Old Aug 30, 2012, 08:33 PM
NCRealEstateGuy is offline
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
Top Flite P47 Razorback Electric Conversion
Hey Folks,
I ran into someone selling their house and in his garage was a TF P47 that he had built from a kit 6 years earlier, but had never maidened it. Long story short, I got a super deal on it and took it home. The monokote job was not done well, so I spent 4 hours taking it all off. Also, I cut all of the control surfaces off, as one aileron was warped, and the elevator and ailerons do not match up well to the wing tips. (see pics).
I took out the Super Tiger G90 engine, took out the Robart pnuematic retracts, and will spend some time this weekend filling, sanding and gluing. It has some build issues that I will redo the right way.
My plan is to install electric retracts (I need suggestions here), electric motor, probably 8 cell, (4cell x2), and I will be fiberglassing the entire plane. (never worked with glass before), and I may install a sound system depending on wieght. This will be my first war bird and my first balsa plane except for my Spectra glider.
All suggestions and comments are welcome.
NCRealEstateGuy is offline Find More Posts by NCRealEstateGuy
Old Aug 30, 2012, 08:46 PM
Charlotte, NC
Joined Feb 2011
Here is the SuperTigre G90 engine, muffler and mount. The SuperTigre G90, the updated version of the S90K. The main
differences between the two engines are that the G90 is a one-piece crankcase
(S90K was a two-piece), and the G90's muffler is a bolt-through-the-crankcase
(S90K muffler bolted onto the crankcase).
It is now for sale. Make me an offer.
Old Aug 30, 2012, 09:27 PM
mattthomas78 is offline
Find More Posts by mattthomas78
Crash test dummy....
mattthomas78's Avatar
United States, TN, Waynesboro
Joined Mar 2012
I'm subbed!!
mattthomas78 is offline Find More Posts by mattthomas78
Old Aug 30, 2012, 10:57 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
go to hobbyking.com, hey have all sorts of electric retracts. they have all metal units, and they have the size you need. they pretty much have anything you need, and at excellent prices. usually less than half the prices you'll pay here in the states.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Sep 08, 2012, 12:09 PM
Charlotte, NC
Joined Feb 2011
Getting some sanding done. I had to pretty much cover the entire fuse with Durhams Water Putty and light wieght spackling. I use a mixture of about 60/40. I will sand all this off and then do a final touch up with just the light wieght spackiling. And then I will try my hand at glassing.
Does anyone know of any electric retracts that would work in here?
Old Sep 08, 2012, 12:17 PM
Charlotte, NC
Joined Feb 2011
I just noticed that the motor mount holes are off to the one side more than the other side. The top hole is 3/4 inch from the top, the right hole is 3/4 inch from the side, the bottom hole is 1 inch from the bottom and the left hole is 1 1/4 incehes from the side. This sounds odd to me. Anyone with a TF P47 or someone with plans that can verify this setup?
Old Sep 08, 2012, 12:32 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Maybe that's for the offset? Aren't they all supposed to be offset to the right to counter torque roll?
matiac is offline Find More Posts by matiac
Old Sep 08, 2012, 03:29 PM
Charlotte, NC
Joined Feb 2011
Yes, but the offset refers to the angle that the motor is canted to the right. This looks like the motor would be off center. I am going to run downstairs and mate the old 90 engine to it and see if the shaft comes out of the cowling in the center.
Old Sep 08, 2012, 03:46 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Becareful Glassing. It can end up real heavy if you're not careful. You might weigh it first so you can see how much weight you end up adding.
I would probably not glass it myself.
These might work for retracts.
http://hobbyking.com/hobbyking/store..._20_class.html
You will want a 80 or 85 degree retract for 60 to 1.20 size aircraft.
Did you weigh it before you stripped it down?
Walter
TripleW is offline Find More Posts by TripleW
Old Sep 08, 2012, 03:54 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Here is my favorite Razorback.
Big Stud
http://www.google.com/imgres?hl=en&s...,r:8,s:0,i:102
http://www.google.com/imgres?hl=en&s...,r:9,s:0,i:105
Old Sep 08, 2012, 04:25 PM
Charlotte, NC
Joined Feb 2011
TripleW,
Why would I need 80 or 85 degree retracts? I am not experienced with retracts.
matiac is offline
AMA 994002
matiac's Avatar
Joined May 2012
From one of your first pics it looked OK, the pic was straight on...
Actually i take that back, I just looked at the pic again, and it IS high and to the right.
Old Sep 08, 2012, 04:51 PM
Charlotte, NC
Joined Feb 2011
TripleW,
The nitro version is said to wiegh in at 9.5 - 10.5 lbs with a wing loading of 30 - 33 oz/sq.ft.
I got rid of the pnuematic retracts for electric (don't know if this is a weight savings or not), I am replacing the 90 motor with an 8 cell electric, and replacing the one aileron servo with two.
I suppose I can put it all together when ready and wiegh it then and determine if glassing is OK. How much weight would glassing add?
Old Sep 08, 2012, 05:35 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Originally Posted by NCRealEstateGuy View Post
TripleW,
When the gear is extended they will be perpendicular to the runway.
It takes into account the dihedral in the wing.
Old Sep 08, 2012, 05:45 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Well it depends on your technique and materials used. But you can add alot of weight if your not careful.
Recently one of the club members glassed a 120 size Mustang and it was so heavy it didn't fly well. I don't remember how much weight it added.
Last I heard he was stripping it all off.
I have a Hanger 9, 60 size Hellcat that weighs 9.5 lbs without any glass work. Flies great as is.
Build Log Top Flite P47 - SCALE ELECTRIC BUILD Gree Glow to Electric Conversions 1311 Jun 16, 2016 08:01 PM
For Sale Top Flite P47 Thunderbolt RTF eidahsedai Aircraft - Fuel - Airplanes (FS/W) 1 Aug 13, 2012 09:41 AM
For Sale Top Flite Gold Edition P47 kit with extras.... imaslob Aircraft - Fuel - Airplanes (FS/W) 0 Jul 18, 2012 03:14 PM
Question Building Top Flite P47, 60 kit gold edition fire433 The Builders Workshop 2 Jun 02, 2012 12:58 AM
Discussion Top flite p47 razorback build issue fireplug1111 Scale Fuel Planes 4 May 25, 2011 04:33 PM
