheet for your 5w LED and I can tell you the best way to wire it. At 5W a regulator system will waste a lot of power from a 14v source.
The Hobby King receiver controlled switch would work to turn it on and off.
http://www.hobbyking.com/hobbyking/s...idproduct=8833
Barn-E-Stormer is online now Find More Posts by Barn-E-Stormer
Discussion b 40 7L with 4.4:1 gearbox on 2 cell lipo xrx1113 Electric Sailplanes 2 Aug 28, 2012 11:17 AM
Discussion Banana Hobby FMS Stuka on 5 cell ?? Ala Flying Dude Electric Warbirds 3 Aug 21, 2012 11:50 AM
Discussion ? on charging 4 and 5 cell lipos Lights Batteries and Chargers 7 Jun 20, 2012 03:43 PM
Sold Great prices on 5 cell and 4 cell Hyperion packs! wollins Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2007 10:55 PM
